RZR Pro Park Brake from Pro UTV Parts - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By craigstumph
  • 1 Post By RWB713
post #1 of 6 Old October 25th, 2019, 03:05 PM Thread Starter
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
HEAVY DUTY PARKING BRAKE FOR YOUR POLARIS RZR XP PRO LOCKING FEATURE - FITS ALL - BY SPRING BRAKE THINGY
DESCRIPTION
This brake allows for a pad-lock to be inserted through pre-machined holes to give you the added option to use as a theft deterrent.
Installation is simple and quick, back out the 15mm nuts on the master cylinder behind the brake pedal, put on the Spring Brake Thingy, then put the nuts back on. It is that simple and quick, takes no more than 2-3 minutes.
To operate, depress brake pedal with right foot, slide lever over brake pedal arm with your left foot and the SBT engages all 4 brakes. Once set, add your own pad lock (1/4" to 5/16" shaft) for that extra security. To release simply unlock pad lock, remove, and depress brake pedal.
PM or order online:
https://www.proutvparts.com/collecti...g-brake-thingy
Name:	General_Unlocked_383x_3x.progressive_f9b73de6-c3b4-4c65-8e61-b93d210a694d_4000x.progressive.jpg
EllerClanLeader likes this.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is online now
post #2 of 6 Old October 25th, 2019, 03:14 PM
EllerClanLeader's Avatar
First Name: Randy and Barbara
My RZR: 2015 XP1K Fox Edition, 2016 XP Turbo
Member #6369
View EllerClanLeader's Photo Gallery(4)
Re: RZR Pro Park Brake from Pro UTV Parts
Highly recommended!!
I proudly use and recommend products and services from these supporting vendors;
SpringBrakeThingy, Fullerton Sand Sports, Bert's Megamall, Assault Ind., Hunterworks, SSV Audio, Super ATV, Packard Performance, Factory UTV, UTV Inc,
EllerClanLeader is offline
post #3 of 6 Old November 7th, 2019, 07:37 PM Thread Starter
craigstumph
My RZR: RZR 1000
Member #59177
In stock!
www.proutvparts.com
post #4 of 6 Old November 8th, 2019, 08:35 AM
nimporzr's Avatar
First Name: Logan
My RZR: 50" RZR900
Member #273546
View nimporzr's Photo Gallery(0)
Looks good but what's wrong with just putting it in PARK??
nimporzr is offline
post #5 of 6 Old November 8th, 2019, 08:52 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Put it in park on a steep grade.... youíll find out quick.
Itíll bind up the gearcase and you damn near wonít be able to get it out of park, Iíve had to Jack a machine up on a steep grade to unbind it before, itís sketchy at best
Max H likes this.
2018 XPT4 - Bailey
RWB713 is online now
post #6 of 6 Old November 8th, 2019, 11:51 AM
Pro4driver's Avatar
My RZR: Trails & Rocks Edition
Member #261784
View Pro4driver's Photo Gallery(0)
Usa Re: RZR Pro Park Brake from Pro UTV Parts
+1
Any kind of parking brake is a good idea. The more often you park in gear on a hill the harder it gets to get it out of park. I noticed this after a few times when new.
I will add that the less complicated design will be problem free. I use mine so often it feels wrong not to have it. My cheap $25 unit has needed repairs, rivets fell out, but some hard bolts welded in are a permanent fix.
The factory should be offering one as standard equipment, but do wish it could be mechanical and work as emergency brake if hydraulic system fails. That happen to me when axle broke at threads. Read about that in a different post.
Bottom line, if you park on any ground that is not flat you need one.
Pro4driver is offline
