2015 HIGH LIFTER Problem / issue, Please Help! - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 22 Old November 2nd, 2014, 08:08 PM
Toro's Avatar
First Name: BMoney
My RZR: High Lifter RZR 1K
Member #69498
View Toro's Photo Gallery(0)
Re: 2015 HIGH LIFTER Problem / issue, Please Help!
yes yes, they do go bad. But its very rear that a new machine has a bad one. simple check (new one is like $40), he will let us know. Lucky the thermostat on these are ez to get to. The OP also clearly states we has already had it over heat, it only takes 1 time.
also if its stuck open that that is not an issue bc the problem he would have would the engine running like shit bc it can't get to a good running temp. OR if its stuck closed all of his fluid would get stuck in the over flow and if he takes the cap off and get its to temp it will boil out bc it can't flow (also this can be caused bc of a blown gasket)
Toro is offline
post #17 of 22 Old November 3rd, 2014, 12:19 AM
TravisTr's Avatar
First Name: Travis
My RZR: 15' RZR Xp1k
Member #70208
View TravisTr's Photo Gallery(0)
Keep us posted OP, quite a bit willing to help here.... Great place to discuss.....
TravisTr is offline
post #18 of 22 Old November 3rd, 2014, 06:16 AM Thread Starter
Julius High Lifter's Avatar
Member #73999
View Julius High Lifter's Photo Gallery(0)
Thank you all.
I will have the local dealer take a look at the thermostat, maybe I will just buy a new one, replace it and see what happens. Where is the thermostat located? Any one can recommend on what order of things/ order of procedure to sort this problem out? I will keep you post it.
Julius High Lifter is offline
post #19 of 22 Old November 3rd, 2014, 08:05 AM
410Customs's Avatar
My RZR: 2014 XP1K, 2015 XP1K4, 2014 Ace
Member #70757
View 410Customs's Photo Gallery(0)
I would let dealer handle thermostat R&R just in case they can deny your warranty of you mess with it first.
410Customs is offline
post #20 of 22 Old November 3rd, 2014, 08:21 AM
broken-01's Avatar
My RZR: rzr xp le and jagged x
Member #64071
View broken-01's Photo Gallery(4)
Originally Posted by Julius High Lifter View Post
Thank you all.
Right under the throttle body on 900 probably the same on 1k. I agree with 410 customs let a dealer check it. Reason is warrinty and your not the only one haveing that issue with the new 1k.
Sent from my SCH-S720C using RZRForums.net mobile app
broken-01 is offline
post #21 of 22 Old November 3rd, 2014, 08:26 AM
z06jones's Avatar
My RZR: 2012 XP900, 2014 XP1K, 2016 XPT
Member #4041
View z06jones's Photo Gallery(0)
After bleeding air you need to add water/antifreeze to the radiator (which is a pain to get to) and you may have to bleed it more than once.
Hello, i bled the coolant by unscrewing the 8mm screw above the headers; It took the air out, put the screw again and filled the front reservoir with more coolant. I tried it out this morning for 10 minutes and temperatures went up to 215. I did not have more time to try it more, but I think I still have the issue. do you guys know what is the normal operating temperature on the high lifter? I bought this vehicle from a dealer in virginia and brought it down to central america, so the official dealer/service is not that reliable. The radiator was washed, and the air filter cleaned as well. I am not getting the check engine light either, so I do not think is an engine problem. Any other suggestions? I also have a 900xp and never had this issue in the past. Thank you, all of your help is highly appreciated.
z06jones is offline
post #22 of 22 Old December 1st, 2014, 09:55 AM
KyRo's Avatar
First Name: Carlos
Member #57412
View KyRo's Photo Gallery(0)
try to touch radiator when red light comes on, or better, try to put some fresh water over the radiator. if radiator is cold, thermostat goes bad...
07 Suzuki LTR
08 KTM Exc 125
Spanish Blog about Rzr -->http://blogpolarisrzr.blogspot.com.es/
Facebook Page: https://www.facebook.com/polarisrzresp
KyRo is offline
Tags
high lifter problem issue
2015 RZR-1000 High Lifter edition Tuf-Skin RZR XP 1000 2305 September 25th, 2016 02:40 PM
Built For The Mud - 2015 RZR XP 1000 High Lifter Edition 4Nines Muddin' 0 October 20th, 2014 11:18 AM
high lifter xp got to see dkrajcovic RZR and UTV Video's 0 June 30th, 2014 04:40 PM
570 High Lifter butch2000 RZR 570 Specific Discussion 7 October 23rd, 2013 07:54 PM
