Racer Tech - RZR 170 Lift Kit - IN STOCK - Polaris RZR Forum - RZR Forums.net
post #1 of 15 Old October 17th, 2013, 04:13 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
View RT PRO's Photo Gallery(0)
Our RZR 170 Lift Kit has been a huge hit since we released it a few years ago. At first they were built to order since they were a PITA to build and expensive to stock. Now they've become so popular and we've grown enough to stock LOTS of these.
This is hands-down the best thing you can do for your RZR 170 besides our Harness Kit. It increases the ground clearance and majorly increases the stability.
The Racer Tech RZR 170 Lift Kit uses a combination of experience and knowledge to gain the needed ground clearance and improved handling characteristics the RZR 170 needs. We've relocated the rear upper shock mounts to manipulate the geometry of the rear end and relocated the front spindles while still using the stock front A-arms. By doing this, we've increased the ground clearance by two inches. The front kit is especially helpful for clearance because the arms stay at the same angle as stock while the spindle is lowered. This provides even better arm to ground clearance than other "arm replacement" alternatives because the arm is put up higher along with the chassis which means there is even less to hit or drag across the arms with the Racer Tech kit.
As an added bonus, we've made sure the steering geometry remains correct while using this lift. This is something most other companies do not seem to consider. The Racer Tech RZR 170 Lift Kit uses heavy duty complete tie rod replacements which are raised and adjusted to work in unison with the factory steering rack and geometry. The stock tie rods on the RZR 170 are a known weak point so when purchasing this kit you should consider the fact you are performing two much needed modifications at the same time.
The Racer Tech RZR 170 Lift Kit comes as a complete kit with everything needed for installation. Installation is fairly simple. The rear shock relocation mount bolts in place with no drilling or mods to the chassis. There is an additional chain link provided with the kit which is needed to lengthen the chain slightly to work with the modified rear geometry. The front kit is also simple in that it’s a "clevis" style kit which slips over the factory spindle clevis and bolts in place using the supplied hardware. There is one hole per side which needs to be drilled though the factory arm clevis to install the necessary hardware but this is very simple if you have a drill and a 3/8” drill bit. To install the tie rods the spindle arms must be drilled out to Ĺ” to fit the adapter bushing but the rest is bolt-together. This kit also includes new, extended brake lines for the front brakes and wheel spacers to widen the rear end to match the adjusted width of the front.
All kits come standard in black powdercoat with no exceptions.
For more info and ordering click HERE.
Formerly Racer Tech. Click HERE for details.
RT Pro UTV - The official site
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #2 of 15 Old October 17th, 2013, 05:57 PM
All Terrain Research's Avatar
Member #11213
View All Terrain Research's Photo Gallery(0)
Re: Racer Tech - RZR 170 Lift Kit - IN STOCK
A well put together kit!
All Terrain Research is offline
post #3 of 15 Old October 24th, 2013, 01:56 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #4 of 15 Old October 27th, 2013, 05:59 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #5 of 15 Old November 16th, 2013, 05:07 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
In stock
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #6 of 15 Old November 24th, 2013, 03:06 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #7 of 15 Old November 28th, 2013, 06:54 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #8 of 15 Old December 9th, 2013, 03:46 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #9 of 15 Old December 12th, 2013, 03:00 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
IN STOCK
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #10 of 15 Old August 3rd, 2014, 07:14 PM Thread Starter
Formerly Racer Tech
RT PRO's Avatar
Member #1051
Back in stock!
517-278-7768
Contact us HERE
ADD US ON FACEBOOK!
RT PRO is offline
post #11 of 15 Old October 19th, 2019, 08:17 PM
UTVReport's Avatar
My RZR: RZR 170, Ace 900XC, and Ranger XP900
Member #9344
View UTVReport's Photo Gallery(0)
In stock now?
Chris
UTVReport is offline
post #12 of 15 Old October 21st, 2019, 08:41 AM
Tech@RTpro's Avatar
First Name: Ted
My RZR: XP1000 Turbo 4
Member #14167
Feedback Score: 4 reviews
View Tech@RTpro's Photo Gallery(14)
The RZR 170 Lift kit is in-stock and can ship the same day if ordered before 1PM eastern time. Use the Discount Code RZRFORUM2019 to save 10% it should be active by the end of the day today.
Ted-Brand Ambassador/Lead Tech RT Pro
https://rtproutv.com/
https://www.facebook.com/RTProUTV/
PM me for Sales and Technical product related questions.
post #13 of 15 Old October 21st, 2019, 09:12 AM
UTVReport's Avatar
Member #9344
Thanks Ted...do you know what tire/wheel sizes and offsets people are running with your lift?
Chris
post #14 of 15 Old October 21st, 2019, 11:30 AM
Tech@RTpro's Avatar
First Name: Ted
Member #14167
Chris 12" wheels with 24" tires seems to be the most popular set up on the 170 with 2" lift.
post #15 of 15 Old October 21st, 2019, 12:22 PM
UTVReport's Avatar
Member #9344
Thanks Ted...I appreciate the help.
Chris
RT Pro 50" RZR 800 2" Lift Kits IN STOCK! RT PRO RT PRO UTV 198 March 14th, 2017 10:11 AM
Racer Tech RZR S/4 800 Lift Kits - IN STOCK TODAY!!! RT PRO RT PRO UTV 249 December 27th, 2016 06:32 AM
Racer Tech lift in stock? Ice RZR-S Specific Discussion 8 May 15th, 2012 10:10 PM
Who has a 2 inch Racer Tech Lift in stock? wandemo1 General RZR Discussion 3 December 16th, 2011 08:27 AM
Racer Tech 2" lift kit for RZR S in stock! [email protected] RT PRO UTV 0 June 16th, 2011 11:07 AM
