MTX Audio Ride Command Adapter - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By mtx_jesse
post #1 of 9 Old December 1st, 2017, 11:56 AM Thread Starter
mtx_jesse's Avatar
Member #213817
View mtx_jesse's Photo Gallery(0)
We now have an adapter available which will allow you to pull the audio signal from the Ride Command source unit and send it to other aftermarket amplifiers and speakers when adding to the system.
https://www.mtx.com/polaris-ridecomm...-range-adapter
Dstew619 likes this.
mtx_jesse is offline
post #2 of 9 Old December 1st, 2017, 12:14 PM
kdjmobiledj's Avatar
First Name: Kevin
My RZR: 2017 Razor XP 1000
Member #225985
View kdjmobiledj's Photo Gallery(0)
Re: MTX Audio Ride Command Adapter
Where can I buy this at ? I thought the ride command already had outputs to do this?
kdjmobiledj is offline
post #3 of 9 Old December 1st, 2017, 12:36 PM Thread Starter
mtx_jesse's Avatar
Member #213817
The Ride Command source has an output but this adapter uses that output and adapts the plug style to the more common RCA jack that can be used to add aftermarket amplifiers to power additional speakers.
You can purchase it through any authorized MTX Audio retailer or directly from MTX.com here - https://www.mtx.com/polaris-ridecomm...-range-adapter
post #4 of 9 Old December 1st, 2017, 01:37 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Product pic? And your price point of $39.95 is higher than your competition by a good amount. I would adjust if you guys can to be more competitive or is there an advantage to yours over what is already out there?
Dstew619 is offline
post #5 of 9 Old December 1st, 2017, 01:42 PM Thread Starter
mtx_jesse's Avatar
Member #213817
It was just put up on the website today so they are working on getting a pic uploaded to the page as well. I personally have not seen the adapter yet but I do know it is higher priced than other competitive models. More details to come ASAP.
post #6 of 9 Old December 1st, 2017, 02:04 PM
brtnshrdr's Avatar
My RZR: '17 RZR XP1000 Highlifter Edition
Member #128345
View brtnshrdr's Photo Gallery(0)
Will this function any different than the MB Quart one? rc1-2rca-f
Or should I use 2 of those and 1 of yours? (MTX site says this is for output 3, while that mb-quart one seems to reference output 1 and 2)
Or do I only need one of these?
[SOLD] '15 RZR XP1000 Highlifter Edition, 5" lift, MSA 16" M22's on 34"x10" Motoboss tires
brtnshrdr is offline
post #7 of 9 Old December 4th, 2017, 02:34 PM
brtnshrdr's Avatar
Member #128345
Any updates on these questions?
post #8 of 9 Old December 5th, 2017, 05:53 AM Thread Starter
mtx_jesse's Avatar
Member #213817
As I understand it, the Ride Command system has 3 pairs of preamp outputs. 1 pair of preamp outputs are for channels 1 and 2. Another pair of preamp outputs are for channels 3 and 4. And the last pair of preamp outputs are for channels 5 and 6. Each preamp output has non-adjustable crossover points programmed into the source unit.
Channels 1 and 2 - Fixed high pass crossover that starts to roll off at 200Hz
Channels 3 and 4 - Fixed high pass crossover that starts to roll of at 200Hz
Channels 5 and 6 - Fixed low pass crossover 48dB/octave slope at 100Hz
We recommend using preamp output 3 (channels 5 and 6) to get a little more low end. These channels will provide more midbass frequencies than the high pass crossover channels.
Once you get the audio signal out of the Ride Command source unit and have adapted it to RCA's, you can split that signal as many times as you need. As I understand it, the only reason you would need more than 1 adapter is if you were running more than 1 amplifier and wanted to send the low pass audio signal to one amp and the high pass audio signal to another.
Hope this makes sense.
post #9 of 9 Old February 15th, 2018, 07:07 PM
Rileyrasmussen's Avatar
First Name: Riley
My RZR: 2017 XP 1000 4 turbo
Member #238201
View Rileyrasmussen's Photo Gallery(0)
I just had the dealer install the ride command on my 2017RZR Turbo with the mtx stage 4 system and it sounds terrible! I have virtually no bass and the front and rear speakers are on one channel. When I open up the fade and send sound to only the front speakers there is no sound, but all 4 speakers come on when move the dial to the rear speakers. Not sure if this was installed correctly. Any advice?
Rileyrasmussen is offline
Tags
bluetooth , mtx , mtx audio , ride command
Ride command audio colts66 Lighting, Stereo and Electrical 0 July 26th, 2017 12:00 PM
MTX Overhead Audio Pod Sshsjd10 Polaris RZR Parts For Sale 0 May 1st, 2016 10:26 PM
