Winch Mount Option??? - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Flashman1
post #1 of 6 Old July 10th, 2019, 08:56 AM Thread Starter
defiant0ne's Avatar
Member #270646
View defiant0ne's Photo Gallery(0)
Question Winch Mount Option???
The used 570, I recently purchased, has a 2" receiver welded to the front of the machine (please see attached picture for reference). Do they make a winch setup that can insert into this location? Or am I better off removing the 2" receiver and installing the winch in the typical location? I am looking to install a plow mount and will need a winch either way.
Thoughts?
d1
Name:	RZR receiver mount (2).jpg
defiant0ne is offline
post #2 of 6 Old July 10th, 2019, 05:42 PM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
View HONDARACER's Photo Gallery(3)
Re: Winch Mount Option???
Find the plow you want to run and then decide how to proceed with the winch. Polaris used to make lock and ride plow mounts but not sure if there is still any around. I have part numbers if your interested.
HONDARACER is offline
post #3 of 6 Old July 10th, 2019, 06:14 PM Thread Starter
defiant0ne's Avatar
Member #270646
Thanks, I would be interested in the part numbers, if you have them handy.
post #4 of 6 Old July 11th, 2019, 12:30 AM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
Glacier 2 mount 2878822
Frame mount 2878824
post #5 of 6 Old July 11th, 2019, 06:37 AM Thread Starter
defiant0ne's Avatar
Member #270646
Frame mount 2878824
Thank you. It does not look like the Glacier II mount that I have on my Sportsman 500 will work with this frame mount. I think maybe the Lock and Ride mounting tabs are wider for the RZR vs. the Sportsman.
post #6 of 6 Old July 11th, 2019, 01:49 PM
Flashman1's Avatar
Member #37609
View Flashman1's Photo Gallery(0)
A hitch mount winch would be nice - rigged so it can be mounted in the rear also. If you have to be pulled backward a front facing permanent mount is useless.
defiant0ne likes this.
Flashman1 is offline
