4 wheel driving not engaging XP1000 2015 - Polaris RZR Forum - RZR Forums.net
post #1 of 24 Old July 14th, 2015, 10:43 AM Thread Starter
kennyshoes's Avatar
First Name: Ken
My RZR: 2015 xp1000 voodoo blue
Member #46668
View kennyshoes's Photo Gallery(0)
I have a 2015 XP1000 voodoo blue that has 50hrs and the front differential will not engage in all wheel drive mode. I took it to the dealer where i purchased the RZR and they found plastic gear cage was broken in front differential. They replaced it (warranty from Polaris) and it still wont engage. The cluster shows emblem of 4wheel and the light is on the switch when i turn it on. The dealer doesnt seem to know what to do at this point?
I am looking for help
kennyshoes is offline
post #2 of 24 Old July 14th, 2015, 11:27 AM
zac692069's Avatar
My RZR: 2015 XP1K
Member #51483
View zac692069's Photo Gallery(0)
Re: 4 wheel driving not engaging XP1000 2015
Is it under warrenty? I would demand the dealer fix it if so. Some thigs you could check is the electrical plug that goes to the magnet in the front dif. Also verify the driveshaft going to the front dif is spinning when the rzr is rolling.
zac692069 is offline
post #3 of 24 Old July 14th, 2015, 11:53 AM
Work hard / Play harder
Drakku's Avatar
First Name: Josh
My RZR: 15 RZR4s 900 Red(SOLD) / 2014 RZR 800s /2017 RZR 1000
Member #80665
View Drakku's Photo Gallery(0)
I'm guessing you are testing this at low speeds or sitting still? AWD wont engage if your going over 35 MPH, you have to drop below that a good ways sometimes before it will take hold.
Drakku is offline
post #4 of 24 Old July 14th, 2015, 12:09 PM
deblas's Avatar
First Name: Steve
Member #33923
View deblas's Photo Gallery(0)
Kenny, curious to hear how you are testing the AWD?
The front drive should not engage unless the rears are slipping. It is not a true/locked 4WD system, it is more like an On-Demand system.
Also, if the engine speed is over 3100 rpm and the AWD switch is turned on, the AWD system will not activate until the engine speed is below that 3100 rpm.
There is also a dowel pin that have sheared off,on occasion, causing issues....I will look for that thread.
2014 XP4 1000 Titanium
deblas is offline
post #5 of 24 Old July 14th, 2015, 12:21 PM
deblas's Avatar
First Name: Steve
Member #33923
I was mistaken about that dowel....when it breaks, apparently AWD stays engaged.
https://www.rzrforums.net/rzr-xp-1000...aging-2wd.html
deblas is offline
post #6 of 24 Old July 14th, 2015, 04:45 PM
juswannabreaksumthin's Avatar
First Name: Jeff
Member #27110
View juswannabreaksumthin's Photo Gallery(0)
The truth is the AWD will actually engage at any MPH... but it will not engage until the tachometer reads below 3100 RPM.
juswannabreaksumthin is offline
post #7 of 24 Old July 14th, 2015, 05:26 PM Thread Starter
kennyshoes's Avatar
First Name: Ken
Member #46668
okay thank you
I will be checking all these things out
post #8 of 24 Old July 14th, 2015, 05:31 PM Thread Starter
kennyshoes's Avatar
First Name: Ken
Member #46668
I tested by hooking my wench from RZR up to my truck and on a dirt road and in reverse I switched on the AWD and gave it gas the back tires spinning and front did not...
I also tried accelerating on dirt and only fish tailed and front wheels did not spin...
post #9 of 24 Old July 14th, 2015, 05:33 PM Thread Starter
kennyshoes's Avatar
First Name: Ken
Member #46668
I will be checking this out
Thank you
post #10 of 24 Old July 14th, 2015, 05:35 PM Thread Starter
kennyshoes's Avatar
First Name: Ken
Member #46668
Thank you to all for your advice. I am working on it....
I am ready to ride.....
post #11 of 24 Old July 14th, 2015, 07:58 PM
deblas's Avatar
First Name: Steve
Member #33923
Kenny, a word of advice on the 1000s. The reverse chain in the tranny has proven to be somewhat fragile. I would suggest you not hammer on this car in reverse. I would hate to see you shred your reverse chain.
Sent from somewhere over there...
deblas is offline
post #12 of 24 Old July 28th, 2015, 02:54 AM
Mike75052's Avatar
Member #66619
View Mike75052's Photo Gallery(0)
Check the driveshaft at the Trans and see if you can rotate it by hand. If so, snorkel shaft is broken and that spins the front diff for engagement.
Mike75052 is offline
post #13 of 24 Old August 30th, 2015, 08:02 AM
teryn1's Avatar
First Name: Teryn
My RZR: 2014 XP 1000
Member #66408
View teryn1's Photo Gallery(0)
This is simply not true. AWD doesn't engage unless certain RPM and speeds are met.
teryn1 is offline
post #14 of 24 Old August 30th, 2015, 08:36 AM
First Name: Jeff
Member #27110
"Initially, the vehicle's electronic system will not enable the AWD until
the engine RPM is below 3100." The vehicles AWD electronic system is not monitoring the vehicles wheel speed.
post #15 of 24 Old August 31st, 2015, 03:01 PM
Radrob99's Avatar
First Name: Robert
My RZR: 2015 xp41k Vodoo Blue
Member #74640
View Radrob99's Photo Gallery(0)
What he said speed don't matter only rpm. your armature is probably bad in dif you can ohm test it.
Radrob99 is offline
2015 XP4 1000 Front end vibration + popping + engaging 4x4 NWGBULLIES Engine and Drivetrain 0 May 26th, 2015 07:28 AM
4 wheel drive not engaging? Tiorum3 General RZR Discussion 4 March 30th, 2011 07:03 PM
Diff lock isnt engaging my left front wheel? alaska General RZR Discussion 16 March 6th, 2011 06:10 PM
4 wheel drive engaging rzrhall Engine and Drivetrain 1 February 5th, 2011 06:06 PM
4 wheel drive no engaging. DenisonRZR Engine and Drivetrain 5 August 5th, 2010 07:13 PM
