RZR 570 Secondary question - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 19 Old May 24th, 2017, 08:23 PM Thread Starter
rgoers's Avatar
First Name: ron
My RZR: 2013 RZR 570
Member #65815
View rgoers's Photo Gallery(0)
I just replaced the primary clutch on my 2013 570. In the process, I inspected the secondary. Here's the problem though, I cannot find ANY diagrams that match the secondary I removed. The manual I have (2012 - yes mine's a 2013, but I don't have a 2013 service manual available to me) shows a shaft with a snap ring that holds the spring under tension. Every video I have seen shows the secondary with the shaft and a snap ring. They are not fastened together in any way, except for the bolt that fastens to the shaft.
My secondary is stamped "Rapid Reaction" (see pic in this link: https://www.rzrforums.net/rzr-s-900/1...on-clutch.html). The strange part is it has the spring on the BACK (gearbox side). The spring is held in with a cup and a ring with 5 screws fastened to the back gearbox side of the fixed sheave. The movable sheave just slides off the drive shaft once the bolt is removed. I don't get it.
Has anybody seen this clutch? Is mine correct and/or installed correctly? Anybody know where I can get an exploded view with parts list?
'13 RZR 570, Spectre intake fix, Utah street-legal, BEAMTECH LED headlights, Dual color (amber/white) 4" LED fog lights, LED tail lights & turn signals, Parking brake, Half windshield, Polaris soft top, Tusk UTV cab pack, Tusk rear window, HF rear rack hack, ITP 12x7 rims 4/156 4+3, EFX 26x9 Motoclaws, Superwinch LT4000ATV SR, Bandit 46 (Series 2) reservoir shocks, Front and rear sway bars detached... High altitude weights, Dalton DPSS-GY/O primary spring.
rgoers is offline
post #2 of 19 Old May 24th, 2017, 09:15 PM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
Re: RZR 570 Secondary question
Answering my own question... I found a diagram on Babbit's website. It shows the clutch 180 degrees from how mine was/is installed. Seems I'm missing a washer (#10) as well.
ID:	427233   Click image for larger version
rgoers is offline
post #3 of 19 Old May 25th, 2017, 04:23 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Nothing special about yours, the 12 was different and the 13 and newer have the clutch you have now.
Other than missing #10 what is the question you have on it?
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #4 of 19 Old May 25th, 2017, 06:16 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Ron, is that picture your clutch right now? If so it's correctly installed. I can't imagine the clutch mounted backwards and the belt alignment being anywhere near correct.
XB3 fire extinguisher, in cab. RAM-mounted Samsung Tab GPS. Larsonator DIY dual rate spring kit and Schmidty Racing resi end caps. Garage Products bushings. BugBuster mesh windscreen and rear mesh screen. Outerwears on R2C air filter and clutch intake. 3500# Winch, parking brake. Polaris DVR mirror & Drift Innovation action camera. PRP harnesses. Roof. DIY mud flaps. Tusk front bumper. UHMW A-arm guards. Hunterworks Gates Carbon belt.
Denver is offline
post #5 of 19 Old May 25th, 2017, 06:21 AM
First Name: Todd
Member #47437
Yes it is installed correctly and picture is right, they are all from drivers side rear view looking forward
www.hunterworks.com
Todd
post #6 of 19 Old May 25th, 2017, 09:02 PM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
Got it.
Thanks for the replies. My main question was about the weirdness of the secondary - how it comes apart without having to release spring tension, and how it appears to be on backwards from the parts diagram I found. The parts diagram shows the bolt going in the spring side. Mine has the spring side against the gearbox, and the bolt goes in from the fixed sheave with the helix. I was mainly thinking it was actually broken somewhere because of the way the two halves come apart without needing a tension fixture/tool.
I'm also trying to tune this thing for the higher altitudes I live/ride at. I cannot go below 4700 feet where I live. It's high desert, and that's my base altitude pretty much anywhere I ride locally. Most of my riding takes place between 5000-8000 feet. It may just be me, and my seat-of-my-pants meter, but with the new clutch the RZR just feels sluggish. All the dealer did was install high altitude weights when I bought it. No other changes. I have since changed from the stock 25x8/25x11 tires to 26x9 tires all around. I'm thinking the increase in size gets cancelled by running narrower tires in the rear. So now I'm fiddling with clutch weights and potentially clutch springs. The biggest problem I have is getting the RPM up high, quickly. It takes a very long time to reach 50 MPH, and if I let off the gas and hit it again, the RPMs stay low. I'm thinking I need better backshift, which means I would need a stiffer secondary spring. Maybe the missing washer is the problem there...
rgoers is offline
post #7 of 19 Old May 25th, 2017, 11:42 PM
Denver's Avatar
First Name: Denver
Member #41951
Does yours look like the picture you posted? If not please post a picture. Actually, post one anyway?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Denver is offline
post #8 of 19 Old May 26th, 2017, 07:45 AM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
Mine looks *exactly* like the one I posted.
