engine specs - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 28 Old August 27th, 2013, 06:54 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: engine specs
Yes it does.
Tuf-Skin is offline
post #17 of 28 Old September 8th, 2013, 08:59 PM
black03SVT's Avatar
Member #39127
View black03SVT's Photo Gallery(0)
Re: engine specs
So can I drop in a 1000 crankshaft with a big bore kit? That would be interesting.
black03SVT is offline
post #18 of 28 Old September 8th, 2013, 09:01 PM Thread Starter
Yamahaloverhas900xp's Avatar
Member #32594
View Yamahaloverhas900xp's Photo Gallery(0)
Re: engine specs
That would be good to know.
Yamahaloverhas900xp is offline
post #19 of 28 Old September 11th, 2013, 08:41 PM
stvdugas's Avatar
Member #57679
View stvdugas's Photo Gallery(0)
Re: engine specs
2200 lbs gross?
stvdugas is offline
post #20 of 28 Old September 11th, 2013, 08:46 PM
stvdugas's Avatar
Member #57679
Re: engine specs
What is actual wet weight?
stvdugas is offline
post #21 of 28 Old September 19th, 2013, 08:25 PM
Shanrzrman's Avatar
First Name: Shannon
My RZR: 09 800 RZRS
Member #60509
View Shanrzrman's Photo Gallery(0)
Usa Re: engine specs
They said it had a 180 crank which I think is bs because its an inline twin. Inline twins have 0 or 360 however you see it. And it sounds normal. It would sound funny kinda like its missing with a 180 crank.
Shanrzrman is offline
post #22 of 28 Old September 19th, 2013, 09:55 PM
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
View milosusa's Photo Gallery(27)
Re: engine specs
Engine in the 800 are 360 degrees, but 900 and 1000 are 180 degrees.
milos
2015 Sandstorm F350 GSLR
09 Raptor 700
14 RZR XP Z1100
http://czechracingteam.com/
milosusa is offline
post #23 of 28 Old September 19th, 2013, 09:58 PM
Shanrzrman's Avatar
First Name: Shannon
My RZR: 09 800 RZRS
Member #60509
Re: engine specs
Have you been inside one to see?
post #24 of 28 Old September 19th, 2013, 10:07 PM
milosusa's Avatar
First Name: milos
My RZR: 2011 XP Red
Member #1361
Re: engine specs
I rebuilt both engine, 800 and 900 and saw the difference in cranks. 1000 is similar in design to 900 engine.
milos
09 Raptor 700
14 RZR XP Z1100
milosusa is offline
post #25 of 28 Old September 19th, 2013, 11:17 PM
Empire Industries's Avatar
First Name: Eric
Member #6961
View Empire Industries's Photo Gallery(0)
Re: engine specs
The biggest difference I can see so far is the head and the crank.The bore is still the same. The crank is 9.1mm longer stroke and the head is quite a bit different. Looks like it flows a lot of air. Intake is bigger and the exhaust is an oval port exit instead of round like the 900. The exhaust valves are smaller than the 900 probably to keep velocity through the larger port design. The cams appear to be the same aside from being different lift and duration.
Empire Industries is offline
post #26 of 28 Old October 10th, 2013, 07:57 PM
Shanrzrman's Avatar
First Name: Shannon
My RZR: 09 800 RZRS
Member #60509
Re: engine specs
Now that ive seen some vids the 800 does sound different than the others
post #27 of 28 Old October 11th, 2013, 07:31 AM
Tuf-Skin's Avatar
Member #2228
Re: engine specs
The exhaust cam is supposedly the same as the cam in the 900 jagged X.
So are the valve springs, according to the parts drawings.
Tuf-Skin is offline
post #28 of 28 Old January 3rd, 2014, 06:09 AM
Banned
Litho-guy 1K's Avatar
Member #63620
View Litho-guy 1K's Photo Gallery(0)
Re: engine specs
Well, that would definitely make a cam different in my racing world....
Litho-guy 1K is offline
I need the engine torque specs for a 2008 rzr 800 oregontrailsman Engine and Drivetrain 4 December 3rd, 2015 08:12 PM
XP 900 Specs Vs XP 1000 Specs atvobsession RZR XP 1000 24 August 2nd, 2013 06:13 AM
Frontier 800cc sled engine specs to rzr??? rzr_max Engine and Drivetrain 2 March 6th, 2013 02:29 AM
XP 900 Engine Specs inside s2k1 RZR XP 900 50 April 30th, 2011 08:22 AM
