800 RZR won't start! - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old August 13th, 2017, 08:06 AM Thread Starter
bentwheel's Avatar
Member #206673
View bentwheel's Photo Gallery(0)
Usa 800 RZR won't start!
I'm having problems getting my 09 800 RZR EFI started, I was riding in a creek, and hit quick sand, stuck, when we hooked the wench on my RZR, we pulled my RZR backwards (only direction I could go), killed my RZR, when I got my RZR to the bank, it won't turn over, water in the cylinders, I took my RZR home took the bed off of my RZR, cleaned all the sand and mud from around the plugs. Water was in cylinders, water was in engine oil, trans, and rear differential. I put new plugs in my 800, and put PB blaster after I started it, put new oil in everything.
Now I'm putting a home made snorkel kit on my 800 RZR, I also put a new air breather in my 800. All this time with working on my RZR, and being with family it's been a month. My 800 RZR won't start now, so I sprayed WD40, and starting fluid in my breather, my RZR started right up, but died few seconds after starting, after that my RZR would start run second or so then die. I did this start, and die thing 4 or 5 times. I quit for the day this morning my RZR won't start, I haven't checked the few pressure, but I can hear the fuel pump run, I would thing my RZR should least start, and die, even if I don't have 40 PSI. Anyone have any ideals what's happening here, I'm new to these RZR. Thank you for any help at all! I got a code reading of 2.2
bentwheel is offline
post #2 of 12 Old August 14th, 2017, 05:55 AM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Re: 800 RZR won't start!
Check the fuel tank for water, if you find water, remove tank, drain it and dry it very well, add fresh fuel, drain, clean and dry fuel lines to injectors, reinstall fuel tank. If no water in tank check fuel pressure. Report back.
Mike
MikeT is offline
post #3 of 12 Old August 14th, 2017, 01:50 PM Thread Starter
bentwheel's Avatar
Member #206673
I checked fuel pressure 40 LBS, I set the TPS 7.0 is as close as could get it, was on 4.9. I'll check the fuel tank for water, are the RZR real sensitive to water? Thank you Mike T
post #4 of 12 Old August 15th, 2017, 06:14 AM
MikeT's Avatar
Member #14202
Fuel pressure is spot on. Time to check the tank for water.
Mike
MikeT is offline
post #5 of 12 Old August 15th, 2017, 08:16 AM
XR4Honda's Avatar
My RZR: 2008 RZR, Rear Bench for my 2 boys
Member #13135
View XR4Honda's Photo Gallery(0)
What is your cylinder compression. If you turned it over much with water in the cylinder that isn't good.
XR4Honda is offline
post #6 of 12 Old August 16th, 2017, 06:49 AM Thread Starter
bentwheel's Avatar
Member #206673
First thing I did was checked the compression, 155 lbs on both cylinders, throttle closed, my RZR started right up after I changed all the oil, and new plugs. But it set for a month doing our family things, plus cleaning all the parts, and putting a home made snorkel kit. Mike T suggested water in the fuel tank, so I took the plug off fuel rail, put a hose on the end of the rail to fill a jar of gas, the pump kicked for a second and quit, got about a cup of gas, the pump quit pumping with power on, I check the 3 way plug to the pump, 1 wire had 5 volts, 1 wire had 2 volts, guess the last wire is ground. I checked the fuel pump fuse, it had 12 volts. I cleaned all the grounds I could find, still only 5 volts. I guess I got a short, are there's a ground I'm missing? I cleaned the grounds under the drivers seat, by the brake light switch, cleaned the ground by starter, and ground on coils. aim I missing a ground. Thank you for you guys help.. If you get 2 reply's sorry, I didn't sign in on the first one.
post #7 of 12 Old August 16th, 2017, 11:15 AM Thread Starter
bentwheel's Avatar
Member #206673
I downloaded a manual on my RZR today, starting to get better ideals why my pump shut off, and there was water in my vent tube to my fuel tank, I'm replacing all my vent tubes in my snorkel kit.
post #8 of 12 Old August 16th, 2017, 11:19 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Check relay contacts in fuse box.
Red/Black wire should be 12V.
Brown is ground wire.
Purple/white is sending unit to fuel gauge wire.
From Manual:
The ECU switches off the pump preventing the continued
delivery of fuel in these instances:
• If the key switch is not promptly turned to the "start"
position.
• If the engine fails to start
• If the engine is stopped with the key switch "on" (as in
the case of an accident).
In these situations, the “check engine” light will go on, but will
turn off after 4 cranking revolutions if system function is OK.
Once the engine is running, the fuel pump remains on.
See attached PDF
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #9 of 12 Old August 16th, 2017, 03:24 PM Thread Starter
bentwheel's Avatar
Member #206673
Thank you CA 800, Appreciate the time you took to send both pdfs. I checked everything and all was what it was suppose to be. Mike T suggested water in tank, so I cleaned the tank and found the vent hose full of water. put new vent hose, cleaned tank, put fresh fuel in the tank, and my RZR started right up. soon as it my RZR started, it started raining cats and dogs out side. Maybe get to ride my RZR tomorrow. Thank you all for your help, happy camper once again!
post #10 of 12 Old August 16th, 2017, 03:32 PM Thread Starter
bentwheel's Avatar
Member #206673
Usa Re: 800 RZR won't start!
Mike
Thanks Mike, water in tank, and vent line full of water. I could kick myself, Thanks again for the help.
post #11 of 12 Old August 16th, 2017, 03:32 PM
RED DOG SUSPENSION's Avatar
My RZR: 2015 XP1000, 2018 XPT1000
Member #213265
View RED DOG SUSPENSION's Photo Gallery(0)
Done deal
Last edited by RED DOG SUSPENSION; August 16th, 2017 at 03:43 PM. Reason: Problem already solved
RED DOG SUSPENSION is offline
post #12 of 12 Old August 17th, 2017, 06:53 AM
MikeT's Avatar
Member #14202
Awesome!! Glad you found the problem and fixed it. Now have fun.
Mike
MikeT is offline
Marks RZR XP 4 Turbo Build Gallery UTV Inc. UTV Inc 5 December 4th, 2017 06:58 AM
RZR 4 800 misc items lionsandwings Polaris RZR Parts For Sale 4 September 20th, 2016 07:25 PM
rzr 1000 seats charlie78 RZR 570 Specific Discussion 7 September 16th, 2016 06:11 AM
08 rzr 800 wont start :( robert421960 RZR 800 Specific Discussion 6 February 22nd, 2016 07:49 AM
