Shock upgrades - Polaris RZR Forum - RZR Forums.net
 5Likes
  • 1 Post By HONDARACER
  • 2 Post By jeffawats
  • 1 Post By Katnapper
  • 1 Post By Eschmit04
post #1 of 15 Old July 20th, 2019, 08:28 AM Thread Starter
Eschmit04's Avatar
Member #249994
View Eschmit04's Photo Gallery(0)
Shock upgrades
2012 rzr 570 with upgraded clutch. Stock other than that. Want to run 27 or 28 inch tires eventually. I've looked at bandit and exit. Any recommendations? Experience? Live in northern Idaho with rough and Rocky terrain and high speed logging roads.
Eschmit04 is offline
post #2 of 15 Old July 21st, 2019, 02:20 AM
Macs Dad's Avatar
My RZR: 2008 Ranger RZR
Member #8581
Re: Shock upgrades
I've had ZBROZ EXIT 2's 3 way adjustable on my 08 800 with +6 long travel for years now. I ride hard pack, sand washes and dunes. Excellent shocks and springs as well as service. They did it over the phone with me and nailed them the first time. They coordinated with SATV on my long travel as well. They even called me a couple months after I had them on to make sure I was good with them. Absolutely great shocks and service.
Macs Dad is offline
post #3 of 15 Old July 21st, 2019, 09:31 AM
Martlor13's Avatar
Member #257610
View Martlor13's Photo Gallery(0)
I have bandit trails and ride what you described. Absolutely love them, no complaints
Martlor13 is offline
post #4 of 15 Old July 21st, 2019, 06:58 PM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
View HONDARACER's Photo Gallery(3)
Re: Shock upgrades
You dont need compression and rebound adjustable shocks on the 570. Just good aluminum body with upgradeable and adjustable springs. Gas charge would be a bonus. I dont think the 570 will ever have a plush ride. The control arm are so short and the machine has a short wheel base making the ride choppy. I am running 200lb front and 250lb rear springs with no front sway bar. I am pleased with the setup for fire road riding. If your riding very slow all the time you could probably go with less spring rate and no sway bars to soften the ride.
steve5657 likes this.
HONDARACER is offline
post #5 of 15 Old July 23rd, 2019, 03:17 PM
gmiller0737's Avatar
First Name: Gordon
My RZR: 2012 RZR 570
Member #47617
View gmiller0737's Photo Gallery(0)
Re: Shock upgrades
I have the Bandit Trail Series On My 570 Put them on @ 1600 Miles & Now @ 4200,Had to send one in for a reseal about 2 years back,Iím not running a front sway bar just the rear Ride & height improved over stock,Also swapped the shock Bushings over to Garage Products
gmiller0737 is offline
post #6 of 15 Old July 24th, 2019, 02:53 AM
jeffawats's Avatar
Member #269196
View jeffawats's Photo Gallery(0)
Re: Shock upgrades
Try some radial tires as well,massive difference in ride and performance.
steve5657 and cecil_bunkford like this.
What do ya mean I ain't kind just not your kind
jeffawats is offline
post #7 of 15 Old July 25th, 2019, 07:38 AM
Packer's Avatar
First Name: Packer
My RZR: 2014 570 LE, 2012 570
Member #74509
View Packer's Photo Gallery(0)
Re: Shock upgrades
I have the Zbroz Exit shocks. About 3500 miles in 3+ years on them so far in ID, WA, OR and Utah. Similar riding conditions to what you describe. They have been good and with the forum discount at the time they were about the same price as the Bandit shocks
Packer is offline
post #8 of 15 Old July 25th, 2019, 11:09 AM
turnkyle's Avatar
My RZR: 2013 570
Member #139233
View turnkyle's Photo Gallery(0)
Re: Shock upgrades
I haven't had any complaints or issues with my Exit shocks.
turnkyle is offline
post #9 of 15 Old July 25th, 2019, 01:58 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
Re: Shock upgrades
PM if you want Walker Evans or Exit shocks. We have both. Either will be better than what you have.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
post #10 of 15 Old July 31st, 2019, 03:32 PM Thread Starter
Eschmit04's Avatar
Member #249994
Re: Shock upgrades
Do the Exits or bandits also allow you to lift the machine? Not just get rid of the sag?
post #11 of 15 Old July 31st, 2019, 07:00 PM
Fastone110's Avatar
First Name: Travis
My RZR: 2016 1000s
Member #31197
Re: Shock upgrades
I bought Walker Evan shocks for my 2012 800 with Racertech Heavy Springs. It was the best option for the 50'' rzr IMHO besides getting wider and longer. That being said I think most aftermarket reservoir shocks with a good set of springs would be the best. It would also allow you to set your ride height and gain ground clearance with out a lift. If you wanted more left after that, go with a lift kit.
Fastone110 is online now
post #12 of 15 Old July 31st, 2019, 09:52 PM
Katnapper's Avatar
First Name: James
My RZR: 2014 570 LE
Member #70102
View Katnapper's Photo Gallery(0)
Re: Shock upgrades
You can, not recommended by either manufacturer. I found that my highlifter kit actually robbed my shocks of almost 1/4 total stroke due to compression from the lift on short a arms. Also caused my springs to sag prematurely. Best bet IMHO is to upgrade shocks, and use larger tires to get more lift. My bandit trail series before adding the lift (wasn't going to AT first) was about 1 inch more ground clearance than my machine had stock when I first measured it at about 300 miles.
Also, make sure you weigh your machine before ordering and talk directly to a sales person so that you can get your springs matched to your vehicles needs. Proper rated shocks will keep the clearence in the beginning as well as long term. Standard spring duel rate for bandit trail series is 220lbs front and 250lbs rear. Bandit offered to tailor my spring rate in the beginning, I declined then, but my sprung weight wasn't quite as much then as it is now since I didn't count driver and potential passenger extra fuel on board and my "get back out of the woods with the machine" gear.
Next week I'm refreshing my bandits with a check on charge, heavier springs, bump stops, and bushings, it's just under $300 to get that done in parts.
Sent from my SM-G950U using Tapatalk
Fastone110 likes this.
2014 RZR 570 LE
Accessories listed in garage
Katnapper is offline
post #13 of 15 Old August 1st, 2019, 07:06 AM Thread Starter
Eschmit04's Avatar
Member #249994
Re: Shock upgrades
Thanks everyone for the input. I really appreciate it.
post #14 of 15 Old August 4th, 2019, 12:27 PM Thread Starter
Eschmit04's Avatar
Member #249994
Do we get a discount on bandit shocks?
post #15 of 15 Old August 4th, 2019, 03:22 PM
Katnapper's Avatar
First Name: James
My RZR: 2014 570 LE
Member #70102
Re: Shock upgrades
Here's the link to their supporting vender page. Looks like last year they put out a 10% off code for labor day.
https://www.rzrforums.net/usercp.php#/forums/372
2014 RZR 570 LE
