RDC Lift on 900 xp4 - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old April 17th, 2012, 10:26 PM Thread Starter
jgriffn's Avatar
Member #18408
View jgriffn's Photo Gallery(0)
Smile RDC Lift on 900 xp4
Well I recieved my lift and got it put on the xp4 last week. I went with the rubberdown customs lift because everyone had good things to say about quality of the lift kits and it is adjustable. I was worried about the adjustability because the adjustability on the highlifter lift does not work on the xp4. I snapped a few pics of the install and showed that you can attach the shocks in both positions.
Here is the lift kit components.
Here is a before pic, sorry I forgot to get an overall after pic, try to get one next week. This is with the shocks set at stock height I have not adjusted them yet.
I started with the front, here is stock.
Jacked up the front, removed the top shock bolt and intalled the front lift.
Here is the shock in the stock position with the lift installed.
Shock in the lifted postion.
Now on to the rear. I actually left the shocks on and installed the lift brackets first.
Before the bracket.
Bracket installed with shock in the stock postion.
Can't find the pic with the shock in lifted postion, but it just moves back and bolts to the bracket.
Can't go too much taller.
The lift components were all well made and the lift was fairly easy to install. The rear adjustability is pretty simple to do, but the exhaust side is pretty tight to get the bolt into. The front takes a little more to adjust because you have to loosen all the bolts and the two stock position bolts fit in pretty tight with the three middle bolts in the bracket, but does bolt into both positions. The only thing I did not do is cycle the suspension with the shocks in the stock position, but it seems like there is enough clearance for the reservoir.
Overall I am very satisfied with the lift so far. I gained right at 2 3/4". I do not have much ride time since the install, because I had to leave for work, but it seems to ride good and my 30" tires did not rub on the short ride I went on.
jgriffn is offline
post #2 of 6 Old May 25th, 2012, 06:17 AM
NorTxXp's Avatar
My RZR: Xp4 Le
Member #35423
View NorTxXp's Photo Gallery(0)
Re: RDC Lift on 900 xp4
Any problems to report? Interested in getting this lift for my xp4.
NorTxXp is offline
post #3 of 6 Old May 25th, 2012, 05:35 PM
The Dark Knight
Batman's Avatar
My RZR: 2012 RZR XP White LE
Member #19983
View Batman's Photo Gallery(0) Send a message via AIM to Batman Send a message via Yahoo to Batman
Sweet!!!! They make some damn good strong products. I have this lift on my xp 2 seater.
Nice write up!!!!!
2018 RZR XP Turbo S
SuperATV Fenders, RXUTV Pawltector, More to Come...........
SOLD 2012 RZR 900XP White LE
To Much to List........
Batman is offline
post #4 of 6 Old December 21st, 2012, 10:57 PM
Scalp's Avatar
My RZR: 2013 RZR XP 4 900 LE
Member #46768
View Scalp's Photo Gallery(0)
Do Yall have one that'll fit the '13 le with 2.5" rear shocks?
Sent from my PC36100 using Tapatalk 2
Scalp is offline
post #5 of 6 Old December 21st, 2012, 11:46 PM Thread Starter
jgriffn's Avatar
Member #18408
The 12 has the 2.5 inch rear shocks also.
jgriffn is offline
post #6 of 6 Old December 22nd, 2012, 06:54 AM
NickPic83's Avatar
First Name: Nick
My RZR: 2011 RZR S LE Orange Madness
Member #21937
View NickPic83's Photo Gallery(0)
Good to hear. My lift just got back from powder and should be shipping out today
Sent from my DROID RAZR using Tapatalk 2
I.B.E.W. L.U. 363 Journeyman
2011 RZR S-LE Orange Madness w/ 3500lb winch, UTV inc doors, E-brake, XP flares, sport roof, HID's, Barkers dual exhaust, DMC fuel controller, UTV intake, grumpy rider mod, RDC 2" lift, RT dual rate springs, DFR harnesses, EMP tinted half windshield, LED reverse/work light, led interior lights, bed extender, LED fog lights up front
NickPic83 is offline
SATV forward arms, SATV 1.5-3" lift, Racertech 2" lift 50" RZR mbsieg Suspension 6 May 31st, 2016 02:19 AM
super atv lift vs racer tech lift mrwizardd83 General RZR Discussion 7 February 26th, 2015 11:16 PM
2" Lift Kit , Lift Springs and Spring Spacers??? HivoltageRZR Suspension 20 April 5th, 2010 10:31 PM
3" Rotek Lift Kit vs 3" Xtreme Lift Kit silveradols Suspension 3 October 20th, 2009 07:04 PM
To Lift or not to lift, that is the question! Free Bird Suspension 5 April 12th, 2009 07:29 PM
