Clock keeps blinking 12:00. 2019 XP4 1000 Turbo - Polaris RZR Forum - RZR Forums.net
Forum sponsored by: Rockford Fosgate
post #1 of 8 Old May 27th, 2019, 10:20 AM Thread Starter
Kzneft's Avatar
My RZR: 2019 RZR4 Turbo
Member #68959
View Kzneft's Photo Gallery(4)
My 2019 RZR4 1000 turbo is only a few months old. I have reset the clock about a dozen times now, but as soon as I turn my RZR off, then back on it keeps blinking the 12:00 symbol again. It keeps time good as long as it's running, but not after turning off. Followed the instructions numerous times but no luck. Dealer has no answer either. Anyone else seen this?
Kzneft is offline
post #2 of 8 Old May 27th, 2019, 12:49 PM
yetifed's Avatar
First Name: Hall
My RZR: 2017 XP 4 Turbo
Member #51910
View yetifed's Photo Gallery(0)
Re: Clock keeps blinking 12:00. 2019 XP4 1000 Turbo
I had the exact same issue, shockingly enough I disconnected both battery leads for a few minutes and that solved the issue. sounds to simple to be true but it worked. I even posted a video on here of mine doing it, I had the battery disconnect by accident while working on something else and when it was reconnected, no more issues.
Hope this helps.
yetifed is offline
post #3 of 8 Old May 27th, 2019, 05:26 PM Thread Starter
Kzneft's Avatar
Member #68959
I will go try that right now! I will let you know the outcome.
Kzneft is offline
post #4 of 8 Old May 27th, 2019, 05:50 PM Thread Starter
Kzneft's Avatar
Member #68959
Just tried it, but unfortunately that didn't work on mine.
Kzneft is offline
post #5 of 8 Old May 27th, 2019, 06:08 PM Thread Starter
Kzneft's Avatar
Member #68959
I have disconnected the battery, and will let sit overnight, and try again. Another thing I am wondering. If you scroll down to where you see it say VOLTS on your screen, does yours say 0 volts? Mine says 0 volts whether it is running or not. Does your do the same thing? I am wondering if this is related to the clock issue. I have attached a picture.
Kzneft is offline
post #6 of 8 Old May 28th, 2019, 05:51 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Try unplugging and plugging back in the display.
On my 18, the clock worked fine until I unhooked the dash to do some wiring, then when i got everything back together, my clock was doing the same thing yours is, I just wrote it off as I'd need to change the whole display to fix it, which wasn't worth it to me, it was that way for about 5 months. Low and behold, I unhooked everything again a few weeks ago, and when i plugged it all back in, the clock works like normal now. Could just be a stubborn pin in that plug I think. My voltmeter always worked fine, but could very well be a similar issue.
2018 XPT4 - Bailey
RWB713 is online now
post #7 of 8 Old May 28th, 2019, 05:59 AM Thread Starter
Kzneft's Avatar
Member #68959
I will give that a try this afternoon. Thank you!
Kzneft is offline
post #8 of 8 Old May 28th, 2019, 03:45 PM
Oldbiker's Avatar
My RZR: 2017 900 S
Member #69733
View Oldbiker's Photo Gallery(0)
I've always been told to start by checking all the ground wire connections - one that is loose or corroded will act differently when the machine is vibrating than when its not running.
2017 900 S - 28x10 Sedona Rock-A-Billys on 14x7 wheels.
Oldbiker is offline
