2019+ RZR 7101A RYCO MOTO Turn Signal/Horn Kit
Application:
POLARIS RZR XP 1000 / 4 1000, 2019,
POLARIS RZR XP TURBO / 4 TURBO, 2019,
POLARIS RZR XP TURBO S / 4 TURBO S, 2018-2019
Kit Features:
Self Canceling if you forget and leave the blinker on
Steering column mounted combination turn signal and horn switch, with four-way flasher activator
Front turn signal accent "fang" LED lights
Ties into the vehicle taillights as rear turn signals for a clean, factory appearance
Brake lights strobe in the first second when activated, and then stay on solid*
Uses the turn signal indicator on the instrument cluster**
*This feature can be disabled, per your preference.
**Polaris did NOT include factory turn signal indicators on machines older than 2011, as well as some models with the RIDE COMMAND DISPLAY, and some TURBO models. On other models, such as the 2019 RZR TURBO S, the vehicle indicators may not be compatible with the turn signals. This kit also includes dash mounted indicator lights to use as needed or per preference.
Ryco street legal kits have a turn signal with an integrated horn button and emergency flashers..The factory rear tail lights are used for the left and right turn signals. Illuminated license plate holder with night time running lights are integrated into the system to meet state regulations for highway vehicles. Wiring harness and detailed instructions are included with each kit. Satisfaction guaranteed.
Kit Includes:
Dash mounted indicator lights
105dB horn
Electronic flasher relay
License plate mounting hardware and LED plate light
Complete wire harnesses with factory-type connectors installed
All necessary hardware, cable ties, and connectors
Illustrated installation instructions
PM or Order online
Ryco Street Legal Kit for Polaris RZR Turbo S/Turbo/1000 2019+
Application:
Kit Features:
Kit Includes:
105dB horn
PM or Order online
