2013 570LE won't start after being garaged. Spark but dry plug. - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 22 Old May 20th, 2019, 09:12 AM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
View Andrew_S's Photo Gallery(0)
Looks like i have the opposite problem of the post for the 2015 that is up. Have spark but the plug is dry after I tried starting it.
It was stored with a full tank of gas with a fuel stabilizer product in it and then neglected for a few years. Very low hours and worked fine prior to storing it. After replacing the battery, filling tires, topping off fluids, and greasing the suspension I couldn't get it to start. There is a spark but the spark plug is dry. After turning the key off there is the clicking sound mentioned in the other thread. Not sure if that is the fuel pump turning off or what that is. My best guess is a fuel pump or fuel injector problem. What should I do next?
Hoping to get this going for Saturday.
Andrew_S is offline
post #2 of 22 Old May 20th, 2019, 10:21 AM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
View HONDARACER's Photo Gallery(3)
Re: 2013 570LE won't start after being garaged. Spark but dry plug.
Bang on the gas tank while cycling the key on and off. Sounds like the pump is stuck
HONDARACER is online now
post #3 of 22 Old May 20th, 2019, 11:44 AM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
Thanks for the suggestion. Trying to come up with a few things to check tonight when I get home later today. Came across this vid showing how to check the pressure at the fuel rail:
Would this be worth doing? $20 from HF isn't bad but I see auto parts stores lend them out too.
Andrew_S is offline
post #4 of 22 Old May 20th, 2019, 06:28 PM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
Ok now that I am home to mess with it I realize I cannot hear the fuel pump power on. Pulled each of the lines coming off the top of the tank and cranked it to see if anything would squirt out and got nothing.
I was able to locate a 2012 RZR 570 service manual which I assume should be fairly close to my machine. It says to check pins 3 and 4 on the wiring harness for the fuel pump and to look for 7v. I am getting 4.9v. Checked continuity on the pump and got .001 so it looks like the pump should be good.
Manual says "If the voltage was below 7 VDC, test the battery, ignition switch, relay(s), wiring harness and ECU." Battery is a little low after cranking on it a bunch but still 12.4v. I am going to have to do some more reading to try and figure out how to do this. Unfortunately the gas cap gasket has deteriorated and fallen apart and a chunk of it has fallen into the gas tank so I also have that to figure out. It is looking less and less likely that I make my trip this weekend unless I take it in to the dealer to work on and hope they can fix it in time.
Andrew_S is offline
post #5 of 22 Old May 20th, 2019, 07:27 PM
gmiller0737's Avatar
First Name: Gordon
My RZR: 2012 RZR 570
Member #47617
View gmiller0737's Photo Gallery(0)
Might want to try swapping the fuel pump relay with one of the other relays The Headlight Relay May be the same
gmiller0737 is offline
post #6 of 22 Old May 20th, 2019, 10:09 PM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
Thanks for the suggestion. I read that in another thread but couldn't pull it out. Went and tried again with pliers after your comment and crushed the one I planned on swapping in. I guess I will be buying two new ones tomorrow and hope that gets me riding.
Andrew_S is offline
post #7 of 22 Old May 21st, 2019, 04:37 AM
Irondogracer's Avatar
First Name: Rob
My RZR: 2017 XP1000 Gold Matte, 2011 Ranger XP 800 LE, 2009 Ranger XP700, 2012 Yamaha 700EPS
Member #98841
View Irondogracer's Photo Gallery(0)
If you hear the fuel pump come on for a couple od seconds with key, then it would not be relay. Low fuel pressre from the pump would keep the injector from opening. Always go back to basics as we overthink, dry plug, FUEL, wet plug ELECTRICAL. Interesting following this post as the final anwswer, thanks for keeping us posted.
Irondogracer is offline
post #8 of 22 Old May 21st, 2019, 05:04 AM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
The pump only has power for a few seconds to prime untill the motor is running for safety reason. If your testing for power to the pump you need to be aware of this. The fuel pump being stuck is more likely than a defective relay.
post #9 of 22 Old May 21st, 2019, 08:55 AM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
I am not hearing the fuel pump come on and I have already checked to see if it is pumping fuel and it is not. The service manual had me check the electrical of the fuel pump. Says there should be at least 7v on the harness. I have 4.9v. Also says that if the fuel pump is good there should be continuity across those pins and there is. "If the voltage was below 7 VDC, test the battery, ignition switch, relay(s), wiring harness and ECU." Just trying to follow the service manual, suggestions here, and whatever I find searching. If you see where I went wrong I'd be happy to check something else. I've already tried your suggestion of banging on the fuel pump while cranking.
