Manual Timing Chain Tensioners (and Prices) - Page 3 - Polaris RZR Forum - RZR Forums.net
post #31 of 44 Old April 9th, 2015, 08:26 PM
deblas's Avatar
First Name: Steve
Member #33923
View deblas's Photo Gallery(0)
Re: Manual Timing Chain Tensioners (and Prices)
This has been beat to death!
When the tensioner looses its prime, it collapses until oil pressure builds up.
Not all cars experience the same level of cold start noise, but for those that do, it's nerve racking as hell.
To say there is no issue with the Polaris tensioners that exhibit this....that is just plain silly.
I don't think a philosophical debate on oils and/or additives is required in this thread.
I have successfully installed a manual tensioner in my car and it's been flawless for over 1000 miles.
I've done my homework and to 100% guarantee I won't have a tensioner failure, a mechanical tensioner was the answer.
This problem is not unique to Polaris and doing some homework will tell you that.
Good luck to all of you that have this issue.
Sent from somewhere over there...
2014 XP4 1000 Titanium
deblas is offline
post #32 of 44 Old April 10th, 2015, 05:11 AM
1bacamaro's Avatar
First Name: Jeff
My RZR: 2015 Rzr 1000xp
Member #63815
View 1bacamaro's Photo Gallery(0)
Just because YOUR Rzr doesn't have the problem doesn't mean it's not a issue. To get on here and call everyone uneducated just makes u look like a a$$ and uneducated. My 2010 Camaro doesn't have the key fob problem that Chevy had but that doesn't mean its not a problem.
1bacamaro is offline
post #33 of 44 Old April 10th, 2015, 05:36 AM
410Customs's Avatar
My RZR: 2014 XP1K, 2015 XP1K4, 2014 Ace
Member #70757
View 410Customs's Photo Gallery(0)
BINGO!! There is a problem with these cars, I own two of them and they both do it.
I am a mechanic, not only am I a mechanic I am a Ford mechanic, which means I work on (or avoid like hell) the SOHC 4.0L V6. This engine was developed on top of an existing pushrod engine. It uses a front and rear timing chains with hydraulic tensioners. It is a great engine! It has the potential to last 300K miles +! Except none of them ever barely make it to 200K because......dun dun da the TIMING CHAIN TENSIONERS fail... exploding the nylon guides into the engine, piston slaps into the valves, and totally destroying the vavletrain! Hooray thanks Ford! These suckers were recalled in 1997 to fix, and eventually (by 2004) they had it figured out. Figured out means the engines might make it to 200K with the updated Ford timing chain tensioners and guides. The SOHC 4.0L is a good engine, but if you don't address the timing chain tensioner issue when it first shows its head (around 140-170K miles) then its only a matter of time....tick tick tick tick like a bomb. The old version of the 4.0L, the OHV 4.0L "pushrod" before this engine, well we have one in our fleet with 373K miles, one with 325K miles, and other high miles versions also. A SOHC engine will not go this far without being pulled and having its timing "cassettes" and tensioners replaced. The OHV and SOHC 4.0L have the same bottom end.....
I will be putting upgraded tensioners in our xp1000's
To say "there is no problem" or "the noise is normal"...well sounds just like a compartmentalized sales pitch from the dealer
410Customs is offline
post #34 of 44 Old April 16th, 2015, 09:15 PM
Empire Industries's Avatar
First Name: Eric
Member #6961
View Empire Industries's Photo Gallery(0)
Empire Industries Manually ratcheting style timing chain tensioner .Hexagon shape allows for easy tightening into cylinder Priced right at $169.95
951 734 7433
Empire Industries is offline
post #35 of 44 Old June 9th, 2015, 07:30 AM
therealquinny's Avatar
First Name: Justin Quinn
My RZR: 2014 rzr xp1000 racecar and play car
Member #62005
View therealquinny's Photo Gallery(0)
We installed a weller racing tensioner on our racecar, all issues were gone, I strongly believe they have the best set up when it comes to how they're built, check them out on their website
therealquinny is offline
post #36 of 44 Old June 9th, 2015, 08:03 AM
Member #62005
https://www.wellerracing.com/HD-Auto...00_p_3052.html
Here's the link, we like it because it keeps the stock oiling property's!
post #37 of 44 Old June 9th, 2015, 06:34 PM
deblas's Avatar
First Name: Steve
Member #33923
Originally Posted by psheadl View Post
Some rattle and some don't. Anyone tried this on one that has a bad startup rattle? Maybe just needs a prime...
https://www.youtube.com/watch?featur...&v=JVTb06h5JCU
That's a good video explaining what happens when a tensioner looses its prime.
deblas is offline
post #38 of 44 Old June 10th, 2015, 08:08 AM
Product Tester
Idaho-RZR's Avatar
First Name: Gary
My RZR: 2016 Xp Turbo
Member #8633
Feedback Score: 4 reviews
View Idaho-RZR's Photo Gallery(0)
Some of the manual tensioners are having issues. In both cases the chain was kinked.This causes the chain to skip timing and bend valves.
