2015 HIGH LIFTER Problem / issue, Please Help! - Polaris RZR Forum - RZR Forums.net
post #1 of 22 Old October 31st, 2014, 11:07 PM Thread Starter
Julius High Lifter's Avatar
Member #73999
View Julius High Lifter's Photo Gallery(0)
Hello, I am new to this RZR forums and I am trying to find some help to solve my issue.
I have a 2015 Highlifter with only 50 miles; I am in the break-in process and have used it without engaging full throttle. After riding in dirt, mud and sand the first 40 miles at low speeds sometimes in L and sometimes in H, the high temperature light is turning on (at 231 degrees). The light goes off after stoping for a while so it cools down or just by going with very little throttle. The fan comes on at 205 degrees.
I have washed it completely, cleaned air filter, checked coolant level, cleaned radiator, even changed the engine oil for the first time and the oil filter because I thought that might be the problem but it was not. I even drove it in the street for 10 miles to see if in normal conditions it would get hot, and it did. The temperature has gone up to 237 degrees and the motor loses power completely. Everything else seems to be normal but I am frustrated that I can not ride for more than 15 minutes when it gets the light again.
Any experiences with this? Your help will be highly appreciated.
Thank you.
Julius High Lifter is offline
post #2 of 22 Old November 1st, 2014, 03:28 AM
orangetc's Avatar
My RZR: 2019 Dynamix Turbo
Member #20195
View orangetc's Photo Gallery(0)
Re: 2015 HIGH LIFTER Problem / issue, Please Help!
Sounds like you may have some air trapped in the coolant system, there is a bleed screw above the oil filter, near the exhaust. On level ground open that screw till only coolant is flowing out of it.
2019 Dynamic 4 Turbo
Sold-2015 Highlifter
You don't have to out run the bear just who you are with !!!
orangetc is offline
post #3 of 22 Old November 1st, 2014, 04:31 AM
dak
dak's Avatar
My RZR: 2017 XP Turbo
Member #50509
View dak's Photo Gallery(0)
It wont take long running up to 231 degrees to ruin that motor, so first off stop doing that. You have a flow problem. Could be air as mentioned above, could be thermostat, could be water pump. All are pretty easy to confirm. In a brand new machine you could also have foreign material blocking a passage, not so easy to confrim. But a new machine with warranty needs to back to the dealer to be fixed and documented. Good luck.
dak is offline
post #4 of 22 Old November 1st, 2014, 05:53 AM
410Customs's Avatar
My RZR: 2014 XP1K, 2015 XP1K4, 2014 Ace
Member #70757
View 410Customs's Photo Gallery(0)
I agree you need to burp the system first. These XP's run right around 180-200 degrees from what I have seen. 230 is HOT and if it is happening that quickly you either have air in system or a thermostat issue
Since we know these cooling systems can be tough to burp I would start there! If it doesnt fix it take to dealer
410Customs is offline
post #5 of 22 Old November 1st, 2014, 05:53 AM
TravisTr's Avatar
First Name: Travis
My RZR: 15' RZR Xp1k
Member #70208
View TravisTr's Photo Gallery(0)
Just to clarify for my personal records, Isn't the break-in process 50 hours? 50 miles doesn't take long at all. Def bring that sucker back to the dealership and I don't advise telling them anything about you messing with it. Get this problem resolved with them before starting your normal servicing. That be my suggestion with a brand spanking new machine, especially a first year production with Mud models. Nobody knows what they can come up with, best of luck brutha!
TravisTr is offline
post #6 of 22 Old November 1st, 2014, 06:11 AM
broken-01's Avatar
My RZR: rzr xp le and jagged x
Member #64071
View broken-01's Photo Gallery(4)
Most break in's for atv/sxs is 10hrs on the motor. Belts are 50miles I believe. As for the overheating issue I agree with the consensuss that you most likely need the cooling system bleed. That will cause your symptom so will blocked thermostate or debris as mentioned above. Now should you do it? Its an easy process but your dabbiling in causing future warrinty issues if the dealer notes serviced by customer. Good luck
Sent from my SCH-S720C using RZRForums.net mobile app
broken-01 is offline
post #7 of 22 Old November 1st, 2014, 06:14 AM
410Customs's Avatar
Member #70757
Did you wash the mud from your radiator? Is the fan kicking on at 180 (I think its 180)?
