New Heat Shield. - Polaris RZR Forum - RZR Forums.net
RZR 4 Specific Discussion For all discussions about the four seater RZR 4 800!
post #1 of 16 Old January 24th, 2012, 08:41 PM Thread Starter
VegasRider's Avatar
First Name: Don
My RZR: 2010 RZR-4
Member #6607
View VegasRider's Photo Gallery(6)
New Heat Shield.
I wanted to try to do something to cut down on the amount of heat that comes into the bed. I tools some duct insulation and put it on the bottom of the bed. The insulation has a sticky back and I used some 3m contact spray as well. I will try it out this weekend and see how it does.
ID:	44176   Click image for larger version
Don
Las Vegas
2010 RZR-4
2008 Keystone Raptor 3712
VegasRider is offline
post #2 of 16 Old January 24th, 2012, 09:02 PM
nbomar's Avatar
First Name: Nick
My RZR: RG RZR4
Member #27641
View nbomar's Photo Gallery(0)
Re: New Heat Shield.
subscribed...
nbomar is offline
post #3 of 16 Old January 25th, 2012, 09:17 PM
Xtension's Avatar
My RZR: 2011 RZR 4
Member #30467
View Xtension's Photo Gallery(0)
Hope it works. I have melted a cooler on the passenger side over the exhaust. I wrapped the headers but have not had an opportunity to test it yet. It doesn't matter what speeds I run, it gets damned hot.
Xtension is offline
post #4 of 16 Old January 25th, 2012, 11:35 PM
Nightmare's Avatar
Member #18559
View Nightmare's Photo Gallery(0)
That first photo is a little hard to understand.
I assume you took off the bed and flipped it upside down, then put it back into roughly the same spot on the RZR.
I took several photos of my 2011 RZR4 when I make my cheapo Heat Shield. Do you care if I post the photos in here?
-Some people play hard to get, I play hard to want
Nightmare is offline
post #5 of 16 Old January 26th, 2012, 05:03 AM Thread Starter
VegasRider's Avatar
First Name: Don
My RZR: 2010 RZR-4
Member #6607
Nightmare, that first photo is the bed upside down. You can use themis you like . Will take a few more this weekend when I run it. Will let you all know howit goes.
Don
Las Vegas
2010 RZR-4
post #6 of 16 Old January 26th, 2012, 05:29 AM
Tiorum3's Avatar
First Name: Al
Member #10509
I know my bed can get pretty warm, but not hot enough to melt a cooler! I have a 2011 as well, I wonder why the difference. Hearing that scares me a little because I usually put a plastic gas can on that side of the bed on long rides...
Tiorum3 is offline
post #7 of 16 Old January 26th, 2012, 05:39 AM
sandjunkie's Avatar
First Name: Phil
My RZR: 2014 XP41K
Member #9682
View sandjunkie's Photo Gallery(4)
I just set my can on a peice of 3/8 plywood.
sandjunkie is offline
post #8 of 16 Old January 26th, 2012, 05:42 AM
Tiorum3's Avatar
First Name: Al
Member #10509
I love KISS solutions. Thanks I'll use that next time.
Tiorum3 is offline
post #9 of 16 Old January 26th, 2012, 07:10 AM
TennesseeRZR's Avatar
First Name: Pete
My RZR: 2011 800 RZR LE, 2014 Black Pearl XP 1K
Member #28240
View TennesseeRZR's Photo Gallery(0)
If that insulation stays on that would be quiet a bit simpler than my solution but if it don't work out. here is how I solved my heat problem. I've had it on since September I've been though a lot of mud and a lot of pressure washing since then and I had it off a few days ago and it seems to be holding up quiet well
https://www.rzrforums.net/rzr-s-speci...conquered.html
BTW: don't know what type of trails you ride (high speed or more rock crawler type) I've found that if I stay in low gear it keeps the clutches engaged when your off the throttle therefore keeping the air moving and blowing out a lot of that heat Don't know for sure but I think that is part of our heat problem
Hope That Helps
TennesseeRZR is offline
post #10 of 16 Old January 26th, 2012, 07:42 AM
MossLager's Avatar
Member #12471
View MossLager's Photo Gallery(8)
I got an RV vent cover...same material and stuck it to the bottom of my cooler. It does help but it still goes to water pretty quick.
2007 Rhino
2010 RZR-S
2013 XP
MossLager is offline
post #11 of 16 Old January 26th, 2012, 10:02 AM
Nightmare's Avatar
Member #18559
I had too much to say, so I just made my own thread in the Projects Forum.
You could easily add the wrap to an aluminum heat shield. It is probably overkill
https://www.rzrforums.net/projects-ho...tml#post855889
post #12 of 16 Old January 26th, 2012, 07:32 PM
whitlow33's Avatar
First Name: Justin
My RZR: 2012 Rzr 4 Robby Gordon Edition EPS
Member #30123
View whitlow33's Photo Gallery(0)
My rzr4 bed got extremely hot. Hot enough that it started melting my lock n ride cargo box. I bought the heat shield from UTV.com for $134 and it works like a charm. Problem solved.
whitlow33 is offline
post #13 of 16 Old January 26th, 2012, 09:07 PM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Feedback Score: 5 reviews
I've got the same thing WITHOUT the logo, under $10. Works great. No more oven in the bed. Just cold beers. :beer:
chipper is offline
post #14 of 16 Old January 28th, 2012, 08:42 AM
nbomar's Avatar
First Name: Nick
My RZR: RG RZR4
Member #27641
Care to share yours chipper? Under $10 sounds great. Mine hasn't melted anything but it gets crazy hot. I don't like touching the bed...
nbomar is offline
post #15 of 16 Old January 28th, 2012, 10:19 AM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
I actually made this in HVAC class one day being bored. It's just thin duct work, you can pick up a small piece at lowes under $10. The X bent into it just keeps it a little stiffer. I used tin snips to shape it up a little. It did great and no heat was in my box.
chipper is offline
Heat shield ? rusty richard General RZR Discussion 5 January 27th, 2012 06:49 AM
XP UTV inc Heat Shield NIB RazinHell Polaris RZR Parts For Sale 1 September 10th, 2011 06:36 AM
Heat shield exawatt Engine and Drivetrain 0 May 8th, 2011 08:20 PM
Heat Shield for '09 RZR firefighter Want to Buy 0 January 26th, 2009 12:56 PM
heat shield help mackeyj General RZR Discussion 4 August 18th, 2008 09:17 PM
