DIY $8 Fire Extinguisher Mount - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 3 Post By chevihemi
post #1 of 5 Old August 11th, 2018, 07:51 PM Thread Starter
chevihemi's Avatar
Member #200993
View chevihemi's Photo Gallery(0)
Made a quick disconnect fire extinguisher mount for about $8Click image for larger version
ID:	558510Click image for larger version
ID:	558512Click image for larger version
ID:	558514Click image for larger version
Materials:
24 Shelf wall bracket
2 - 1 3/4 - 2 3/4 hose clamps
2 - hose clamps that will fit around extinguisher of your choice
2 - 1/4 x 1 1/4 ring detent pins
Cut desired length of bracket for mount (I did about 7). You will need 2 of these. Round cut edges off with sanded or grinder.
Using a punch and hammer bend out two of the middle tabs on each piece for the hose clamps to pass through.
Clamp both pieces together with c-clamps and drill through all 4 layers in two places with a 1/4 bit. Changer these holes slightly with a larger bit.
Assemble on roll bar of RZR. 5/16 shrink wrap fits perfect over the hose clamps for a better appearance. Of pins are too tight wallow the holes slightly until you are happy with the fit.
Pullerguy, kwasm1 and Carhauler38 like this.
chevihemi is offline
post #2 of 5 Old August 12th, 2018, 03:46 AM
turboville's Avatar
Member #65574
View turboville's Photo Gallery(0)
Re: DIY $8 Fire Extinguisher Mount
Nice at that price you can put them all the way around the cage ! Should strengthen the cage lol
Using Tapatalk
turboville is offline
post #3 of 5 Old August 12th, 2018, 07:46 AM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
Nifty!
204 AR is offline
post #4 of 5 Old August 19th, 2018, 07:05 AM
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
Got these on Amazon. These mounts work great and fit different tube sizes and extinguisher sizes.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Roger Lee is offline
post #5 of 5 Old May 15th, 2019, 02:02 PM
Feldhege's Avatar
First Name: Robb
My RZR: 2017 Polaris RZR S 900
Member #268354
View Feldhege's Photo Gallery(0)
Thanks for this idea. I made one and it works awesome.
Feldhege is offline
Pro Armor Fire Extinguisher Kit W/ mount Adrenaline Cycles Adrenaline Cycles 11 March 22nd, 2017 07:10 AM
Quick Release Fire Extinguisher Mount flimmy Polaris RZR Parts For Sale 3 March 13th, 2016 10:15 AM
Quick Release fire extinguisher mount flimmy Roll Cages and Safety Equipment 1 February 29th, 2016 05:36 PM
