Changed Throttle Body Getting Code - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old July 16th, 2017, 11:36 PM Thread Starter
RZRRcr's Avatar
First Name: Willy
My RZR: 2016 RZR 1000S and Arctic Cat 700 Wildcat Trail
Member #125969
View RZRRcr's Photo Gallery(0)
I changed my Throttle Body and now getting a 520276 2 and 520276 12 codes, I think the Throttle Pedal and Throttle Body need adjusted. Anyone have this issue before? How did you resolve?
RZRRcr is offline
post #2 of 17 Old July 17th, 2017, 05:54 AM
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 1102cc 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Re: Changed Throttle Body Getting Code
Why did you replace the throttle body? They don't get adjusted and typically don't go bad. I have seen the pedals get dirty or worn causing issues on the drive by wire setups.
Ken R.
roguedriver is offline
post #3 of 17 Old July 17th, 2017, 06:33 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
Broke the connector that plugs onto it, on the TB. I put a TB from a 1000XP on it. I matched up the wiring etc but maybe need to put an XP tune in it.
RZRRcr is offline
post #4 of 17 Old July 27th, 2017, 08:05 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
Does anyone know how to adjust the Throttle Position Sensor on the XP1000 TB? I am getting , .80 out just .02 out of Spec. I am hoping it is not inside the Black Controller with the Connector on it. I am thinking of loosening that Box and see if I can make a change that way. I really don't want to play with the Butterfly Stop if I don't have too.
RZRRcr is offline
post #5 of 17 Old July 27th, 2017, 08:07 AM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Did you switch from the single throttle body intake manifold to the dual throttle body setup?
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #6 of 17 Old July 27th, 2017, 11:32 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
Yes, almost there just need to get the Output down a little, which is a TPS adjustment, the Older 800S had this adjustment. I read that ALBA was working on this at one time?
RZRRcr is offline
post #7 of 17 Old July 27th, 2017, 11:35 AM
AlbaNate's Avatar
Member #24131
We never did it, but I do have some insight. Did you change the ecu or harness? This is not a simple swap over. You can not just wire it up. Your stock ECU is not set up for dual throttle bodies and will not operate them correctly...
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
AlbaNate is offline
post #8 of 17 Old July 27th, 2017, 11:48 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
I moved Pin38 to 37 on Bank One to get the 5VDC Input. I have an XP Tune. Can't you pull 5 VDC from the TMAP to the TB? Everything I have checked they have the same ECU and Everything else. Same Wire Harness except for Pin 37 and 38. 1000S uses Pin38 3.3 VDC and XP Uses Pin37 5 VDC. Right now all I need is get the TPS adjusted and I am set.
RZRRcr is offline
post #9 of 17 Old July 27th, 2017, 11:50 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
Hopefully I will be able to beat some of those XP's to the first turn.
RZRRcr is offline
post #10 of 17 Old July 27th, 2017, 11:51 AM
AlbaNate's Avatar
Member #24131
Yes, they all use a 5 volt ref. You are using an XP1000 ECU? You can not adjust the TPS. It is adjusted through Digital Wrench only.
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
AlbaNate is offline
post #11 of 17 Old July 27th, 2017, 08:07 PM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
I am going to assume that only dealers can get Digital Wrench? The RZR 1000 S uses 3.3V, so do the 900's. So it sounds like I would have to go to the Dealer and have them Adjust it. I will poke around some more before I throw in the Towel and go to the Dealer (There is nothing wrong with my dealer, quite the oppisite). I appreciate your input. I will also be checking out your Web site, see what you guys have.
RZRRcr is offline
post #12 of 17 Old July 28th, 2017, 07:45 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
I think I found my problem with the Throttle Body(I got it Used). There is a middle gear shaft with a bad bushing on one end. It is a Plastic Bushing, I am going to put a good bushing in it and we will see. The rest of the shafts look OK.
RZRRcr is offline
post #13 of 17 Old August 8th, 2017, 02:01 PM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
Throttle Body turned out to be fine. Just had to make a couple adjustments.
I just have to find out what size resister to put on the 02 Sensor Connection then Final Tune. It sounds really good, I did'nt think it would make that much difference (Sound wise). I should have the final tune done tonight, let you know how much difference it makes (Power wise).
ID:	453729   Click image for larger version
RZRRcr is offline
post #14 of 17 Old August 30th, 2017, 08:40 AM Thread Starter
RZRRcr's Avatar
First Name: Willy
Member #125969
I have been running for a few weeks now and it is running great. Just ordered XP Cams should have them on next week for the last race of the Season. Does anyone with a BULLYDOG know what Throttle Percentage is at at:
1. Key on but not started for about 15 seconds?
2. Running at Idle?
I just want to make sure I have it set correct.
RZRRcr is offline
post #15 of 17 Old May 14th, 2018, 05:30 PM
marc.cormier82's Avatar
Member #252513
View marc.cormier82's Photo Gallery(0)
What all did you have to do to make this work
marc.cormier82 is offline
rzr 1000 seats charlie78 RZR 570 Specific Discussion 7 September 16th, 2016 06:11 AM
Bored throttle body or bullet throttle body homdaddy Want to Buy 0 September 12th, 2016 07:11 PM
Throttle body boots Craneman32 RZR XP 1000 1 April 11th, 2016 09:26 PM
XP1000 Throttle body and injectors Nitrodoctor Polaris RZR Parts For Sale 0 January 18th, 2016 09:56 PM
polaris 4014934 vane sensor new slumper1 Polaris RZR Parts For Sale 5 November 23rd, 2015 06:09 AM
