Is it worthy to use the side view mirrors? - Polaris RZR Forum - RZR Forums.net
Member Introductions Please introduce yourself in here and let us know a little bit about yourself and your ride. Welcome to RZRforums!
post #1 of 1 Old September 19th, 2019, 11:10 PM Thread Starter
Kemimoto
Kemimoto's Avatar
First Name: Agnes
My RZR: RZR1000
Member #272748
View Kemimoto's Photo Gallery(0)
Laughing Is it worthy to use the side view mirrors?
Today I'd like to take a few minutes of you and tell you something about side view mirrors for utility vehicles.
The mirrors are designed for utility vehicles and we make them specifical to deal with all the situations that we know people do with utility vehicles.
The mirrors are designed with a breakaway feature. When you're navigating a tight trail and are going to hit a tree, they will fold promptly. It's no big deal at all! Then you can push it back out and keep on riding.
They can take the hit of clamps, for the mirrors are held on the roll cage, which are made of steel. The low mast profile allows them to be mounted in different spots of the roll cage.
And you might want to put on a windshield, the mirror is designed out of the way. So that when it meets the clamp it's got an unlimited range of motion. It can literally go 360 degrees on the clamp so you can position it.
Whatever vehicle you are in, whatever kind of riding you're doing, between the clamp and the mirror, there's a rubber isolator that helps to hold the mirror in place. It also minimizes the vibration when you're looking into it.
The mirror has the ability to fold and a tremendous range of adjustability. Because it got a spring-loaded ball joint in the bottom and that's adjustable with a socket wrench. It won't loosen up from hitting tree branches and adjusting unless it has lasted for over years.
You can just go back in and get it right back to normal. Side mirrors have many advantages
So believe me, it's worthy to buy the side mirror that will make our ride more enjoyable.
Kemimoto is offline
Tags
utv mirrors
