2013 570 lots of problems after washing - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old May 22nd, 2019, 06:52 PM Thread Starter
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
View HONDARACER's Photo Gallery(3)
Washed the rzr this am. Went to park it and noticed the check engine. Recorded codes and found shorted power circut on 4x4 circut. Also started without brake application, no head or taillights. Found headlight fuse blown but had now power to top row of fuses. Found blown fuse in auxillary fuse block in lr wheel well near the brake switch attached to frame. Replaced blown 30 amp fuse and now the headlight fuse blew again. Check engine light was off now though. Unhooked taillight harness upper lr wheel well and fuse dodnt blow. Traced harness and found it was not routed correctly from factory on right hand side. It was crushed between the box and frame where box mounts. Removed pinched harness and taped it up and rerouted correctly. No more blown fuses. Took about 2 hours to get all this done.
When I bought the machine I asked the previous owner why he had spare fuses in the tool kit. He said the headlights went out one time. Now we know why. Maybe that's one reason he got rid of it cheap.
HONDARACER is offline
post #2 of 7 Old May 22nd, 2019, 08:16 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: 2013 570 lots of problems after washing
Tail/brake light harness tends to fall down onto the muffler and melt/short out, just inside bed engine cover.
Sent from my S9+ using Tapatalk Pro
Denver is offline
post #3 of 7 Old May 23rd, 2019, 03:09 AM Thread Starter
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
Ya mine was crushed.
post #4 of 7 Old May 23rd, 2019, 04:50 PM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
View Beanhead's Photo Gallery(0)
HONDARACER, where was the rear tail light wires crushed ? I ask because my brake lights stay on all the time and I have replaced the the pressure switch. I have not lost any fuses, I have the same year and model that you have. thanks in advance.
Beanhead is offline
post #5 of 7 Old May 23rd, 2019, 08:26 PM Thread Starter
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
With the engine compartment lid off you will see a torx bolt on the right side in the area where you put your hand to lift the lid. My harness was supposed to run below and in front of that bolt but was pinched between the box and frame where the bolt goes in. I had to pry the box up pretty hard to get the harness out. Dont break it though.
post #6 of 7 Old May 24th, 2019, 10:13 AM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
Thanks for the info I will check it out this weekend.
Beanhead is offline
post #7 of 7 Old July 3rd, 2019, 03:56 PM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
Well I finally got around to checking out the tail lights. I removed the bed to find no pinched wires. While I was messing with the LED light bulbs I found that, for the life of me witch I cannot recall I must have removed a bulb and rotated it 180 degrees. So thats what was the problem, and I know I had checked them to be sure they were functioning properly when I originally changed out the stock bulbs.
Beanhead is offline
