Winch wiring question - Polaris RZR Forum - RZR Forums.net
 20Likes
post #1 of 31 Old March 21st, 2019, 05:25 AM Thread Starter
Slamfire's Avatar
Member #266088
View Slamfire's Photo Gallery(0)
So I just installed a Kimpex 3500lbs winch on my buggy.
I installed the winch solenoid on the firewall inside the cab and ran the wires to the battery thought the tunnel.
This winch kit didn't include any type of circuit breaker at all. I didn't have one on my previous atv but I've seen a few threads on here and I'm thinking I probably should have one.
I don't see a lot of room around the battery to mount a circuit breaker. Any ideas how to mount one?
I did find a block at work with 2, 40 amp breakers that looks like it was for a winch, do you think they would be up to handle the load?
2018 570 base
Slamfire is offline
post #2 of 31 Old March 21st, 2019, 07:26 AM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Re: Winch wiring question
Iíve never run a breaker or a fuse on a heavy load like a winch or starter motor. Heard of guys doing so and then it wonít work when you need it to. General rule of thumb is if you canít hold your hand on the motor housing you need to let it cool. You could also add a volt-meter to monitor voltage on long pulls if that is your concern, but if you use a little common sense and keep the vehicle running while winching and for a while afterward, you shouldnít have any problems. And if the wiring and connections are kept clean and maintained there really is not a concern for overloading the circuit. Thatís been my experience anyway.
Vandal and Slamfire like this.
BWXT is offline
post #3 of 31 Old March 21st, 2019, 09:41 AM
madsonp's Avatar
My RZR: 2017 XP 1000
Member #189721
View madsonp's Photo Gallery(0)
I'd suggest putting one on, without one, if you get a short you can burn up your machine.
Slamfire likes this.
madsonp is offline
post #4 of 31 Old March 21st, 2019, 10:19 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Never run anything directly from the battery without a fuse or breaker. For winches I like to use a 200A resettable breaker.
Name:	th (3)_1553188782356.jpeg
RZR_Joe is offline
post #5 of 31 Old March 21st, 2019, 10:31 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
A winch can pull a lot of amps, hence the large gauge battery cables.
I was not comfortable with long battery cable with no short circuit protection and was not happy with available fuses or breakers that could handle the amperage caused by a stalled winch.
I used a 300 amp battery disconnect switch, and only turn it on when I am using winch.
https://www.bluesea.com/products/600...Knob_-_Red/FAQ
paul463 and Slamfire like this.
2014 800 LE w/EPS 50Ē
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2Ē lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #6 of 31 Old March 21st, 2019, 07:55 PM
BWXT's Avatar
Member #241858
Attachment 573552
Iím honestly surprised to see you guys recommending a fuse or breaker for a winch. Iíve been doing the offroad thing for 20 years and really never known anyone who did this, nor have I ever seen it recommended by manufacturers or any of the better known offroad gurus. That said, I do like the idea of the power disconnect switch. Might add that to mine, but I donít think Iíd ever add a breaker.
BWXT is offline
post #7 of 31 Old March 21st, 2019, 09:24 PM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
My superwinch came with a circuit breaker Iím mean you donít have to fuse or relay anything and might get away with it for a lifetime but why risk it over s simple part
Metki is offline
post #8 of 31 Old March 21st, 2019, 11:22 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
I to have been doing the off-road thing, for close to half a century.
I never saw the need for a disconnect between the winch in front of the grill and the battery behind the grill.
Then I got a side x side.
The cable from the contactor (relay) had to go;
behind the dash,
thru the fire wall,
down the frame,
between the floor and the frame,
across skid plate,
past the drive shaft,
to the battery located under my tail bone,
and I thought a short circuit caused fire would not be a good idea in a hydrocarbon tinder box.
ljrat and Slamfire like this.
CA 800 is offline
post #9 of 31 Old March 22nd, 2019, 03:40 AM
BWXT's Avatar
Member #241858
behind the dash,
thru the fire wall,
down the frame,
across skid plate,
Lol
BWXT is offline
post #10 of 31 Old March 22nd, 2019, 09:13 PM
Vandal
Vandal's Avatar
First Name: Richard
My RZR: 2016 RZR 570 EPS Trail
Member #82526
View Vandal's Photo Gallery(0)
I agree....The heavy gauge wiring from the battery to the contactor is made to protect the circuit from building too much heat on a long pull. As long as those wires are installed properly (away from sharp objects and pinch points where they might have a tendency to chafe) you will never have trouble with that circuit. I like BXWT, have never run relays or circuit breakers on the power cables for a winch. I also have used heavy gauge cable on boats to power the trolling motors with either 12 or 24 volts and even when running the trolling motor constantly for hours the cable is large enough to disperse any heat that might cause issues, and have never had to use relays or circuit breakers on these circuits either. I know some will say, well that's on a boat and winches will build much more heat than a trolling motor will, you must remember a 24 volt trolling motor has twice the volts and also more amp draw for hours on end at a time pulling a 3000 lb bass boat through the water so I'd have to say that if an unprotected circuit can stand up to that kind of abuse a utv's winch isn't going to pose any more of a risk than that trolling motors performance does, and not to mention you don't use a winch constantly over hours and also you should be trying to help the winch by moving the utv under power while using the winch. Some boats actually come with circuit breakers on the batterys but I've never used them and have never had a problem on a boat or an atv. I actually worry more about the switch wiring on a winch but if you use keyed power as your power supply your actually already on a circuit with a 20 amp fuse so youre protected there without doing anything extra. Ive seen more problems caused by relays and circuit breakers than whatever protection they might give in off road and offshore situations. 6 gauge wiring such as used in winches and trolling motor wiring can take a lot of abuse without any help
Denver, nibroc, BWXT and 1 others like this.
