Real World Exhaust Testing - Polaris RZR Forum - RZR Forums.net
post #1 of 53 Old June 1st, 2014, 02:59 PM Thread Starter
CB-BLR's Avatar
Member #45144
View CB-BLR's Photo Gallery(0)
I wanted to report on the real world pipe testing I have been doing.
Stock
HMF
Muzzy
Sparks Racing
Car setup: R&R cage, 30x10x14 STI Rocktane tires, STI beadlocks, DirtyDawg clutch kit, ignition by Chris @ Benchmark Performance (raises rev limit to 9500 & top speed to 95 mph), Dobec Auto tune with cruise set at 13.5 and WOT set at 13.0 on the AFR . I clutched all of them to turn a max rpm of 8350-8400
I test these pipes using an analog tach, and two GPS speedo's at a steady uphill grade near my house in rural Washington. I have painted marks on the road at 1/4 mile and 1/2 mile.
I don't have a lot of time to go into detail at the moment...so I will just post the top speeds at the 1/2 mile.
1/2 Mile speeds via GPS:
Stock = 70-71 mph
HMF = 70-71 mph - pulls harder than stock on the bottom end - crisper throttle response
Muzzy = 69-70 mph - pulls harder than stock on the bottom, but seems to flatten out on the top end
Sparks Racing = 73-74 mph. - Pulls harder everywhere.
Of note is the fact that I tested the Muzzy back to back with the Sparks pipe. With the same clutch weight, the Muzzy pulled 8350 rpm, and the Sparks pipe did 8550 rpm at 73 mph. When I added some tip weight to the clutch arms to bring the rpm down, the Sparks pipe pulled harder, and came up in speed at the 1/4 and 1/2 mile marks.
I am not associated with any of these manufacturers.
Chris
CB-BLR is offline
post #2 of 53 Old June 1st, 2014, 03:13 PM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
Re: Real World Exhaust Testing
Sparks makes some AZZ KIcking Engine Parts...
They also built a "MEAN AZZ" BITD Engine for Justin Lambert (owner of Cognito Motor Sports) he just won the Silver State 300 with his New Sparks Powered XP 4 1000...
swingarm1 is offline
post #3 of 53 Old June 1st, 2014, 07:24 PM
JT1KXP4's Avatar
My RZR: '14 1000 XP4
Member #67847
View JT1KXP4's Photo Gallery(0)
What happened to the original "real world exhaust testing" thread?
JT1KXP4 is offline
post #4 of 53 Old June 2nd, 2014, 09:37 PM
Empire Industries's Avatar
First Name: Eric
Member #6961
View Empire Industries's Photo Gallery(0)
Which Sparks system did you test? Slip on or full system? What was the AFR while you were testing? Did you have to do some tuning to keep the AFR consistent?
Empire Industries is offline
post #5 of 53 Old June 2nd, 2014, 09:56 PM
fuelcustoms's Avatar
Member #13411
View fuelcustoms's Photo Gallery(0)
good questions empire.
fuelcustoms is offline
post #6 of 53 Old June 2nd, 2014, 11:02 PM Thread Starter
CB-BLR's Avatar
Member #45144
Sparks full system
As stated in my post...Dobec Auto tune controller with cruise set at 13.5 AFR and WOT set at 13 AFR
Chris
P.S. You can now buy just the front end of this system to retrofit onto the existing Sparks mufflers. This consists of a header and new mid pipe to hook into the mufflers.
CB-BLR is offline
post #7 of 53 Old June 3rd, 2014, 05:02 AM
the_worm_'s Avatar
My RZR: XP1K
Member #61055
View the_worm_'s Photo Gallery(0)
So you can just get the header now instead of having to buy the full system if you already have the slip on?
the_worm_ is offline
post #8 of 53 Old June 3rd, 2014, 07:52 AM Thread Starter
CB-BLR's Avatar
Member #45144
Yes... it comes with header and new mid-pipe... which does away with factory donut gasket... You can buy this separately if you already have the slip-ons.
Sent from my Android Smartphone
CB-BLR is offline
post #9 of 53 Old June 3rd, 2014, 07:57 AM
the_worm_'s Avatar
My RZR: XP1K
Member #61055
Interesting thanks for the info
post #10 of 53 Old June 3rd, 2014, 08:09 AM
proshop's Avatar
My RZR: xp 1k 1065
Member #15198
View proshop's Photo Gallery(0)
we found the same results on the dyno and the desert/dunes.
proshop is offline
post #11 of 53 Old June 3rd, 2014, 03:57 PM
oufreud's Avatar
First Name: Philip
My RZR: 2014 RZR XP1000 Black Pearl
Member #13358
View oufreud's Photo Gallery(3)
Been looking at exhaust, looks like I'm going with sparks. Do you have any video of the sparks? Just didn't really want to deal with repacking the cans but I've always liked sparks exhaust had it on all my 4 wheelers. If you go full system do you have to do the clutch kit and tuner?. Slip on just as good?
2014 Rzr 1000 Black Pearl.
oufreud is offline
post #12 of 53 Old June 3rd, 2014, 07:24 PM Thread Starter
CB-BLR's Avatar
Member #45144
The full system is better... the length of the primaries is longer and different diameters than the stock pipe. .. so yes. ..I recommend a tuner... it is flowing air differently than stock. Yes I would recommend a clutch kit. .. it is producing more power than stock and easily revs past 8400 rpm which is above where you should have it clutched for peak horsepower.
CB-BLR is offline
post #13 of 53 Old June 3rd, 2014, 08:23 PM
oufreud's Avatar
First Name: Philip
Member #13358
Ok thanks for the info. Think I'm gonna go the sparks route.
oufreud is offline
post #14 of 53 Old June 16th, 2014, 01:52 PM
KB Motorsports's Avatar
First Name: KB Motorsports
My RZR: XP1000
Member #19990
View KB Motorsports's Photo Gallery(0)
Stock
HMF
Muzzy
Sparks Racing
Stock = 70-71 mph
Chris
Thanks for sharing your results!! I've been back and forth between the Sparks and Barker exhaust systems. The Dobeck Gen 4 is the only fuel controller to run in my opinion! They're awesome!
KB Motorsports is offline
post #15 of 53 Old June 16th, 2014, 04:52 PM
RZR_Racer725's Avatar
First Name: Brandon
My RZR: 2013 RZR 900XP
Member #60154
View RZR_Racer725's Photo Gallery(0)
Hey Guys,
Here's a picture of an installed system. Let me know if you have any questions! And, a link to the info on our site: X-6 Stainless Steel Exhaust System, Polaris 2014- RZR 1000 XP/ XP4
RZR_Racer725 is offline
Exhaust for xp 900 real hp gains Dustyroads33 RZR XP 900 10 August 10th, 2014 04:00 PM
Real World Pipe testing. CB-BLR RZR XP 1000 9 May 30th, 2014 10:45 PM
Rzr xp 900 exhaust testing ALBAPAT RZR XP 900 31 July 10th, 2011 09:07 PM
Advertised tired height vs. real world actual height crawlrinny Wheels and Tires 0 July 7th, 2010 07:00 PM
Real World Turbo Cost Overlord Forced Induction 23 January 30th, 2010 10:37 AM
