Vibration satv carrier bearing - Page 2 - Polaris RZR Forum - RZR Forums.net
RZR 4 900 Discuss the 2015+ Polaris RZR 4 900 EPS four-seater RZR here.
 11Likes
post #16 of 22 Old June 19th, 2019, 02:20 PM Thread Starter
Buffalobillcody's Avatar
Member #144321
View Buffalobillcody's Photo Gallery(0)
I just got in the all balls brand shafts. Pretty excited. Has weights welded to them, and they have grease zertz. The rhino shafts show no signs of balancing, and have no zertz.
Buffalobillcody is offline
post #17 of 22 Old June 19th, 2019, 07:57 PM
DogRunner2's Avatar
Member #137545
Re: Vibration satv carrier bearing
I just put in the All Balls driveline.Much smoother than stock and greasable ujoints.
2018 XP1K LE
DogRunner2 is offline
post #18 of 22 Old June 19th, 2019, 08:44 PM
Marco75's Avatar
First Name: Marc
My RZR: 2018 XP Turbo
Member #266924
View Marco75's Photo Gallery(0)
Tried the rubber gasket material between the bearing block and the frame, 2 layers 1/16 in thick, no change. Noise is still there at 30 mph and above.
rotech likes this.
2018 XP Turbo WE Velocity Blue
Marco75 is offline
post #19 of 22 Old June 23rd, 2019, 07:56 PM Thread Starter
Member #144321
Well, installed the all ball's shafts, and at first I was elated. No vibrations! But after a bit more driving, I'm getting some similar vibrations as before but drastically reduced. It been such a long process, I don't remember what stock felt like. Is there some vibration/noise when you left off the throttle above 25 ish?
post #20 of 22 Old June 23rd, 2019, 08:22 PM
Marco75's Avatar
First Name: Marc
Member #266924
At 25-30 mph it starts, sounds like rocks in the front diff. Under that speed, it goes away. Thinking about going back to the oem carrier bearing with the rubber isolator.
Marco75 is offline
post #21 of 22 Old June 23rd, 2019, 08:25 PM Thread Starter
Member #144321
The all balls shafts have that..and I've still got it.
Marco75 likes this.
post #22 of 22 Old August 13th, 2019, 05:11 PM Thread Starter
Member #144321
Just an update, after a few miles, and re greasing the shafts, the vibration has tamed to fairly quiet. I then replaced all wheel bearings and front end bushings, and I'm going to drive it like I stole it!