Vandal is offline
post #11 of 31 Old March 23rd, 2019, 09:33 AM
Live'n in Gods Country
MLK65's Avatar
My RZR: 2013 RZR 570 LE
Member #70450
View MLK65's Photo Gallery(0)
Vandal please do not take this as a negative post, in regards to the trolling motor wiring the protection devices are not to protect the motor it is a Coast Guard requirement to protect you and your boat from possible fire. I know this from years as a marine mechanic specializing in MinnKota troling motors.
2013 570 LE, 26" Kendra HTRs, Bandit 46 Sport shocks, Desert Molding Concepts Suspension Seat Brackets, Polaris 4500 lb winch, Trail Armor doors, CB roof, F&R windshields, Heater Craft heater, custom side windows, turn signals, 2 custom gun mounts, Tusk skid plate, 20" light bar, Dalton Clutch Kit, & lots of other goodies!!!
MLK65 is offline
post #12 of 31 Old March 23rd, 2019, 06:39 PM
Vandal
Vandal's Avatar
First Name: Richard
Member #82526
I didn't take as a negative post. Newer boats are under Coast requirements and do come equipped with circuit breakers but older boats aren't and the boat I mentioned was a 1978 model that ran flawlessly for 24 yrs with only the protection of the 6 gauge wiring. I never had a fire and didn't even have the wiring get hot to the touch so if I had put a circuit breaker on that boat it wouldn't have tripped over the 24 yrs I ran it. Since the trolling motor is under water worrying about it overheating is a mute point. I just wanted to point out that many times relays and circuit breakers are not needed depending on what wiring your using. Believe me I would be the first to advocate for protection if I knew it was needed, but in this case or with the winches heavy wiring I believe its possibly overkill
Vandal is offline
post #13 of 31 Old March 23rd, 2019, 09:01 PM
Metki's Avatar
Member #164697
I installed a circuit breaker because my superwinch came with it and deemed it necessary so I did the good old days of 1978 are gone when you smoked with the windows up didnít have to wear seatbelts or put circuit breakers on your dang trolling motor.
Metki is offline
post #14 of 31 Old March 23rd, 2019, 10:54 PM
Katnapper's Avatar
First Name: James
My RZR: 2014 570 LE
Member #70102
View Katnapper's Photo Gallery(0)
I will always error on the side of caution. So what if I have to reset the breaker or change fuses. I carry extras anyway. Those items are made to fail to avoid catastrophic failure.
Having a machine go up in flames sparking a wildfire is not acceptable especially when it would be found if my wiring was jacked and I would be required to pay for damages including fighting the fire.
You do you though. If it works in your favor, great, if not, hopefully nobody gets hurt because of your decision.
Sent from my SM-G950U using Tapatalk
MLK65 likes this.
2014 RZR 570 LE
Accessories listed in garage
Katnapper is offline
post #15 of 31 Old March 24th, 2019, 09:36 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
I've installed my winches on both my machines; neither of them came with nor did the instructions recommend/require a circuit breaker. Is it a good idea? I call it situational. If I was a mud/water rider I'd have a CB on everything; but I'm a mountain/dust rider... I have to agree with Vandal; as long as you have proper gauge wiring and properly installed terminal ends, you shouldn't have any hot spots. Adding the CB means another two terminal ends to install, unless you purchase a wiring kit with the CB inline builtin.
XB3 fire extinguisher, in cab. RAM-mounted Samsung Tab GPS. Larsonator DIY dual rate spring kit and Schmidty Racing resi end caps. Garage Products bushings. BugBuster mesh windscreen and rear mesh screen. Outerwears on R2C air filter and clutch intake. 3500# Winch, parking brake. Polaris DVR mirror & Drift Innovation action camera. PRP harnesses. Roof. DIY mud flaps. Tusk front bumper. UHMW A-arm guards. Hunterworks Gates Carbon belt.
Denver is offline
Winch Wiring Question Mad Dog 7.62 General RZR Discussion 5 April 6th, 2017 06:33 PM
Winch switch wiring question Beestieboy Lighting, Stereo and Electrical 14 April 26th, 2016 08:10 AM
Wide Spool Winch Install Question? Cadiero RZR XP 900 6 January 12th, 2014 10:14 PM
To Winch or Not to Winch, That Is the Question kmburns49 General RZR Discussion 30 June 19th, 2013 05:23 AM
Winch Question 10SuperCab Lighting, Stereo and Electrical 16 March 5th, 2013 10:42 AM