Denver, when are we going riding again???
Denver likes this.
rgoers is offline
post #9 of 19 Old May 27th, 2017, 04:07 AM
First Name: Todd
Member #47437
Got it.
We do offer an adjustable dalton clutch kit for this model.
Tire size does change things drastically on the lower HP machines
Polaris RZR XP 1000 900, Polaris Ranger 800 - 2013-16 Std. 570 Dalton Clutch kit
There is a link to the ki
Todd
www.hunterworks.com
Todd
post #10 of 19 Old May 27th, 2017, 07:04 AM
Packer's Avatar
First Name: Packer
My RZR: 2014 570 LE, 2012 570
Member #74509
View Packer's Photo Gallery(0)
The Dalton kit from Hunterworks is easy to install and adjust and makes a noticeable difference.
Packer is offline
post #11 of 19 Old May 27th, 2017, 06:14 PM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
I already have close to $500 into the new primary I just bought. Maybe when I rebuild the clutch I took off it...
rgoers is offline
post #12 of 19 Old May 28th, 2017, 05:33 AM
First Name: Todd
Member #47437
IT is not a rebuild kit it is a performance kit that will be right on RPM
Also was addressing this part of your post
"The biggest problem I have is getting the RPM up high, quickly. It takes a very long time to reach 50 MPH, and if I let off the gas and hit it again, the RPMs stay low. I'm thinking I need better backshift, which means I would need a stiffer secondary spring. Maybe the missing washer is the problem there..."
www.hunterworks.com
Todd
post #13 of 19 Old May 28th, 2017, 07:30 PM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
Yes, I understand what the performance kit is for. I was simply stating that I have basically run out of money because I bought a new OEM clutch, and new weights to go with it. The performance kits are quite pricey, and I'll have to wait a while before I can go that route. I now have a 'spare' clutch that is in perfect condition (minus the consumables like rollers and bearings). When I get to rebuilding THAT clutch, I'll spend the coin on the performance kit, as I have to buy new weights and spring for it anyway.
I'm not discounting the helpful info I have received thus far. I'm just 'out of budget' now. I'm sure there are many here who can understand that. I'd like to have it all... but 'all' costs more money than I have at this point, and I *do* have a brand new clutch on it now, so at least I'm good for another 3800 miles or so.
Denver and Hunterworks like this.
rgoers is offline
post #14 of 19 Old June 2nd, 2017, 11:58 AM
lets go there's Avatar
First Name: Jeremy
My RZR: 570
Member #73517
View lets go there's Photo Gallery(0)
Epi has a black and white PEBS25 secondary spring that worked perfect for my 28" outlaw 2's and I have the same secondary as you
lets go there is offline
post #15 of 19 Old June 3rd, 2017, 03:24 PM Thread Starter
rgoers's Avatar
First Name: ron
Member #65815
Thanks! I'm at high altitude, so I have the 48 gram weights in it. I have been looking at secondary springs. I printed off a ton of info last week, including the EPI, SLP, and Dalton springs.
Yikes. That black/white is a 160/205! Hole-shots would be fantastic with that... probably snap your neck in the process. lol
I was looking at the spring that comes in the Dalton kit - DPSS-GY/O. The Dalton is a 90/175 spring. That's a lot closer to the stock spring, and would engage smooth at a low RPM, but give slightly better backshift, which is what I'm looking for. I'm so close now. Good pickup, and I'm hitting the speed limiter at about 7250 RPM. That gives me a couple hundred RPM to fiddle with... Ideal situation would be to hit the speed limiter and rev limiter at the same time.
Anyway, for $30-ish bucks, I'm going to give the DPSS-GY/O a try and see where it lands me.
Anybody on the forum a dealer for Dalton? I'd rather support a 'local' if I can. Otherwise, I will have to use Dalton's online sales outlet (Drivepower).
rgoers is offline
Marks RZR XP 4 Turbo Build Gallery UTV Inc. UTV Inc 5 December 4th, 2017 06:58 AM
UTV INC Rear Wheel Bearing Greaser Tool UTV Inc. UTV Inc 11 July 11th, 2017 08:06 AM
RZR 570 / 900 / 1000 parts chendric Polaris RZR Parts For Sale 3 January 8th, 2017 07:19 AM
Perfex RZR 570 2" lift $ 70 including shipping lower 48 JdubNC Polaris RZR Parts For Sale 0 December 19th, 2016 07:12 PM
Twisted Stitch RZR Seats In Stock - 03/15 UTV Inc. UTV Inc 10 March 31st, 2016 09:15 AM