post #8 of 22 Old November 1st, 2014, 07:06 AM
the_worm_'s Avatar
My RZR: XP1K
Member #61055
View the_worm_'s Photo Gallery(0)
Should be kicking on between 200-205
the_worm_ is offline
post #9 of 22 Old November 1st, 2014, 10:13 AM
broken-01's Avatar
Member #64071
For what its worth there is a thread "cooking thermostates" said that his failed the thermos every time it passed 230° so might be somthing else to check.
post #10 of 22 Old November 1st, 2014, 10:21 AM
Jadan26's Avatar
My RZR: rzr xp le 900
Member #24158
View Jadan26's Photo Gallery(0)
If you open the bleed screw above headers to try and burp air out its an 8mm probably little green screw. Also the radiator cap has to be off and machine should be cool.
Popo lnr box, half windshield, roof.. TS revolver seats.. Futv skid, sliders, a arm guards.. 26 sand blasters and smoothies.. Dfr harnesses.. Tribalwhips lighted whip and 30" led bar.. Ez steer PS.. Highlifter radius rods.. Utv inc gussets, trailing arm sliders, heat shield, billet mirror, snatches, seat lowering bases... Emp modified parking brake.. Pro armor doors and graphics..Dg cage..Pep utv shocks..holz motor mounts..
Jadan26 is offline
post #11 of 22 Old November 2nd, 2014, 05:26 AM Thread Starter
Member #73999
Hello, i bled the coolant by unscrewing the 8mm screw above the headers; It took the air out, put the screw again and filled the front reservoir with more coolant. I tried it out this morning for 10 minutes and temperatures went up to 215. I did not have more time to try it more, but I think I still have the issue. do you guys know what is the normal operating temperature on the high lifter? I bought this vehicle from a dealer in virginia and brought it down to central america, so the official dealer/service is not that reliable. The radiator was washed, and the air filter cleaned as well. I am not getting the check engine light either, so I do not think is an engine problem. Any other suggestions? I also have a 900xp and never had this issue in the past. Thank you, all of your help is highly appreciated.
post #12 of 22 Old November 2nd, 2014, 05:40 AM
Misdirected's Avatar
First Name: Michael
My RZR: 2014 RZR XP1K "Black Pearl"
Member #63857
View Misdirected's Photo Gallery(0)
Since u are sol on warranty. I would check the thermostat as said above. It may be stuck closed. You can look on YouTube and find videos on how to check a thermostat using a pan and some water on the stove and see if it opens at proper temp.the opening temp should be stated on the thermo it self. Let us know
Misdirected is offline
post #13 of 22 Old November 2nd, 2014, 08:02 AM
Toro's Avatar
First Name: BMoney
My RZR: High Lifter RZR 1K
Member #69498
View Toro's Photo Gallery(0)
the thermostat is mechanical so they almost never go bad. I myself have never seen one go bad. There are many other things that can be happening. For example he could have already blown his top or bottom gasket which is causing back pressure. He could have a bad Rad cap causing bad pressure in the cooling system. His pump could have also gone bad.
Toro is offline
post #14 of 22 Old November 2nd, 2014, 06:22 PM
First Name: Michael
Member #63857
Not to get into a pissing contest but yes they go bad they stick open or closed. IMO
post #15 of 22 Old November 2nd, 2014, 06:58 PM
broken-01's Avatar
Member #64071
Thermo's do go bad.
Tags
high lifter problem issue
2015 RZR-1000 High Lifter edition Tuf-Skin RZR XP 1000 2305 September 25th, 2016 02:40 PM
Built For The Mud - 2015 RZR XP 1000 High Lifter Edition 4Nines Muddin' 0 October 20th, 2014 11:18 AM
high lifter xp got to see dkrajcovic RZR and UTV Video's 0 June 30th, 2014 04:40 PM
570 High Lifter butch2000 RZR 570 Specific Discussion 7 October 23rd, 2013 07:54 PM
