Been dealing with this for a while. checked and cleaned grounds. I noticed when cranking the relays click on and off as do dash lights. yes I have a new battery. looking to see if there is a common short or open. if so location would be great. If I find a fix I will share I have noticed it is not on google anywhere and service manual is useless. a flow chart for 636 2 would be awesome
any updates on this? A friends machine started throwing this code yesterday. it started sputtering and died. we had difficulty starting then when it did start it idled fine, would sputter and die under throttle.
Has anyone solved the mystery of this code yet? I have tried everything and have failed. Even took it to the dealer and they couldnt find the problem. Help would greatly be appreciated.
