2013 xp4 lift - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old December 4th, 2012, 08:42 PM Thread Starter
Laundryboy's Avatar
First Name: Brian
My RZR: 2012 xp 900 / 2113 xp 900 4
Member #8300
View Laundryboy's Photo Gallery(0)
2013 xp4 lift
I want to disclose that when I ordered this lift, they told me they were not sure if it would work on the 2013 XP4. However; I felt if it did not work I would be able to put it on my 2012. So I ordered it. I started putting it on my 4-seater tonight, and apparently the mounting locations on the Walker-Evans shocks on my 2013 are wider. I would imagine the shocks on the 2-seaters and 4-seaters are the same, so has anyone put this lift on a 2013 2-seater because if it won't work on mine, I don't see why would work on that either.
On the rear there is a spacer on each side that is supposed to go between the shock and the bracket. The inside diameter is the same but on the outside diameter-one of them is noticeably larger, what is the deal with this?
Thanks, appreciate any help.
Brian.
Laundryboy is offline
post #2 of 4 Old December 4th, 2012, 09:30 PM Thread Starter
Laundryboy's Avatar
First Name: Brian
Member #8300
Re: 2013 xp4 lift
On closer inspection of the kit, the two rear spacers that were in the kit both have different inside and outside diameters. I don't know if I'm doing something wrong or what.
post #3 of 4 Old December 9th, 2012, 09:42 AM
Rubberdown's Avatar
My RZR: 2009
Member #1505
View Rubberdown's Photo Gallery(0)
Re: 2013 xp4 lift
The 2 little metal washers are laser cut to be the same, they are powder coated and sometimes on smaller parts the coating can be thicker than normal. The only other possibility is that we had them made in 2 batches with a slight size change from one run to the next, it is possible that when Melissa put the hardware together she didnt notice the difference. This will not make any difference in how it all works, its just a small spacers to take up some space between the new shock mounting tabs and the width of the shock itself.
Rubberdown is offline
post #4 of 4 Old December 21st, 2012, 10:54 PM
Scalp's Avatar
My RZR: 2013 RZR XP 4 900 LE
Member #46768
View Scalp's Photo Gallery(0)
So, does it work for the 2013 xp 4 walker evans le? How much lift does it give? I'm looking for 2-3"
Sent from my PC36100 using Tapatalk 2
Scalp is offline
2013 Walker Evans 2013 Shocks ktm300guy Polaris RZR Parts For Sale 15 November 9th, 2013 05:01 PM
2013 570 LE (before and after 2" Lift and 27" tires) Rzrbone RZR 570 Specific Discussion 55 October 25th, 2013 07:26 PM
2013 Ranger XP900 BIG Lift(Pics Inside) SuperATV Super ATV 2 May 6th, 2013 01:01 PM
2013 RZR XP ,and A Ranger 900 ,and a 2013 RZR 900 4 at the TAYLOR PARK CO. ride !!!!! FJK General RZR Discussion 65 August 12th, 2012 03:08 PM
