RZR ARP Wheel Studs by Maxwell Industries - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old March 19th, 2015, 01:08 PM Thread Starter
maxwell tech's Avatar
Member #78901
View maxwell tech's Photo Gallery(0)
STOP replacing your wheel studs – upgrade to ARP!
If you’re racing your RZR UTV’s, then you’ve probably had wheel stud problems. The OEM wheel studs just weren’t designed for extreme off-road duty.
There are other replacement wheel studs on the market, but they don’t address the real engineering issue – they aren’t strong enough.
That’s why we worked with the fastener experts at ARP to engineer and manufacture a wheel stud that will handle a ton of use and abuse. ARP re-engineered the stud with a 35% larger diameter in the critical area from the rotor to the hub face. In addition, ARP’s studs are made from 8740 chrome moly and heat-treated to a nominal strength of 180,000 psi – significantly stronger than cheap grade 8 replacements.
These replacement wheel studs require a 16mm x 2.0 tap and minimally drilling out the brake rotor, but the end result is much stronger than OEM and other aftermarket studs. In the image to the right, you can see the dramatic difference in the stud diameter between the ARP threaded stud and the OEM stud. (Tap and drill bit sold separately.)
If you’re on a tighter budget, but still want the strength of ARP fasteners, we also offer an ARP knurled stud that fits your hub without any modifications. These studs are easier to install, but still have the 35% larger diameter between the rotor and the hub face.
Check out Maxwellindustries.com for more information, including installation videos.
maxwell tech is offline
post #2 of 2 Old March 3rd, 2018, 11:57 PM
jmedlin13's Avatar
First Name: Justin
My RZR: 2014 XP1000
Member #221153
View jmedlin13's Photo Gallery(0)
Re: RZR ARP Wheel Studs by Maxwell Industries
How much longer are the press in ones than the stock? I need studs with at least 1/2 longer threads
jmedlin13 is offline
Tags
wheel studs
Maxwell Industries is a Supporting Vendor! 4Nines Maxwell Industries 5 March 19th, 2015 03:17 PM
ARP Head Studs, Main Studs and Wheel Studs in Stock! GHETTOSLED RZR 1000 Engine 1 October 26th, 2014 01:55 AM
ARP Head Studs, Main Studs and Wheel Studs in Stock! GHETTOSLED RZR 900 Engine 0 September 28th, 2014 10:47 PM
Wheel Studs RZRJOSH Want to Buy 4 August 11th, 2012 07:55 PM
wheel studs bajarzr General RZR Discussion 2 March 18th, 2012 06:06 PM