There were instructions for testing the ignition switch in the service manual but I was done for the night. Didn't really see what to check on the ECU or wiring harness but I'll try and do some more reading today.
The relay is crushed now anyway and I have ordered some from Amazon since they have a guaranteed delivery of tomorrow. I read that the relays can be purchased from NAPA and other parts stores but I couldn't find them searching on any of their websites. Had to get the Amazon order in last night if I wanted Wed. delivery so I just went with it figuring losing 1 day was better than losing 2. I've got a quad that needs a carb cleaning and some packing to do that can keep my busy tonight.
Andrew_S is offline
post #10 of 22 Old May 22nd, 2019, 06:32 AM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
Well my first move would be to make sure the fuel pump does work. I would jump the fuel pump relay pins 30-87 and the pump should run. Then I would verify the engine starts.
BWXT likes this.
post #11 of 22 Old May 23rd, 2019, 08:23 PM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
Relays weren't the problem. After rechecking the service manual I realized I was probing the wrong wires on the fuel pump harness. I am getting proper voltage so it looks like the fuel pump is the problem after all. Did some more banging on it and cant get it to kick on.
Is it worth buying from the dealer tomorrow? I am seeing a huge range on these. It looks like I can replace the fuel pump motor for as little as $20 or the whole assembly for ~$180 with aftermarket parts. OEM looks to only sell the full assembly for $350+.
Andrew_S is offline
post #12 of 22 Old May 24th, 2019, 05:12 AM
HONDARACER's Avatar
My RZR: 2013 570
Member #12019
I would take the pump assembly out and try to get it working. The pump is just stuck and needs help getting turning again. Perhaps even just jumping the pump directly to a good car battery andvrapping on the pump with a screwdriver handle.
The pump isnt worn out it just needs some help getting back to do its job, kinda like physical therapy. Good luck
bcs-extreme likes this.
post #13 of 22 Old May 24th, 2019, 09:18 AM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
If it were just "stuck" shouldn't I still hear it power on when it is getting voltage? It is dead silent when it gets 12v on ignition and I could feel no signs of life either. I was in the process of hard wiring it to the rzr battery to make sure it worked when I realized that I had checked the wrong pins. If hard wiring it doesn't do the trick how good or bad of an idea would it be to reverse the polarity on it to try to unstick it?
I've only got about an hour after work that I can fool around before the dealership closes. Going to call them later today to find out if they have a pump in stock and how much it will cost.
Andrew_S is offline
post #14 of 22 Old May 24th, 2019, 09:54 AM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
I agree with Hondaracer, I've had this happen on vehicles after a long sit. Did you pull the pump? If not, that's what I would do. It won't take much to get it going.
And no, you won't hear anything but silence.
See if you can get one from the dealer just in case, and return it if unused next week. I went aftermarket on my 800, with a perfect match that fits a 93 jeep 4cyl.
204 AR is offline
post #15 of 22 Old May 24th, 2019, 12:53 PM Thread Starter
Andrew_S's Avatar
First Name: Andrew
My RZR: 2013 570 LE
Member #54093
Was able to take off work early so now I have the pump removed. Had to use a hammer and push block to undo the retaining ring so I've jostled the assembly pretty good just getting it out.
There were some clear crystals on the top silver part which I brushed off and hit with brake cleaner to flush out. There are three plastic circles on the bottom that are deteriorating which I am not sure if I should be concerned about. Tapped around the pump a bit and I've left it upside down to dry out. Is this pretty much all that I need to do or should I be doing something else to it to get it to work? All of the wired connections look good. Not sure if I should attempt further tear down or just drop it back in with fresh gas at this point.
I also got the pieces of my gas cap gasket out of the tank and cleaned out the bottom as best as I could.
ID:	577550   Click image for larger version
Andrew_S is offline
Rzr 170 wont start! Has no spark Acristinaa RZR 170 Specific Disccusion 0 November 9th, 2017 01:11 PM
08 rzr 800 wont start not getting spark T-RZR Community Help 4 June 11th, 2016 02:35 AM
Spark Plug maintenance - WHY?? mowdoc RZR 570 Specific Discussion 7 September 30th, 2013 01:01 PM
Some Info On A Spark Plug for a 2013 570 crazycaper RZR 570 Specific Discussion 4 October 29th, 2012 10:42 AM
Spark Plug wires scottw1171 General RZR Discussion 2 October 18th, 2009 06:00 PM
