What Engine Oil? - Polaris RZR Forum - RZR Forums.net
post #1 of 47 Old October 12th, 2015, 06:25 AM Thread Starter
rynomx785's Avatar
First Name: Ryan
My RZR: 17 XP 4 Turbo
Member #61131
View rynomx785's Photo Gallery(0)
What Engine Oil?
What's everybody using?
I read something on Facebook claiming that the factory Polaris oil isn't good and can lead to premature failure. The guy that shared it claimed he got the write up from Alba's website and they recommended using Maxima 10W-40. Anybody know if there is any truth to that? I couldn't find anything on their site about it.
Getting ready to do my second oil change and want to get to the bottom of this.
rynomx785 is offline
post #2 of 47 Old October 12th, 2015, 06:32 AM
410Customs's Avatar
My RZR: 2014 XP1K, 2015 XP1K4, 2014 Ace
Member #70757
View 410Customs's Photo Gallery(0)
Re: What Engine Oil?
Polaris oil is fine its not going to kill your engine hahaha BUT its also overpriced for what is in the bottle
Many people here run Mobil 0-40 full synthetic and love it
But there are MANY oils that will work in your 4 stroke OHC engine
410Customs is offline
post #3 of 47 Old October 12th, 2015, 07:39 PM
sharprzr's Avatar
First Name: DENNIS
My RZR: TURBO XP1K & TURBO XP900
Member #23245
View sharprzr's Photo Gallery(0)
the polaris oil is junk.any synthetic oil from walmart is way better..i have buddies using mobil 1,rotella,amsoil,royal purple.in the turbo cars we use the mobil 1 5 40 diesel pickup oil..thats formulated for turbo applications ...all these oils stop the dry rattle..
sharprzr is offline
post #4 of 47 Old October 12th, 2015, 07:40 PM
sharprzr's Avatar
First Name: DENNIS
Member #23245
i also run the wix oil filters
sharprzr is offline
post #5 of 47 Old October 12th, 2015, 07:42 PM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
I like Joe Gibbs Racing Oil or Champion Oil ...
swingarm1 is offline
post #6 of 47 Old October 12th, 2015, 07:45 PM
sharprzr's Avatar
First Name: DENNIS
Member #23245
ive heard good things about joe gibbs
sharprzr is offline
post #7 of 47 Old October 12th, 2015, 08:25 PM
desertdog01's Avatar
My RZR: 2015 xp 1000 voodoo blue
Member #74627
View desertdog01's Photo Gallery(0)
Alba won't run popo oil in their engines they recommend the maxima, but also only use the popo oil in the front diff and trans/rear end they have an oil change kit on thier site.
too many mods, need more cash
Suspension by fineline,radio's by rugged, dragon fire harness's,full Mtx sound system , 30" light bars- fifty cal mount, baja design squadron pro's,axia alloys visors, bumpers, roof by popo, alba racing belt temp gauge,alba radius rods , alum. Lower doors, prp door bags, duel led whips,utv fan bypass 36"rear strobe lite bar, get outta the way horn seismic mirrors,pawltector brake,Nrg quick release with a momo steering wheel Polaris Spare tire mount,method 401 beadlocks,popo slip on,serius pro 2x3 leds w axia mounts Evo ecu,lowrance hds7 touch gps:
desertdog01 is offline
post #8 of 47 Old October 12th, 2015, 09:04 PM
Xp41thousand's Avatar
First Name: Andy
My RZR: 2015 xp4 1000 Rzr 170
Member #75804
View Xp41thousand's Photo Gallery(0)
Polaris RZR oil change kit (Get that Polaris oil out of your RZR).
Here's were alba states it's junk
I have only done one oil change on mine and used Polaris extreme duty oil just because that's recommended and haven't done my homework for next oil change. This thread should help..
Xp41thousand is offline
post #9 of 47 Old October 13th, 2015, 05:07 AM Thread Starter
rynomx785's Avatar
First Name: Ryan
Member #61131
Thanks guys. I am leaning towards Maxima SxS Synthetic 5w-50 but I will have to check out Joe Gibbs.
Do they make Mobile 1 in a 5w-50 or would I have to use 10w-50?
post #10 of 47 Old October 13th, 2015, 08:30 AM
410Customs's Avatar
Member #70757
post #11 of 47 Old October 13th, 2015, 08:57 AM Thread Starter
rynomx785's Avatar
First Name: Ryan
Member #61131
Originally Posted by 410Customs View Post
Mobil makes just about anything you can think up for oil
Mobil 1 5w50 (Case of 6 Quarts)
Thanks.
post #12 of 47 Old October 15th, 2015, 01:57 PM
Z15
Z15's Avatar
My RZR: 2018 S 900 EPS Black Pearl
Member #9114
View Z15's Photo Gallery(0)
AMSOIL Lookup Guides
Mike
2018 RZR S 900 EPS Black Pearl
Z15 is online now
post #13 of 47 Old October 16th, 2015, 09:05 PM Thread Starter
rynomx785's Avatar
First Name: Ryan
Member #61131
I ended up going with Mobil 1 4T 10W-40 because O'Reillys stocks it.
Opinions?
post #14 of 47 Old October 16th, 2015, 11:24 PM
BryanD's Avatar
Member #32985
View BryanD's Photo Gallery(0)
EVERY engine / build is unique. Do your homework, its WORTH the read, trust me. I can guarantee you will NOT think the same about OIL after reading!
Motor Oil 101 - Bob is the Oil Guy - Bob is the Oil Guy
With the Prostar motor and low pressure (tested and confirmed) at idle I gravitated towards Mobile 1 - 10/30 in the winter and Royal Purple XPR 20-50 (mandatory warm up), in the summer and 80+ degree ambient.
I have an XP900 buddies motor in pieces on my bench IMO due to low oil pressure at idle. On a hill climb, instant throttle release, and 0 (zero) oil pressure resulted in the hydraulic cam tensioner releasing and jumped timing. Broken timing gear, broken intake cam, bent valves, broken timing chain, stripped gears on crank, bearings, seals, gaskets, etc. = $1500 in parts alone!!! The Prostar motor has idle / oil-pressure issues, don't deny.
2012 XP4
Hybrid Z1 Swap
Big Chute Turbo, Vipec, etc.
Reno, NV.
BryanD is offline
post #15 of 47 Old October 17th, 2015, 06:41 AM Thread Starter
rynomx785's Avatar
First Name: Ryan
Member #61131
Have you confirmed low oil pressure at idle on multiple motors Bryan?
800s engine sucked in water (inside engine pictures attached) traut811 Engine and Drivetrain 2 September 13th, 2015 07:14 PM
Stock 2012 engine blown while hill climbing -repost from general engine forum OzXP900LE RZR 900 Engine 8 July 3rd, 2013 03:58 AM
Engine braking 'kicking out' as engine idles down on downhills? mthomson General RZR Discussion 31 June 25th, 2011 02:12 PM
HELP!!! Engine shuts off ... wait 10 minutes it goes again ... Honda RC51 engine twvette Engine and Drivetrain 19 December 23rd, 2010 07:54 AM
Need Help with Engine Diagnostics please(Engine Dying at start) tjmotors Engine and Drivetrain 12 March 18th, 2010 07:00 PM
