Any put Can-Am retractable harnesses in a RZR - Polaris RZR Forum - RZR Forums.net
Roll Cages and Safety Equipment For discussion of roll cages
 4Likes
  • 1 Post By Dirt-Monger
  • 1 Post By Herdfan
  • 1 Post By DogRunner2
post #1 of 7 Old June 18th, 2019, 01:01 PM Thread Starter
Herdfan's Avatar
Member #203033
View Herdfan's Photo Gallery(0)
And the reason I ask is because I am not sure I want the leg straps. I think they would annoy me and the CA's are only 4 point.
I can fab any bracket I would need. Just wondering if anyone has done it.
Or in the alternative, how annoying are the leg straps?
Herdfan is offline
post #2 of 7 Old June 19th, 2019, 01:19 PM
Dirt-Monger's Avatar
My RZR: 17 RZR 900s
Member #211761
View Dirt-Monger's Photo Gallery(0)
Re: Any put Can-Am retractable harnesses in a RZR
Hey, I just installed a click 6 harness but did not like the leg straps either ..... so I just cut them off, I also took the latch apart and removed the safety plug harness since I already had a bypass installed, now its just a simple 4 point without wires on the side... I like it much better now.
Herdfan likes this.
Dirt-Monger is offline
post #3 of 7 Old June 19th, 2019, 01:41 PM Thread Starter
Herdfan's Avatar
Member #203033
So I am guessing that the bypass plug is the only difference between the driver/passenger side ones? I have a bypass already.
I saw a video of an install and they don't look as annoying installed, so I will start with them and if they annoy me, cut them off.
Thanks.
RZR_Joe likes this.
Herdfan is offline
post #4 of 7 Old June 19th, 2019, 08:12 PM
DogRunner2's Avatar
Member #137545
I don't mind the leg straps.
Herdfan likes this.
2018 XP1K LE
DogRunner2 is online now
post #5 of 7 Old June 20th, 2019, 12:38 PM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I was thinking along the same lines. I would like to get the Pol 6 click but the price is crazy
It seems you can find the Can Am belts for half the price if you shop around and either way mods will need to be made with a custom cage
Max H is offline
post #6 of 7 Old June 20th, 2019, 01:56 PM
My RZR: 17 RZR 900s
Member #211761
Thanks.
I only got the driver side, there's is no safety on the pass side however the buckle does face the opposite side
Herdfan likes this.
post #7 of 7 Old June 20th, 2019, 02:22 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
On the click 6 belts, the lower two straps are to prevent you from sliding out from under the harness upon a front impact. It took me a bit to get used to them but now I would not run anything else.
RZR_Joe is online now
