Differential fill plug broke using torque wrench! - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By jerrzr
post #1 of 9 Old May 20th, 2017, 04:28 PM Thread Starter
aswetich's Avatar
First Name: Tony
My RZR: 2008 Indy Red (All Stock)
Member #8916
View aswetich's Photo Gallery(0)
I am always very cautious when using plugs in aluminum. When changing my differential fluids I always use a torque wrench on all the plugs. For some reason my fill plug broke using the specified torque of 40- 50 foot pounds. I've run the service manual multiple times, do I have the torque right?
Sent from my XT1254 using Tapatalk
aswetich is offline
post #2 of 9 Old May 20th, 2017, 05:05 PM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Differential fill plug broke using torque wrench!
The manuals are mis-printed. Many people have done just as you have. Alot of people say the torque should be 40-50 in-lbs.
Clothier is offline
post #3 of 9 Old May 20th, 2017, 05:07 PM
Clothier's Avatar
First Name: Brian
Member #65577
Also the new diff I put in mine had a steel fill plug instead of aluminum.
Clothier is offline
post #4 of 9 Old May 20th, 2017, 08:33 PM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
That really sucks to have a mistype in the service manual. Its an easy trap to fall into if in a rush to get things done.
aswetich likes this.
post #5 of 9 Old May 23rd, 2017, 04:51 AM
Rzr800s2009's Avatar
Member #182737
View Rzr800s2009's Photo Gallery(0)
Damn bro i cant believe you didn't question that when you read it. Not your fault and they should have did a better job with the manual but the clutch on the engine side is only 40 ftlbs and that's an important fastener for instance.
If you didn't crack the case id see if maybe u go up a size and using a steel one and plenty of lube cut new threads or what you'll end up doing.
For future reference if it's something important i torque to spec otherwise I use the German torque specs "GUTEN-TITE" LOL
Best of luck and please post what the fix ends up being im very curious.
Rzr800s2009 is offline
post #6 of 9 Old May 23rd, 2017, 05:46 AM
Clothier's Avatar
First Name: Brian
Member #65577
No need to go up in size or anything, it just breaks the outer flange off the plug. Simply take it out and put in a new plug.
Clothier is offline
post #7 of 9 Old May 23rd, 2017, 08:43 AM Thread Starter
aswetich's Avatar
First Name: Tony
Member #8916
I feel like an idiot for over tightening the plug. I knew the torque seemed excessive but assumed it was necessary for a reason. The thing that really burns me is there is no mention of the misprint from Polaris and I can see any revised specification posted anywhere.
aswetich is offline
post #8 of 9 Old May 23rd, 2017, 09:08 AM
Clothier's Avatar
First Name: Brian
Member #65577
Yea I've never seen Polaris mention that the torque was wrong either. And I'm not 100% on the 40-50 in-lbs either. But after reading about so many broken plugs I just tighten mine up nice and snug so it wont back out. No problems in 2500 miles, just keep an eye on it for a bit after you do fluid changes.
Clothier is offline
post #9 of 9 Old May 23rd, 2017, 09:57 AM
rush2252's Avatar
First Name: Kolby
My RZR: 2013 Rzr 800
Member #135881
View rush2252's Photo Gallery(0)
Good and snug is all you need, it has an O-ring seal, 40-50 ft. lbs. is way excessive!
rush2252 is offline
Front Gear case fill plug is stripped tskilbride RZR 570 Specific Discussion 20 March 26th, 2019 12:06 PM
Stripped Transmission Fill plug captainphx General RZR Discussion 15 January 3rd, 2017 03:33 PM
Removing Trans fill plug??? bsmizzy07 RZR XP 1000 7 November 17th, 2016 05:55 PM
Transmission Fill Plug (main Gearcase) CP-06 RZR 900 - 50'' Trail Models 2 August 8th, 2016 08:12 AM
Cost of rear transmission lube fill plug MappGas1 RZR 570 Specific Discussion 41 December 17th, 2015 04:35 PM
