Bus Bar Accessory Solution From OTB - Polaris RZR Forum - RZR Forums.net
post #1 of 1 Old July 31st, 2018, 05:10 PM Thread Starter
OTB Powersports's Avatar
Member #250554
View OTB Powersports's Photo Gallery(0)
This high quality bus bar accessory kit is all thatís needed to install light bars, fans, radios, and any other switched accessories in your 2017-Current Polaris RZR and General. This kit features:
30 Amp Capacity
Relay Switched Power
Fused
Lighted Rocker Switch Ready
Ignition Switch Controlled ( No dead battery if you accidentally leave an accessory on )
Lightning Fast Installation of Accessories
Here is how simple it is to install an accessory on your machine when using this kit.
Connect RED and BLACK wires to your accessory. RED is 12V+ and BLACK is ground.
Plug in YELLOW wire to the center(common) terminal of the rocker switch. Plug in BLUE wire to the rocker switch light ground if equipped. Plug in RED wire to the normally open contact of the rocker switch
Plug in the main harness connector into the bus bar.
Fasten the relay with a screw or zip tie.
Install a mini blade fuse of the current rating of your accessory.
Done!
Includes:
Complete Switch Harness
Relay
https://otbpowersports.com/product/p...accessory-kit/
OTB Powersports is offline
Bus bar wiring? The Crazor Guy Lighting, Stereo and Electrical 9 July 23rd, 2017 10:28 AM
bus bar harness 40$ wadewoot RZR S 1000 3 January 7th, 2017 07:02 PM
Bus bar help 2016 HO 900XP Bronson1987 RZR XP 900 H.O. Jagged X Edition 13 November 30th, 2016 12:41 PM
UTV INC & Totron 30" LED Light Bar Kit UTV Inc. UTV Inc 53 October 11th, 2016 07:56 AM
Winjet 30" Curved Light Bar Sshsjd10 RZR S 900 2 August 24th, 2016 06:11 AM
