DIY adjustable sway bar - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By glamisfan
  • 1 Post By FRAZR
post #1 of 11 Old May 13th, 2017, 05:08 PM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
View glamisfan's Photo Gallery(0)
This was done on my XP turbo. With the stock shocks I ran it with the rear sway bar disconnected. It's seemed to handle just as good, but it articulated better for the slow stuff. Recently I put on shock therapy 3+ Springs, which is four new front springs and rear upper Springs along with crossovers. It made a huge difference and it rides much smoother. But, it had ridiculous body lean with the rear sway bar disconnected. So I hooked it back up and it handles good again. But, it lost the articulation on the rear. So I made up some plates with multiple holes and welded them to the trailing arms, so that you can put the swaybar link farther back towards the shock which makes it stiffer, but you can also put it towards the front of the trailing arm which makes it a softer sway bar. I also welded two pieces of half inch angle iron to the swaybar links to make them stronger. Total cost......zero!!! I'll be trying it out tonight to see how it works.
glamisfan is offline
post #2 of 11 Old May 23rd, 2017, 02:51 PM
Baynz's Avatar
First Name: Blake
My RZR: 2015 1000 XP4
Member #76455
View Baynz's Photo Gallery(0)
Re: DIY adjustable sway bar
Looks great can't wait to hear how it worked out.
Sent from my SM-T580 using Tapatalk
Loving the RZR life!
Baynz is offline
post #3 of 11 Old May 27th, 2017, 09:53 PM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
It worked just like I thought it would. I got it set to be softer than stock.
post #4 of 11 Old May 28th, 2017, 10:49 AM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
In this picture at the four-inch Mark was the original swaybar mount. I tried it 4 inches to the left and it was actually too soft there and it would take a set when you were cornering making one of the front tires feel too light. So now I am at 2 inches from the original mount and it feels like a good compromise right there.
post #5 of 11 Old May 28th, 2017, 11:40 AM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2014 XP4K, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
Your fabrication skills look nice. I'm surprised this affects the stiffness of the sway bar, since the same amount of sway bar is sticking out from the fulcrum point, (sway bar brackets). I would think you'd get better stiffness by drilling a new hole in the sway bar, closer to the firewall, so it doesn't allow as much flexing.
I guess as you move the bottom link bolt, it just changes the effectiveness of the sway bars torsion rate, due to the increased angle?
Fimea is offline
post #6 of 11 Old May 28th, 2017, 11:52 AM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
As you move the lower mount towards the rear of the trailing arm, it gets closer to a 1:1 ratio making it stiffer. If you move it towards the front, the trailing arm moves less and has more leverage, making it softer.
So the stock mount near the middle makes the sway bar about half as effective as it would be if mounted right above the axle.
Fimea likes this.
post #7 of 11 Old June 22nd, 2017, 04:56 AM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
So this is working great. I put it in the farthest back hole which is the stiffest for Glamis a few weeks ago, and it cornered like it was on rails!
post #8 of 11 Old June 22nd, 2017, 10:12 AM
RZRdavid's Avatar
First Name: David
Member #161625
Good idea. Nicely done.
RZRdavid is offline
post #9 of 11 Old June 22nd, 2017, 11:24 AM
megadesertdiesel's Avatar
My RZR: None
Member #597
Feedback Score: 18 reviews
Great idea, i love the DIY stuff.
drive fast and take chances.
megadesertdiesel is offline
post #10 of 11 Old June 22nd, 2017, 12:11 PM
FRAZR's Avatar
Member #82174
View FRAZR's Photo Gallery(0)
Just saw this. Great idea! BTW are you using dryer vent tubing for your clutch housing tubes?
Chuck13x likes this.
FRAZR is offline
post #11 of 11 Old June 22nd, 2017, 01:15 PM Thread Starter
glamisfan's Avatar
First Name: Steve
My RZR: XP Turbo
Member #21731
Yes...............
I didn't like how the oem hose was 3" at the bed and 4" at the housing. And I can't find the good black 4" hose that some vendors use with their setups.
Front sway bar?? luckylawnboy RZR XP 1000 22 April 13th, 2018 04:57 PM
