4 wheel driving not engaging XP1000 2015 - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 24 Old September 21st, 2015, 08:43 AM
rzr nuts's Avatar
First Name: Travis
My RZR: 2013 900 xp, 2014 1k4
Member #63970
View rzr nuts's Photo Gallery(1)
Re: 4 wheel driving not engaging XP1000 2015
My rzr 1000 4 is doing the same thing. 4 wheel drive is not working. I just had Polaris install a brand new front diff. I have a lot of play in the front drive shaft i can turn halfway around by hand.
rzr nuts is offline
post #17 of 24 Old September 22nd, 2015, 09:43 AM
Radrob99's Avatar
First Name: Robert
My RZR: 2015 xp41k Vodoo Blue
Member #74640
View Radrob99's Photo Gallery(0)
Sound's like output shaft in tranny not the diff.
Radrob99 is offline
post #18 of 24 Old April 1st, 2016, 11:59 AM
Hecker's Avatar
My RZR: XPT
Member #91697
View Hecker's Photo Gallery(0)
Originally Posted by teryn1 View Post
Originally Posted by juswannabreaksumthin View Post
Originally Posted by Drakku View Post
AWD wont engage if your going over 35 MPH, you have to drop below that a good ways sometimes before it will take hold.
The truth is the AWD will actually engage at any MPH... but it will not engage until the tachometer reads below 3100 RPM.
This is simply not true. AWD doesn't engage unless certain RPM and speeds are met.
Ok I had that clanking noise in my rzr at about 6.5 months and I took it to the dealer and they said the bearing broke free an tore the front diff up. Luckily my RPM1 extended warranty covered everything. However when i asked if the 4wd drive should engage while driving the dealer that my 2015 RZR 1000 only goes into 4wd if i stop the machine.
Does anyone have any insight on this?
I have a cf moto 800 ex for friends to ride and it goes right in while moving... this makes it nice when wanting/needing to switch from 2wd->4wd and back to accommodate different terrains to get the best time on my course.
Hecker is offline
post #19 of 24 Old April 1st, 2016, 01:08 PM
juswannabreaksumthin's Avatar
First Name: Jeff
Member #27110
View juswannabreaksumthin's Photo Gallery(0)
The Dealers and the Owners should open up the Owner's Manual and read it...
juswannabreaksumthin is offline
post #20 of 24 Old December 3rd, 2016, 08:26 PM
buggy2015's Avatar
Member #171457
View buggy2015's Photo Gallery(0)
2015 polaris rzr 1000XP won't go in awd light is coming on the switch but not on the dash and no play in drive shaft
buggy2015 is offline
post #21 of 24 Old December 15th, 2016, 05:08 AM
kezell17's Avatar
My RZR: 2014 RZR 800 XC
Member #62297
View kezell17's Photo Gallery(0)
Try these two test and see. If you still don't have it working let me know and I try to help.
2017 HL Blue 1000XP
2014 RZR 800 XC w/S-conversion - gone
www.youtube.com/kevinezell
Last edited by kezell17; December 15th, 2016 at 05:10 AM. Reason: Trying to add attachment
kezell17 is offline
post #22 of 24 Old December 15th, 2016, 02:49 PM
buggy2015's Avatar
Member #171457
Took it to the dealer re flashed the ecu awd working still don't find throttle response not like was
post #23 of 24 Old July 2nd, 2017, 02:40 PM
colerlone's Avatar
Member #205729
View colerlone's Photo Gallery(0)
I just got a 15 xp 1000 and I'm having the same issue. The drive shaft is going to the front diff but not engaging. It's getting 12 volts to the plug
colerlone is offline
post #24 of 24 Old July 9th, 2017, 07:35 AM
bluetoad7's Avatar
First Name: Ron
My RZR: 2017 XP 1000 Gold Matte Metallic Rock Crawler Edition
Member #19658
View bluetoad7's Photo Gallery(0)
This probably won't apply to the original poster, but dirty fluid will also cause the front differential to not engage. To be certain, you can engage (flip the switch) AWD at any speed. The icon will not display nor will the AWD actually start to function until the engine speed drops below 3100 rpm or so. I have had my old 800 front diff apart, inspected it and found nothing wrong, save dirty fluid. Fresh Polaris fluid fixed it. This is the one location that aftermarket fluids usually will not work. I believe the armature which is actually an electronically engaged magnet will not function correctly with non-spec oils.
Many other options available for tranny, rear diff, transfer case and transmission oil. To test the AWD function, use a floor jack with wheels to elevate the rear wheels off the cement floor. Get in and put it in gear with switch engaged and the front wheels should pull you across the garage floor, if functioning correctly.
Da Blue Toad
bluetoad7 is offline
2015 XP4 1000 Front end vibration + popping + engaging 4x4 NWGBULLIES Engine and Drivetrain 0 May 26th, 2015 07:28 AM
4 wheel drive not engaging? Tiorum3 General RZR Discussion 4 March 30th, 2011 07:03 PM
Diff lock isnt engaging my left front wheel? alaska General RZR Discussion 16 March 6th, 2011 06:10 PM
4 wheel drive engaging rzrhall Engine and Drivetrain 1 February 5th, 2011 06:06 PM
4 wheel drive no engaging. DenisonRZR Engine and Drivetrain 5 August 5th, 2010 07:13 PM
