Power steering issue after light bar install - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old October 10th, 2016, 02:51 PM Thread Starter
enigma94's Avatar
Member #147721
View enigma94's Photo Gallery(0)
Me and my brother just installed our light bars on our 16 XPT's and now we have intermittent issues with power steering not working right when we turn the cart on. If we turn the cart off then back on the power steering starts working... His is doing it more than mine but both are having issues.
We ran 10ga power 14ga ground from the battery to the terminal on the firewall. Installed our hot and ground leads from our relay to the same post and then installed a wire from the switch to the accessory terminal to light up the switch when not in use.
Is there something wrong with how we wired them that's causing the power steering to not work right at start up???
enigma94 is offline
post #2 of 7 Old October 10th, 2016, 08:14 PM
claas's Avatar
Member #85471
View claas's Photo Gallery(0)
Re: Power steering issue after light bar install
If you take the wires off for the lightbar does the power steering function properly then and it's only when you hook your wiring up? Wiring sounds like it was ran fine
claas is offline
post #3 of 7 Old October 11th, 2016, 12:52 AM
Jjwheeler2's Avatar
Member #138641
View Jjwheeler2's Photo Gallery(0)
Only issue I see is you should have run same size ground as you did power.
Even that though shouldn't be messing with the power steering.
Jjwheeler2 is offline
post #4 of 7 Old October 11th, 2016, 07:05 AM
Weerdone's Avatar
First Name: Steve
My RZR: 2019 RZR XPT
Member #127465
View Weerdone's Photo Gallery(0)
I know after the ignition is turned on, if you wait too long to start it will disable the Power steering. Take notice if the problem is mainly after sitting with key on looking at lights, or listening to radio. My 16' after i sit with key on to keep lights lit up it will shut off the power steering, then i need to cycle key off and back on and it works fine.
Weerdone is offline
post #5 of 7 Old October 11th, 2016, 08:54 AM
DogRunner2's Avatar
Member #137545
Yep. It's in the manual.
2018 XP1K LE
DogRunner2 is offline
post #6 of 7 Old October 11th, 2016, 02:52 PM
RIPPED_RZR's Avatar
Member #137985
View RIPPED_RZR's Photo Gallery(0)
I turn the key and let it prime and then turn it on. It happened to me twice on Sunday. Never happened before we installed the light bar. It's happened on cold starts and warm starts.
RIPPED_RZR is offline
post #7 of 7 Old October 11th, 2016, 02:53 PM
RIPPED_RZR's Avatar
Member #137985
I'm enigmas brother by the way lol
LED light bar whistle Scott M General RZR Discussion 10 October 3rd, 2016 09:39 AM
XP 900 power steering install question Longrange223 RZR XP 900 4 May 12th, 2016 05:09 AM
2012 800 Power Steering Issue Chris073 RZR 800 Specific Discussion 1 April 7th, 2016 01:15 PM
Power steering startup issue MLESa7990 RZR 900 - 50'' Trail Models 7 April 2nd, 2016 11:31 AM
OV 17.6 - Power Steering and Check Engine light RZR 1000 RZR_BC RZR XP 1000 3 March 21st, 2016 06:22 PM
