Racing Oil - Polaris RZR Forum - RZR Forums.net
Racing Specific Equipment For discussion of racing equipment such as cages, fuel cells, doors and other racing requirements
post #1 of 8 Old August 5th, 2013, 06:37 AM Thread Starter
tpollock33's Avatar
First Name: Travis
My RZR: XP1000
Member #45974
View tpollock33's Photo Gallery(0)
Racing Oil
Just wondering what oil everyone is using for there race RZR??
tpollock33 is offline
post #2 of 8 Old August 5th, 2013, 08:07 AM
sandracer1's Avatar
First Name: Todd
My RZR: Redline Revolt 750 turbo 135hp
Member #15581
View sandracer1's Photo Gallery(0)
Re: Racing Oil
Redline 20/50 full synthetic.
sandracer1 is offline
post #3 of 8 Old September 2nd, 2013, 08:50 AM
SRRZR's Avatar
My RZR: XP 900
Member #55669
View SRRZR's Photo Gallery(3)
Re: Racing Oil
Amsoil 15w50 Dominator
SRRZR is offline
post #4 of 8 Old September 11th, 2013, 05:55 PM
BCRacing24's Avatar
First Name: Brian
My RZR: 2018 XPT4 Dynamix
Member #20030
View BCRacing24's Photo Gallery(0)
Usa Re: Racing Oil
Wouldn't use anything else in a high $$ race engine.....
Racing Oils | Mobil 1 Racing™
Joe Gibbs Driven - XP6 SAE 15W-50 Synthetic Racing Motor Oil
BCRacing24 is offline
post #5 of 8 Old September 11th, 2013, 06:12 PM
turkeyhunter's Avatar
First Name: gary
My RZR: XP turbo
Member #16815
View turkeyhunter's Photo Gallery(0)
Re: Racing Oil
Joe Gibbs XP6
turkeyhunter is offline
post #6 of 8 Old September 11th, 2013, 06:32 PM Thread Starter
tpollock33's Avatar
First Name: Travis
My RZR: XP1000
Member #45974
Re: Racing Oil
Can I ask why you are running xp6. Since holz and kroyer recommend xp7.
post #7 of 8 Old September 11th, 2013, 09:35 PM
BCRacing24's Avatar
First Name: Brian
Member #20030
Re: Racing Oil
XP6 is a full synthetic 15-50
I do not and never have changed my oil after every race like some do. I prefer 15-50 for less engine wear and to maintain viscosity with high rpm\heat use.
XP7 is a Semi synthetic 10-40
It will not withstand as much heat before breaking down and loosing viscosity compared to 15-50. Their are two reasons I suspect Holz uses XP7. 1) they change oil & filter after every race negating the need for full synthetic. 2) they are trying to achieve max HP which is obtainable with a thinner oil. NASCAR engines typically run 0-20. Holz is using a oil cooler as well to keep oil temp, breakdown & thinning in check. One other thing to note, if running the stock hydraulic cam chain tensioner I wouldn't use 10-40 as the tensioner operates off of oil pressure. Hot thin oil can cause chain to jump due to inadequate pressure. Holz uses a solid mechanical chain tensioner that doesn't rely on oil pressure.
If you are willing to change oil\filter every race, have a oil cooler, mechanical tensioner & DLC coated valve buckets and are wanting the absolute most power possible from your current package then use a 10-40 or equivalent. If you want to stay conservative & have the belief that an extra 1hp or so will not be the difference of Podium or not then by all means stay safe and use a 15-50 or equivalent.
Sent from my iPhone 4s using Tapatalk
Member #247
Last edited by BCRacing24; September 11th, 2013 at 09:45 PM. Reason: Auto-correct spell check sucks.....=)
post #8 of 8 Old June 21st, 2019, 03:52 PM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
Re: Racing Oil
Blud Lubricants 10w50
AMA D38 - Sportsman UTV 2009 Polaris RZR 800S
Windansea Coffee / Mass Depot / MassFX / Matrix Concepts / Venom Products / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
442raceRZR is offline
Vent Racing Racing Head Valves mxmike13 RZR 170 Specific Disccusion 0 August 15th, 2012 10:01 AM
new racing venue for sxs racing Houston Texas scott stephens Short Track Racing 0 April 18th, 2009 02:34 PM
Lucas Oil Off Road Racing & Dragonfire Racing Bring UTV Racing to LOORRS DRAGONFIRERACING Short Track Racing 1 April 17th, 2009 11:09 AM
