19 Ride command update with Group ride V2V Communication antenna kit install - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 22 Old August 7th, 2019, 04:27 AM Thread Starter
Fuzzy761210's Avatar
My RZR: 19 XP1000 Ride Command
Member #268740
View Fuzzy761210's Photo Gallery(0)
Vehicle-to-Vehicle Communication Kit
Item # 2884449
https://rzr.polaris.com/en-us/shop/a...ology/2884449/
Price 150
Here are the parts that came in the kit
Antenna
Antenna cable
After seeing this big antenna had me a little scared until I realized it fits under the top dash piece. The directions are pretty straight forward and the install should take no longer then 20 minutes. I won't walk through the actual install instruction but I will show pictures
Drilled hole in the approx position in the instruction, manual calls out a 17mm hole, I used a Unibit (step bit). There is plenty of wiggle room for placement
The antenna is foam backed and a washer is included with another piece of foam for sealing. I believe the nut was 23mm but you could use a crescent wrench
The directions show running the cable through the smaller firewall grommet, I have the SSV Works sub so running any more wires through it is a pain so, I ran it through the large grommet.
On the back of the ride command there is a blue cap over the connector, this is the one on the driver side. It's also the only one that doesn't have a cable coming out of it.
Unclip and pull off blue dust cap, the connector socket is brown to match the cable end in the kit
Push on connector until it clicks, attached antenna end and tighten it snugg
Zip tie how you see fit
Put everything back together
Here is a picture of the top dash panel installed over the antenna
Here are just some pictures of the setup, you honestly just toggle it on or off, I have no idea if its working.
AZNorseman likes this.
Fuzzy761210 is offline
post #2 of 22 Old August 10th, 2019, 01:59 AM
tomax.ssv's Avatar
Member #271942
View tomax.ssv's Photo Gallery(0)
Re: 19 Ride command update with Group ride V2V Communication antenna kit install
Does it only allow positionning or also voice communication through a paired headset for example ?
tomax.ssv is offline
post #3 of 22 Old August 10th, 2019, 06:13 AM Thread Starter
Member #268740
Positioning only, although that would be awesome to be able to communicate or even throw out a distress beacon type thing if your in a group at the end of the line and you break or get stuck it pings everyone or even people not in your group.
post #4 of 22 Old August 11th, 2019, 04:33 PM
GPS GURU
702youngbergs's Avatar
My RZR: 2019 XP1000 RC
Member #269632
View 702youngbergs's Photo Gallery(0)
I bought the 2019 RC 1000xp4, Do I need to buy this or should my car have come with it? I can’t remember seeing it anywhere.
702youngbergs is offline
post #5 of 22 Old August 11th, 2019, 05:21 PM
GPS GURU
Member #269632
just inspected under my bezel, and in fact I do not have the antenna! and I am Pissed because my car was billed to me as having this feature from the factory. Polaris is gonna get words from me for sure.
Now for the next question, That wire looks pretty short. Is it not long enough to reach the roof for better distance?
Last edited by 702youngbergs; August 11th, 2019 at 05:23 PM. Reason: added question
post #6 of 22 Old August 12th, 2019, 04:13 AM
ktl5005's Avatar
First Name: Keith
My RZR: 2018 1000XP Ride Command
Member #215297
View ktl5005's Photo Gallery(0)
They said in the release of this it is an upgrade to to the 19+, not factory installed. Only stock on the forecoming Pro XP, so don’t know where you got that information or why your panties are in a twist.
ktl5005 is offline
post #7 of 22 Old August 12th, 2019, 05:02 PM Thread Starter
Member #268740
The antenna is standard on 2020 ride commands and can be added to the 19's. Without the antenna kit, you will use your phone tethered via bluetooth. This is how the ride commands worked on previous model years
The cable is not long enough to reach the roof, I don't think moving it 3 ft higher would make the much of a difference, your surroundings would have more to do with it (trees, hills, rocks, valleys etc.)
post #8 of 22 Old August 12th, 2019, 05:22 PM
GPS GURU
Member #269632
My salesman [email protected]!$&
post #9 of 22 Old August 14th, 2019, 05:25 PM
GPS GURU
Member #269632
My kits came in and I have an extra kit for sale if anyone needs it, please pm me
post #10 of 22 Old August 23rd, 2019, 10:36 AM
Vallone1990's Avatar
First Name: Anthony
My RZR: RZR XP Turbo S
Member #263456
View Vallone1990's Photo Gallery(0)
Everything besides the proprietary connection to the RC head unit looks like standard rf connections and antenna. Wonder how hard it would be to use a standard antenna to acquire this function. Could probably get a more sensitive antenna for a lot cheaper, just need to figure out how to attach to the proprietary connection. I can't imagine there's any software or hardware in this kit that would affect operation.
This ability was what I originally thought RC could do anyway when I bought my Turbo S, sort of a crap move to offer it later with a 150$ price tag... I think it was advertised when the Turbo S originally came out, but it just straight up didn't have this ability.
Vallone1990 is offline
post #11 of 22 Old August 23rd, 2019, 03:35 PM Thread Starter
Member #268740
The antenna itself is an off the shelf antenna, the part number is on the bag. The price was 45 bucks
I tried to look for the cable but it is pre terminated with the proper ends. I searched the cable manufacturer and couldn't find it
I'm sure you can find a cable and use some adaptors to make it work. Someone in the RF cable world might know what each end is called and it might make it easy to source a cable.
I didn't search real hard because frankly I already bought it from polaris
post #12 of 22 Old August 24th, 2019, 08:25 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
For approximately $70.00 this might work.
Antenna $60.00
https://www.mouser.com/ProductDetail...VkC7HIgQ%3D%3D
Pigtail $5.00
https://www.ebay.com/itm/Fakra-SMB-K...-/332256021397
extension $5.25
https://www.amazon.com/RP-SMA-Female...MGYQGJQ536WQG9
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #13 of 22 Old August 24th, 2019, 08:59 AM
First Name: Anthony
Member #263456
Originally Posted by CA 800 View Post
Nice! Sure as hell ain't $150 lol Normally I'd probably just buy the $150 part but imo this should have come with the Turbo S standard.
Also found the antenna here for $33
https://www.neobits.com/
post #14 of 22 Old August 24th, 2019, 11:21 AM Thread Starter
Member #268740
Awesome guys!!
Hope this helps others!!
post #15 of 22 Old August 25th, 2019, 07:32 PM
First Name: Anthony
Member #263456
deleted
Tags
group ride , ride command , v2v communication kit
