08 RZR 800 adding lights. Do I use switched ground? - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old July 30th, 2019, 01:08 PM Thread Starter
ToeKnee's Avatar
Member #271224
View ToeKnee's Photo Gallery(0)
Im adding a bunch of lights to my old but new to me 2008 RZR 800. From what I understand, Polaris chose to used switched ground on lighting / accessory circuits.
My question is, with the stuff that Im adding, am I better to keep that method going, or just wire it up traditionally switched hot and permanent grounds?
Am I better to keep the whole thing (original accessories plus my added ones) using constant 12 volts with switched grounds? Or have both concepts in play?
ToeKnee is offline
post #2 of 8 Old July 30th, 2019, 02:35 PM
slant911's Avatar
My RZR: 2019 XP Turbo
Member #269992
View slant911's Photo Gallery(0)
Re: 08 RZR 800 adding lights. Do I use switched ground?
Switched grounds? To my knowledge there are switched hot circuits...i.e. they go on with the ignition switch in the on position. Switched grounds is a new one on me.
But in hopefully answering the question I would put all accessories on switched circuits. That way if you forget to turn them off when you stop the engine the key will turn them off for you.
slant911 is online now
post #3 of 8 Old July 30th, 2019, 04:36 PM Thread Starter
ToeKnee's Avatar
Member #271224
As far as I can see from the wiring diagrams, the circuit (for instance, headlights) has +12 volts when the key is on. However, the lights dont turn on because the headlight switch has interrupted the ground wire. When you flick the headlight switch, the ground side is closed, the circuit completes and the lights turn on.
Normally, what I am used to is the ground side of the circuit is always closed, and the +12 volts side is switched.
For the record, every circuit I add will be fused and run through a relay. My question is just whether I should have the ground side run through the relay contacts, or the +12 volts side.
Do I wire things so it is consistent with the Polaris way, or do I wire the things I add up in the common non-Polaris way?
ToeKnee is offline
post #4 of 8 Old July 30th, 2019, 05:18 PM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
There's an accy wire under the dash. Tap into that. Be warned, don't add too many or too big a light. Your little stator can't hack it... Trying to run oem headlights, an amber led chase light, small light bar and a parker pumper makes my battery light flash at me at idle or low rpm. Have to turn off the parker pumper or lights when I'm going slower or pitting.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
post #5 of 8 Old July 30th, 2019, 05:50 PM Thread Starter
ToeKnee's Avatar
Member #271224
Thanks for the heads up. It already had a yellow top optima so there is a huge amount of reserve capacity, but I totally understand that the the 800 stator only puts out about 500 watts on a good day.
ToeKnee is offline
post #6 of 8 Old July 30th, 2019, 08:23 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Only the brake lights have constant 12v, and switched ground. This is because they wanted to use the brake light switched ground to also be switched ground for the starter solenoid (their version of neutral safety switch).
The tail lights have constant 12v (when key on), and constant ground, so tail lights are always on when driving.
Do yourself a favor, and replace tail lamps with LED bulbs. The factory incandescent bulbs will melt the housings.
I added a relay and rearranged the wires in the box harness connector so that brake lights have constant ground and switched power.
This was part of mods to add turn signals using factory tail lamp assemblies.
2014 800 LE w/EPS 50
CA 800 is online now
post #7 of 8 Old July 31st, 2019, 09:36 PM Thread Starter
ToeKnee's Avatar
Member #271224
Thanks for the info about the switched grounding only on tail lights. I was certain I saw the same thing on the headlight schematic, but Im research from my phone and its hard to trace on the small screen. Also, dont have the RZR with me at the moment to just go meter the harness.
With regard to running LED in the tail lights, isnt there some weird issue caused by the lower load or resistance over the incandescent bulbs? I know the polarity is of the socket is backwards (not an issue with incandescents obviously) and some LEDs wont work so you have to re-pin the sockets.
Any idea what particular bulbs you run / ran?
ToeKnee is offline
post #8 of 8 Old July 31st, 2019, 10:58 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Take a look at post #9 in:
https://www.rzrforums.net/rzr-570-sp...akelights.html
and verify your sockets with a meter.
The lower resistance(load) is only an issue with turn signal blinker, and RZR's don't have one.
