Stupid question - how to know when front diff is active - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By RZRdavid
  • 2 Post By sndnsno
post #1 of 8 Old August 23rd, 2018, 07:21 PM Thread Starter
nagilem's Avatar
First Name: Rob
My RZR: 2018 XP4 1000
Member #251170
View nagilem's Photo Gallery(0)
I just changed my front diff fluid and I was wondering how i might know if the front diff is active without the switch turned on. I went with synthetic atf and the diff sounds much better. I just don’t know how to test if it works or if it is active without the switch. Is there an easy way to tell? Is the 2/4 wheel sensor tied to the switch or does it actually show when the diff is working? I don’t feel much difference when i do turn the switch on.
Sorry for the newb question - before anyone says ‘learn how to search’, I have done several but am not finding anything useful. I may just not have the right search words to find my answer.
Thanks in advance for your help!
Time to get down to business!
nagilem is offline
post #2 of 8 Old August 23rd, 2018, 07:24 PM Thread Starter
nagilem's Avatar
First Name: Rob
Member #251170
Re: Stupid question - how to know when front diff is active
Not sure how this got in the rubber down customs area. I selected xp4 1000 when I wrote the opening message.
nagilem is offline
post #3 of 8 Old August 24th, 2018, 04:44 AM
waynesworld001's Avatar
First Name: Wayne
My RZR: 2015 XP 1000 / 2017 XPT 4
Member #94809
View waynesworld001's Photo Gallery(4)
I know this is pretty unscientific. But how about having someone stand outside of your RZR and watch when you put it in AWD and stomp on it. If your front spins too, then it's engaging. If not, then you have a problem. I know that might seem like a silly way to do it. But it might help get you an answer to your question until someone with a little more technical expertise than me chimes in.
Can't sleep. Clowns will eat me.
2017 XTP 4 - TBD.....
2015 XP 1000 - Shock Therapy Level 3 Spring Kit / Front Sway Bar, Alba Racing Stage 1 kit / Rear Radius Rods / Sway Bar Links / Front Bumper, Flight OffRoad "Shorty" Cage, ITP SS112 Wheels, Autotude High Clearance A-Arms, Southern Sounds MTX Roof System, SSV Works Sub, Super ATV 4500lb Winch, UTV Giant Full Doors / Rear Storage, Trail Control Gated Shifter, Adventure Air Onboard Compressor, Pro Armor Harnesses, Gorilla Whips.
waynesworld001 is offline
post #4 of 8 Old August 24th, 2018, 05:03 AM
RZRdavid's Avatar
First Name: David
Member #161625
Waynesworld is correct. This simple way is to find a soft loose surface that will allow a lot of tire spin. 1) do a two wheel spin 2) do an AWD spin. Compare, should be significant difference. Your spotter should be able to notice the front wheels spinning in AWD.
waynesworld001 likes this.
RZRdavid is offline
post #5 of 8 Old August 24th, 2018, 06:06 AM
sndnsno's Avatar
First Name: Ken
My RZR: 2014 XP1K
Member #25844
View sndnsno's Photo Gallery(0)
Years ago others on the forum told me to put the rear of my old 800 Up on my floor jack then put it in gear. If front is pulling it will ease forward. Try again with the 4x4 switch on. If you use this method make sure you have room in front. No need to stomp on it, just get the clutch to engage. Once the rig senses the rear wheels spinning with no forward progress thefront should kick in and move the RZR.
adam_s05 and Michale like this.
sndnsno is offline
post #6 of 8 Old August 25th, 2018, 04:06 PM Thread Starter
nagilem's Avatar
First Name: Rob
Member #251170
LOL thanks guys. Ill give the 'unscientific' method a try.
nagilem is offline
post #7 of 8 Old August 25th, 2018, 04:35 PM
RZR800SS's Avatar
First Name: GORDEN
My RZR: 2018 900 RZR S
Member #214409
View RZR800SS's Photo Gallery(0)
Usa Re: Stupid question - how to know when front diff is active
why not use 90w gear oil like they use in lower units on boat motor they turn 5,000 rpm
RZR800SS is offline
post #8 of 8 Old August 25th, 2018, 10:02 PM Thread Starter
nagilem's Avatar
First Name: Rob
Member #251170
Front diff needs lighter synth atf. I put the 75w90 in the rear diff / trans in the back.
nagilem is offline
Rzr 800 Front Diff Swap huntermorse01 Engine and Drivetrain 1 August 1st, 2018 11:40 AM
Play in Front Diff MarkW RZR XP 900 0 April 6th, 2017 12:52 PM
Another Front diff question NCincyRZR RZR XP 1000 22 January 14th, 2017 03:58 AM
Another front diff problem Steve Morris General RZR Discussion 1 January 4th, 2017 03:55 PM
New HD Front Diff for 570/800/900 RZR!!! Hunterworks Hunterworks 15 October 13th, 2016 04:54 AM
