Adding to Ride Command audio - Page 7 - Polaris RZR Forum - RZR Forums.net
 25Likes
post #91 of 119 Old February 15th, 2018, 07:27 PM
Wisk's Avatar
First Name: Shawn
My RZR: 2016 XP1000
Member #84224
View Wisk's Photo Gallery(4)
Re: Adding to Ride Command audio
I've found that disconnecting and connecting while testing your set up changes the output level. Once its connected and left that way, it seems to solve the problem.
Wisk
Wisk is offline
post #92 of 119 Old February 15th, 2018, 07:31 PM
Xtoyz17's Avatar
First Name: Shawn
My RZR: 2016/2018 RZR XP Turbo
Member #25099
View Xtoyz17's Photo Gallery(0)
Wisk
I ended up ordering a new ground loop isolator and that seems to have solved the problem. Now if only there was a good way to heat shrink and seal everything to eliminate future headaches!
Xtoyz17 is offline
post #93 of 119 Old February 15th, 2018, 08:24 PM
Rileyrasmussen's Avatar
First Name: Riley
My RZR: 2017 XP 1000 4 turbo
Member #238201
View Rileyrasmussen's Photo Gallery(0)
I just had the dealer install the ride command on my 2017RZR Turbo with the mtx stage 4 system today and it sounds terrible! I have virtually no bass and the front and rear speakers seem to be sharing one channel. When I open up the fade and send sound to only the front speakers there is no sound, but all 4 speakers come on when move the dial to the rear speakers. Not sure if this was installed correctly. Any advice?
Rileyrasmussen is offline
post #94 of 119 Old February 23rd, 2018, 05:16 PM
TSMITH2012IM's Avatar
Member #236833
View TSMITH2012IM's Photo Gallery(0)
I posted previously in this thread about the difficulties I am was having getting 2018 ride command edition to work with additional amps. I ordered the mbquartz adapters and the volume was really low. Someone mentioned get isolators but that didnít seem to help either. From what MBquartz told me, the ride command is a balanced audio connection and there are no amps that will work properly. I ended up ordering a Fosgate line level converter and connecting the output of the factory 50w amp to it. The Fosgate RFHLC seems to have done the trick and I didnít have to connect the ground wire to eliminate any noise. I have two amps, the mbquartz 400.1 for the SSV works sub bell sure with a kicker 10 and the 400.2 to drive the factory door speaker and a wetsound core 6. I havenít decided if I am going to use the sound bar, the door speakers sound really good with the new amp.
Hopefully this will helps others trying to enhance the factory ride command edition.
TSMITH2012IM is offline
post #95 of 119 Old February 25th, 2018, 11:10 AM
Roger Jones's Avatar
Member #238274
View Roger Jones's Photo Gallery(0)
I just added the adapter I ordered from Wisk..
Great looking workmanship and included an isolator for the horrible hum i was getting in my Wetsounds ultra 10 soundbar..
I really had my doubts but his adapter took care of my problems..
THANKS WISK!!
On another note, when you guys try something and lose the sound from the ride command plug, I've had to unhook a battery cable for a few seconds to get the sound back for another test try..
I worked on this for quite some time before i ordered the adapter from WISK, sure glad i did.
My search for a solution led me to this forum..
Thanks guys for everyones input to their similar issues and solutions..
Thanks WISK for your help..
Anyone make a sub enclosure that fits behind the seat for an 18 turbo?
Soundbar is not enough bass for me..
Just an old fart wanting to have fun!
Roger
Wisk likes this.
Roger Jones is offline
post #96 of 119 Old March 7th, 2018, 11:49 AM
taxxin's Avatar
My RZR: '16 XPT, '18 900S, '17 170
Member #211905
View taxxin's Photo Gallery(0)
Just got a call from my Polaris CSR that was working with me on my Ride Command audio issues (popping at shutdown and intermittent noise) and she told me that there is a new service bulletin out for the audio systems connected to the RC head unit. It includes replacing the amplifiers in the pods and the amplifier for the door speakers to new versions that are now compatible with the RC system. I do not yet know if they have a firmware update for the RC head unit to add an On/Off button for the audio system, but if these amps work at least that will solve the most annoying part of spending over $8k on the two systems I currently have.
For those of you with the stock set up using the RC head end with door kits and/or pods (all MB Quart) the service bulletin # is: ZSA-18-02
I called my dealer and he looked it up and it gives him at least four new part numbers so he is researching it all for me and is going to order the parts for both RZRs so with a little luck the audio will begin to function as it should. He did tell me that this fix is for the doors and pods only, there is nothing shown for the subwoofer, but I don't believe it was an issue since the noise is all higher frequency and therefore probably above the range that would be audible on a subwoofer. If you have the same issue and haven't trashed your stock components for aftermarket audio, you might want to get on the horn to your dealer and get the ball rolling because knowing Polaris, they are likely to run out of these upgrade kits long before the demand subsides!