I have 2 friends this has happened to in the last 3 weeks. I am taking my manual tensioner out for now until they figure it out.
The Polaris chains are failing and are on national backorder. Polaris is aware of the situation and once again is doing nothing about it.
2006 Ranger 700-SOLD
2008 RZR 800-SOLD
2011 RZR XP900-SOLD
2014 RZR XP1000-SOLD
2015 RZR 900S-SOLD
2016 RZR XP Turbo- Wife's
2017 RZR4 900-So the dog can go too.
2018 Brand X
Idaho-RZR is offline
post #39 of 44 Old June 10th, 2015, 09:00 AM
deblas's Avatar
First Name: Steve
Member #33923
Am I missing something here??? How is the tensioner the cause for failure, unless installed incorrectly?
How is the tensioner causing a chain to kink? Please enlighten as to how this wass determined?
You have 2 friends with the exact same problem, happening within 3 weeks of each other....talk about coincidence....does it happen to be the same guy installing these manual tensioners on your friends cars?
Did an interweb search as well, I can find absolutely nothing as it relates to the actual timing chain failing....not sure if the "problem" is as wide spread as you indicate. Maybe your 2 buddies are just lucky enough to be on the tip of the spear......
deblas is offline
post #40 of 44 Old June 10th, 2015, 09:46 AM
1bacamaro's Avatar
First Name: Jeff
Member #63815
My chain broke because I got the tensioner to tight. The reason I got it to tight was because the threads fit so tight. I couldn't turn it by hand. At this point I had no clue if I was hitting the the the chain or not. I pulled the motor replaced the chain and then went to this new Yamaha style tensioner. To me it's better because it takes the guess work out of it.
post #41 of 44 Old June 10th, 2015, 10:26 AM
rzr4hank's Avatar
First Name: Alex
My RZR: 2014 RZR4-900
Member #61009
View rzr4hank's Photo Gallery(0)
I can see if you get the manual tensioner too tight you can stretch or break a chain. Get it too loose and you can jump a tooth or two. Both conditions have bad consequences. Then add time and wear and the manual tensioner needs to be adjusted or again you could jump a tooth or two. Add thermal effects of the difference in thermal expansion rates of aluminum and steel (aluminum is about 2X steel). Set the manual tensioner at ambient temperature and as the engine heats up the chain gets tighter. Haven't done it but I'd consider adjusting the manual tensioner with engine at temperature and running. Use sound as the adjusting factor.
The hydraulic tensioner is a compromise and works off oil pressure. Use the wrong oil viscosity and your tensioner force is different. Use the wrong oil filter without an oil drain back feature and you do dry starts. That means the chain is loose on startup and rattles until you get oil pressure. BTW everything else moving in the engine is dry too. So I'd recommend at least using factory equivalent specified oil and filter. Polaris has done significant engineering and durability testing to find the best combination.
Pick your poison (manual or hydraulic), there is no free lunch.
Well said.
Alex
rzr4hank is offline
post #42 of 44 Old June 10th, 2015, 08:54 PM
Product Tester
Idaho-RZR's Avatar
First Name: Gary
Member #8633
The chains come out kinked with two different brand tensioners. With the stock tensioner the chain is not kinking. Pretty hard to install wrong. That's the question exactly, how is the tensioner causing the chain to kink? Both guys live in different states. There is no discussion yet on this but it will come to light soon. I'm taking mine out. You leave yours in. You might be missing something.
2008 RZR 800-SOLD
2011 RZR XP900-SOLD
2015 RZR 900S-SOLD
2018 Brand X
post #43 of 44 Old June 24th, 2015, 06:40 PM
White Lightening's Avatar
First Name: Brian
My RZR: 2014 XP1K
Member #81868
View White Lightening's Photo Gallery(0)
First off I would really reccoment buying a factory service manual.
Next buy the Boondocker tentioner, it's $200,00 but thats a lot cheaper than
bent valves, let alone missing out on a weekend of fun because you jumped your cam chain. It's fully automatic so you dont have to mess with adjusting it. Iv'e been running one since my XP1000 was new with no issues.
White Lightening is offline
post #44 of 44 Old June 24th, 2015, 06:46 PM
First Name: Brian
My RZR: 2014 XP1K
Member #81868
Originally Posted by gonedunnin View Post
Can anyone explain the process and precautions for installation if I purchase one of these manual timing tensioners?
Buy a factory service manual then buy a Boondocker tensioner, Problem solved.
The manual will tell you how to install it. Then go out and have fun.
K&T Timing Chain Tensioner tshot27 General RZR Discussion 1 December 28th, 2013 02:41 PM
Manual timing chain tensioner or? ErosionDrifter RZR 900 Engine 1 August 13th, 2013 08:25 AM
Manual cam chain tensioners... roguedriver RZR 900 Engine 0 July 19th, 2013 12:59 PM
Timing chain jumped. sandfreak RZR 900 Engine 10 November 9th, 2012 03:57 PM
how to replace a timing chain? atvxtreme RZR XP 900 32 December 14th, 2011 07:13 AM
