2015 Wheel Bearings - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 32 Old March 25th, 2017, 08:30 AM Thread Starter
mattre69's Avatar
First Name: Matt
My RZR: 2015 RZR 570 White Lightning
Member #32732
View mattre69's Photo Gallery(0)
Question 2015 Wheel Bearings
I was reading here that for some RZR's you can get a greaser specific to RZR wheel bearings that will help them last. They were also saying that RZR's are shipped with minimal grease the the wheel bearings. I don't remember what size RZR the greaser were for, maybe 800's. My question is, do they make one for our 570's? I haven't looked into it to see what design our bearings are yet. I'm assuming from the fact that there is a greaser for some others that there must be openings in the middle of the inner race to pressurize grease through? Would just like to keep from replacing when I can.
Thanks!
Matt
2015 RZR 570, Dalton clutch kit, Viper 3500, Bandit trail series, EMP front and back windshields and roof, 26" Big Horns, 14" SS212 wheels black, Mudbusters, Quadboss trunk, LED replacement lights, EMP parking brake, 30ah battery
2009 RZR170 bought new Sept 2011
Kolpin front and rear windshield and top
CVT and engine cooling intake re-located.
mattre69 is offline
post #2 of 32 Old March 25th, 2017, 08:36 AM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: 2015 Wheel Bearings
Holy Tools
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #3 of 32 Old March 25th, 2017, 10:49 AM Thread Starter
mattre69's Avatar
First Name: Matt
Member #32732
It says it's for 900 and 1000?
Matt
mattre69 is offline
post #4 of 32 Old March 25th, 2017, 11:26 AM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
View Beanhead's Photo Gallery(0)
I have been checking into the holy greaser too , we have to order both the 40 and the 44 mm tools for the 570.
Beanhead is offline
post #5 of 32 Old March 25th, 2017, 11:57 AM
Live'n in Gods Country
MLK65's Avatar
My RZR: 2013 RZR 570 LE
Member #70450
View MLK65's Photo Gallery(0)
MACHINED INTEGRATIONS makes a set for the 570's. Not sure how to make a link you need the RZR 570 EFI UTV product. $75 comes with two greasers one front & one rear. You due have to release the hubs to remove the axle shafts from the hub, less than 2 hours to completely grease all 4 bearings.
2013 570 LE, 26" Kendra HTRs, Bandit 46 Sport shocks, Desert Molding Concepts Suspension Seat Brackets, Polaris 4500 lb winch, Trail Armor doors, CB roof, F&R windshields, Heater Craft heater, custom side windows, turn signals, 2 custom gun mounts, Tusk skid plate, 20" light bar, Dalton Clutch Kit, & lots of other goodies!!!
MLK65 is offline
post #6 of 32 Old March 25th, 2017, 12:15 PM Thread Starter
mattre69's Avatar
First Name: Matt
Member #32732
Just found this when looking at Youtube videos. It doesn't mention ours as needing two of them?
TGH Bearing Greasers (various Models) - Busted Knuckle Off Road
Matt
mattre69 is offline
post #7 of 32 Old March 25th, 2017, 01:43 PM
js570's Avatar
My RZR: 2013 570
Member #53344
View js570's Photo Gallery(0)
The 570s need two we have two different size wheel bearings. I have the holy tools ones and they work great
js570 is offline
post #8 of 32 Old March 25th, 2017, 02:43 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Holy Tools, you don't need to remove the axles.
Sent from my Note 5 using Tapatalk 6
mattre69 likes this.
XB3 fire extinguisher, in cab. RAM-mounted Samsung Tab GPS. Larsonator DIY dual rate spring kit and Schmidty Racing resi end caps. Garage Products bushings. BugBuster mesh windscreen and rear mesh screen. Outerwears on R2C air filter and clutch intake. 3500# Winch, parking brake. Polaris DVR mirror & Drift Innovation action camera. PRP harnesses. Roof. DIY mud flaps. Tusk front bumper. UHMW A-arm guards. Hunterworks Gates Carbon belt.
Denver is offline
post #9 of 32 Old March 25th, 2017, 05:38 PM Thread Starter
mattre69's Avatar
First Name: Matt
Member #32732
Holy it is then.
I would think that the 40 mm would work on the 44 bearing also? That's only 2mm per side. They should put an o-ring groove in and you could just add a couple o-rings then for the 44 and take them out for the 40.
Matt
mattre69 is offline
post #10 of 32 Old March 25th, 2017, 06:01 PM
Denver's Avatar
First Name: Denver
Member #41951
Waste of grease that way?
pfd1980 likes this.
Denver is offline
post #11 of 32 Old March 25th, 2017, 06:15 PM Thread Starter
mattre69's Avatar
First Name: Matt
Member #32732
Yeah, maybe a tiny bit in the 2mm gap between the main groove and the o-rings, but that wouldn't be much I would think. I assume that since there's no o-rings in the Holy that it must be a very close fit to the bearing so that it doesn't let the grease out between the greaser and the inner race? Does anyone ever have trouble getting the greaser in the races?
Matt
mattre69 is offline
post #12 of 32 Old March 26th, 2017, 06:31 AM
tattoo305's Avatar
First Name: Dave
My RZR: 900s
Member #62148
View tattoo305's Photo Gallery(0)
Using an o ring would be very messy. I have both greasers. Believe me spend the extra $40. They are well worth it. Your bearings will thank you.
warn winch, EMP Bash Bumper
tattoo305 is offline
post #13 of 32 Old March 26th, 2017, 08:05 AM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
Did you get the hub holder tool as well? what did you torque the axle nuts back down to?
Beanhead is offline
post #14 of 32 Old March 26th, 2017, 10:10 AM
gmiller0737's Avatar
First Name: Gordon
My RZR: 2012 RZR 570
Member #47617
View gmiller0737's Photo Gallery(0)
80 Foot Pounds is The Spec. On My 2012
gmiller0737 is offline
post #15 of 32 Old March 26th, 2017, 04:05 PM
Beanhead's Avatar
My RZR: 13 570 LE
Member #66022
Thanks gmiller0737.
Beanhead is offline
Tags
570 , bearings , grease , greaser , wheel
XP4 1000 Wheel Bearings RWTDCT General RZR Discussion 0 October 29th, 2016 12:16 PM
Wheel Bearings Jimmy Bigsky RZR XP Turbo 0 October 7th, 2016 10:07 AM
Wheel Bearings....new vs old part # vspec1 RZR XP 900 2 February 24th, 2016 07:02 PM
WTB Factory 2015 RZR 900 wheel MLESa7990 Want to Buy 0 December 8th, 2015 05:33 PM