801Ag likes this.
taxxin is offline
post #97 of 119 Old April 8th, 2018, 08:08 PM
gixxeraaron's Avatar
First Name: Aaron
My RZR: 2014 RZR XP 1000
Member #60730
View gixxeraaron's Photo Gallery(1)
How do I order the adapters from Wisk?
DWSrzr likes this.
gixxeraaron is offline
post #98 of 119 Old April 20th, 2018, 09:04 PM
Craigtn's Avatar
First Name: Craig
My RZR: 800 Dynamix 4
Member #34851
View Craigtn's Photo Gallery(0)
Any input on a Dynamix radio. I bought the swamp donkey harness with out reading that it doesnít work itís most Dynamix. Tried 3 Amps with little to no sound. I looked at wire colors and they appear to be correct on my harness.
Any ideas. Wanting to run a 4 channel amp with 2 speakers in fire wall for now and more later.
Rzr's 800 & Dynamix 4
Diesels: LB7 & Cummins
Craigtn is offline
post #99 of 119 Old April 22nd, 2018, 05:55 PM
tmaxxman21's Avatar
First Name: Ryan
My RZR: 2015 900S
Member #1426
View tmaxxman21's Photo Gallery(6)
Hey guys, hate to bring a dead thread back, but I was messing with a buds 18í ride command. Adding a amp and sub. Not wanting to wait for the correct harness to come in, I cut the wires at ďamp 3Ē connecting both positive together, and neg together. Then connecting those to the amp. I ran my amp blue wire to the acc terminal under the hood.
We are not getting a whole lot of action out of the sub currently, amp is on, sub isnít doing much. I wondering if the blue or brown wire I left connected in the factory 8 pin connector needs to be run somewhere. Any ideas
2016 rzr xpt4
2015 rzr xp1k
2015 rzr 900S
2014 rzr 900xp sold
2013 rzr 800s sold
2008 rzr 800 50" sold
Bikeman Performance, CageWrx, Tricled, Booger Whips
tmaxxman21 is offline
post #100 of 119 Old April 25th, 2018, 12:46 PM
Craigtn's Avatar
First Name: Craig
Member #34851
The harness i got from wisk with the 3.5 worked great. I also used a 3.5 to rca back to amp and it worked and sounded great.
Craigtn is offline
post #101 of 119 Old December 18th, 2018, 06:03 PM
Xtoyz17's Avatar
First Name: Shawn
Member #25099
Wisk do you sell adapters?
Xtoyz17 is offline
post #102 of 119 Old December 18th, 2018, 08:23 PM
First Name: Riley
Member #238201
I had that issue, but what I found out through MTX is the dealer did not ground the system back to the battery. Once MTX replaced the rca connector switch the proper connectors and grounded it back to the battery my system sounds awesome and no buzzing.
post #103 of 119 Old December 21st, 2018, 09:24 AM
SSV Sales
Greg-SSVworks's Avatar
First Name: Greg
My RZR: Turbo -4
Member #30620
View Greg-SSVworks's Photo Gallery(5)
Sorry to hear you guys are having some much trouble with adding audio to the Ride Command.
We currently offer complete Plug n Play kits to fit just about any budget for ALL vehicles with Ride Command.
2015-2018 RZR 900S, 1000, Turbo models.
https://www.ssvworks.com/product/pol...r-Ride-Command
2018 Turbo S 2019 + RZR 1000 and Turbo
https://www.ssvworks.com/products/polaris/rzr-turbo-s
Please let me know if we can help.
oneshotkyle likes this.
SSV Works Inc.
The original since 2006
818-991-1778
www.SSVworks.com
[email protected]
Greg-SSVworks is offline
post #104 of 119 Old December 28th, 2018, 08:47 AM
colts66's Avatar
First Name: jeff
My RZR: 2017 XPT
Member #1945
View colts66's Photo Gallery(0)
Hey greg I need a price for ride command front pod system. Of course Forum discount... LOL.
colts66 is offline
post #105 of 119 Old December 28th, 2018, 11:30 AM
SSV Sales
First Name: Greg
My RZR: Turbo -4
Member #30620
Two speaker SSV speaker kit:
https://www.ssvworks.com/product/pol...nd-Play-system
Two speaker Kicker speaker kit:
Please use coupon code RZF-10 for a 10% forum discount
SSV Works Inc.
818-991-1778
www.SSVworks.com
[email protected]
Mid-South Riders 2nd Anniversary Ride - January 27-29, 2017 - Arkansas CentralArk_RZRbacks Local Rides and Events 9 January 27th, 2017 07:06 AM
Jan 1st, 2017 New Near's Ride, Central City, Colorado wkayl Southwest / Arizona 24 January 4th, 2017 08:25 AM
2015 Highlifter Ride Improvements WARPARTY36 Shock Therapy 13 May 16th, 2016 04:47 PM
Looking to Ride Saturday 4-23 Sunday 4-24 Colorado BernieZ66 RZRForums Members' Rides 43 April 26th, 2016 01:28 PM
North Glamis RZR Forum Ride Schedule of Events FJK Glamis North Hot Springs Resort Ride 6 March 17th, 2016 08:04 AM
