Rear Diff helicoil - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By CA 800
post #1 of 13 Old June 3rd, 2017, 04:49 PM Thread Starter
TNAstealth's Avatar
Member #201505
View TNAstealth's Photo Gallery(0)
Rear Diff helicoil
While changing the oil last season, i stripped out the Helicoil for the rear differential drain plug. Does anyone know what size the replacement would be?
TNAstealth is offline
post #2 of 13 Old June 4th, 2017, 12:55 AM
Rzr800s2009's Avatar
Member #182737
View Rzr800s2009's Photo Gallery(0)
Re: Rear Diff helicoil
Not sure but maybe you can go up in size instead?
Rzr800s2009 is offline
post #3 of 13 Old June 4th, 2017, 07:43 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
What model & year RZR?
The my RZR 800 does not have HeliCoils.
2014 800 LE w/EPS 50
CA 800 is offline
post #4 of 13 Old June 4th, 2017, 11:40 AM Thread Starter
TNAstealth's Avatar
Member #201505
its a 2009 800
post #5 of 13 Old June 4th, 2017, 01:56 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Did the HeliCoil strip out, or did it just unscrew with the plug?
If it is the stock drain plug, the thread size is 3/8-24 SAE Straight Thread O-ring (O-Ring Boss). You may be able to pick up some 3/8-24 HeliCoils and re-install one in the differential.
CA 800 is offline
post #6 of 13 Old June 4th, 2017, 02:44 PM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
It sounds like it's been cranked on before. You might need to use a product like this:
https://autoplicity.com/2546839-dorm...FQVqfgodaaAJNQ
Or, what I've done is just get a short bolt that's big enough to screw into a larger drilled and tapped hole in the differential, and before installing, I drill and tap a hole in the middle of the bolt to make one similar to the one I posted above.
Good luck!
Fimea is offline
post #7 of 13 Old December 4th, 2017, 04:38 PM
FijiRob's Avatar
First Name: Rob
My RZR: 2013 Polaris RZR4 800 EPS Blue Fire/Orange LE
Member #166049
View FijiRob's Photo Gallery(0)
Hey guys, my rear diff drain plug is also stripped. I don't have my repair manual around. Does anyone know if the plug is also a 3/8-24 standard (as mentioned above for the 2009) so I can purchase a Time-Sert kit to repair mine? I have a 2013 800 4 EPS.
thanks.
FijiRob is offline
post #8 of 13 Old December 5th, 2017, 12:46 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Drain plug part number 5133731 is listed for RZR 800 rear diff from 2008 thru 2014.
FijiRob likes this.
CA 800 is offline
post #9 of 13 Old December 27th, 2017, 09:05 PM
FijiRob's Avatar
First Name: Rob
Member #166049
Okay, I'm trying to figure out how to repair my rear diff drain plug with the Time-Sert, but there is not a lot of room to drill and retap. Has anyone done this and how did you do it with the limited space?
FijiRob is offline
post #10 of 13 Old December 28th, 2017, 07:31 AM
Pullerguy's Avatar
First Name: Les
My RZR: 2012 800 50"
Member #61901
View Pullerguy's Photo Gallery(0)
Rob:
We did a pinion nut on one in Reno last winter, the plug was stripped. I tool a 7/16-20 tap and ran it in with out drilling, then we used a short 7/16 Allen head bolt with a nylon washer to seal it.
Les
Pullerguy is offline
post #11 of 13 Old December 28th, 2017, 08:15 AM
FijiRob's Avatar
First Name: Rob
Member #166049
Originally Posted by Pullerguy View Post
Rob:
Les
Thanks Les. Can you explain how you did this?
FijiRob is offline
post #12 of 13 Old December 28th, 2017, 08:54 AM
Clayton4971's Avatar
First Name: Carl
My RZR: 2018 XPT fox edition
Member #36446
View Clayton4971's Photo Gallery(0)
Rob:
Les
Did the same thing Les , I would dip my tap in heavy wheel bearing grease turn two or three turns then clean tap and repeat . Pulled the chips out really well
Clayton4971 is offline
post #13 of 13 Old December 28th, 2017, 02:35 PM
Pullerguy's Avatar
First Name: Les
Member #61901
Rob:
I used a taper tap so the starting size was small enough I didn't need to drill it out. After I had some good threads started I backed the taper out and used a plug tap to finish the threads the rest of the way. As Carl mentioned I used a bit of grease on the tap to collect the cuttings, I turned the tap about 1/2 to 3/4 turn then back off then advance a little more. Pulled it and cleaned after a couple of turns, then more grease and do it all over again.
One issue with using the plug with the drain in the center is clearance for the hex of the head.
Hope this makes sense.
Les
UTV INC Rear Wheel Bearing Greaser Tool UTV Inc. UTV Inc 11 July 11th, 2017 08:06 AM
2016 RZR 4 900 Rear Diff Leak Kal Torak RZR 4 900 10 August 8th, 2016 07:40 PM
Blown rear diff? IZ48 RZR 800 Specific Discussion 13 July 11th, 2016 10:05 AM
Leak from rear diff? CV boot? Dalucazz RZR S 1000 5 April 17th, 2016 07:14 AM
Wtb 08 trans, transfer case and rear diff. Help!! Flip wi Polaris RZR Parts For Sale 2 December 11th, 2015 04:05 AM
