Timing chain tension - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old March 15th, 2017, 07:45 AM Thread Starter
Scott Heller's Avatar
First Name: Scott
My RZR: 1000 XP
Member #78463
View Scott Heller's Photo Gallery(0)
I installed the Sparks big bore kit and Sparks did the porting, cams and valves. My question is on the Sparks manual timing chain tensioner. How tight should it be set? If I turn it in just til it touches it seams to loose.
Scott Heller is offline
post #2 of 3 Old March 15th, 2017, 06:19 PM
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 1102cc 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Re: Timing chain tension
On the mechanicals, I like to go as far in as I can turn it with my fingers (until I can't turn it with fingers anymore) then a half to 3/4 turn more past that point. After adjusting, rotate the primary counter clockwise a couple of revolutions and make sure the chain is sitting good on the sprockets and not too sloppy.
Ken R.
roguedriver is offline
post #3 of 3 Old March 15th, 2017, 06:52 PM Thread Starter
First Name: Scott
My RZR: 1000 XP
Member #78463
Okay, Thanks! I'll try that and see what it looks like.
2017 XP1K Timing Chain Tensioner - I Think Polaris Fixed It! Sshsjd10 RZR XP 1000 89 September 28th, 2018 01:12 PM
Timing chain... ArkansasRZR RZR XP 900 4 March 7th, 2016 05:44 AM
Stretched timing chain??? Pipefitter RZR 900 Engine 10 January 17th, 2016 07:20 AM
