MudBuster Fender Flare install issue??? - Polaris RZR Forum - RZR Forums.net
 5Likes
  • 1 Post By BrianS
  • 2 Post By Denver
  • 1 Post By defiant0ne
  • 1 Post By Katnapper
post #1 of 8 Old August 14th, 2019, 08:59 AM Thread Starter
defiant0ne's Avatar
Member #270646
View defiant0ne's Photo Gallery(0)
Question MudBuster Fender Flare install issue???
Recently purchased a set of MudBusters for the 2012 570. I do appreciate the enclosed installation directions.
My issue is, I only got the drivers side front fender flare mocked up and noticed it does not really follow the angle of 570's front fender. It is about 1/4" off from the drilled holes in the flare and the supplied (mounted) L brackets. If I keep everything loose I can attach all the hardware, but when I start to tighten everything up the flare flexes and creates wide gaps between flare and fender edge.
Basically, when flare is installed, the body lines of the flare do not match the fender. I feel if I elongated the holes of the bottom two mounting bolts to add relief, the flare would line up better. But figured I would ask those who have installed these to see if there is something I might be overlooking.
Thoughts?
d1
defiant0ne is offline
post #2 of 8 Old August 14th, 2019, 10:20 AM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: MudBuster Fender Flare install issue???
Sounds like the machine or the Mudbuster flaps have a problem. Is it possible that you have the incorrect set for your machine?
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #3 of 8 Old August 14th, 2019, 10:41 AM
BrianS's Avatar
Member #266106
View BrianS's Photo Gallery(0)
Use a heat gun to reshape the mud buster fender flare? Be careful and use only enough heat to do the job.
defiant0ne likes this.
BrianS is offline
post #4 of 8 Old August 14th, 2019, 10:56 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Contact Chad at Mudbusters, they are very responsive. They are a supporting vendor. @Chad at MudBusters
Fastone110 and defiant0ne like this.
Denver is offline
post #5 of 8 Old August 14th, 2019, 11:45 AM Thread Starter
defiant0ne's Avatar
Member #270646
Great question. There are no specific markings on the flares to indicate otherwise. They do follow the same body line of the fender, the mounting holes seem off or as you indicated, maybe the 570's fender is off somehow. I will try the passenger side fender to see if I encounter the same issue.
Thank you for the info.
Denver likes this.
post #6 of 8 Old August 14th, 2019, 07:03 PM
Katnapper's Avatar
First Name: James
My RZR: 2014 570 LE
Member #70102
View Katnapper's Photo Gallery(0)
I just installed my mudbusters on mine a couple weeks ago. I had similar concerns when putting on the fronts. I had some gaps. Use a heat gun, or do like I did, and leave it outside in the sun for several hours. It will allow the plastic to relax and bend correctly.
I had mine loaded in the back of my truck at about 6pm and left it over night (backed against my garage). When morning came, gaps were almost gone. After riding all day and keeping it out in the sun all day, I don't have the gaps.
This is a pic from right after installation. You can see that everything isn't settled yet. Unfortunately, I didn't take a pic after my last ride to show the difference, but there is a difference.
Sent from my SM-G950U using Tapatalk
2014 RZR 570 LE
Accessories listed in garage
Katnapper is offline
post #7 of 8 Old August 14th, 2019, 07:30 PM Thread Starter
defiant0ne's Avatar
Member #270646
Good feedback, I appreciate you taking the time to share your results. Hopefully, I will have time this weekend to tackle finishing the fender flare install.
I will report back the results.
d1
post #8 of 8 Old August 15th, 2019, 06:58 PM
Vandal
Vandal's Avatar
First Name: Richard
My RZR: 2016 RZR 570 EPS Trail
Member #82526
View Vandal's Photo Gallery(0)
Thoughts?
d1
The Mudbusters do require a little massaging when first installed but are well worth the trouble. As others have stated a heat gun goes a long way
Vandal is offline
