CHEAP carrier bearing fix for all RZRs - Polaris RZR Forum - RZR Forums.net
 27Likes
post #1 of 45 Old June 1st, 2017, 12:30 PM Thread Starter
HawkEng's Avatar
First Name: Jason
My RZR: Turbo Apex RZR & Z1 RZR
Member #747
View HawkEng's Photo Gallery(0)
Here is an easy and CHEAP fix for the carrier bearing in all the RZRs with 2 pc. driveshafts. You will need to remove the carrier bearing from the RZR to do the fix. Your carrier must have good rubber inside it. This fix also works on the Toyota carrier that some use.
First, we find it easiest to twist the carrier sideways to walk it off the bearing once you have the 2 shafts separated. This will leave the actual bearing on the driveshaft which you will have to knock off with a hammer.
Second, drill some holes around the outer perimeter of the carrier housing to squirt 100% silicone in. This will fill the void pocket that makes the rubber so soft. It will harden after a few days and be like a solid piece of rubber. This will take out all the play, but keep the harmonics from transferring. You will be able to install it after it sets up over night though. Just give it a few days before riding the RZR.
Third, remove the 2 rings from the old bearing. Obtain a new 6006-RS bearing from Ebay. They are cheap! We have found that these cheap bearings hold up fine. BUT, you need to pop out one of the rubber seals and pack it with waterproof grease. These hold up to Z1 power as well as the mud and water we run in. Install the 2 rings from the old bearing. Install the bearing back in the rubber carrier.
Final, put the shafts back in the tunnel. install the carrier on the shaft. We use a short piece of pipe to tap the bearing on the shaft. It must just clear the OD of the shaft and tap on the inner race of the bearing. This is important that it goes all the way on. Now make sure you have the driveshafts phased correctly. The new shafts only go together one way as they have a master spline.
Hope this helps out and puts some money back in your pocket. No need for those expensive carriers.
ID:	429897   Click image for larger version
ID:	429905   Click image for larger version
I specialize in APEX and Z1 conversion kits for the 800. Z1 kits for the 900xp, XP1000, and 1k Turbo. We have a Z1 waterproof belt cover too.
573-579-8295. Check out our custom coach builds too. www.hawkengineering.com.
HawkEng is offline
post #2 of 45 Old June 1st, 2017, 08:23 PM
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
Dang, great info!!! Thanks!
btrshoes is offline
post #3 of 45 Old June 2nd, 2017, 04:16 AM Thread Starter
HawkEng's Avatar
First Name: Jason
Member #747
Re: CHEAP carrier bearing fix for all RZRs
Been doing it this way for over 3 years with no failures since before anything came out. It works well.
HawkEng is offline
post #4 of 45 Old June 2nd, 2017, 05:08 AM
Larsonator's Avatar
My RZR: 2015 900S
Member #73551
View Larsonator's Photo Gallery(0)
Do you know which models need the driveshafts phased, and which have the master spline?
Larsonator is offline
post #5 of 45 Old June 2nd, 2017, 05:16 AM
Zonkie's Avatar
First Name: Todd
My RZR: 2015 900S
Member #188473
View Zonkie's Photo Gallery(0)
I'd sure love to see a video doing this.
Zonkie
Zonkie is offline
post #6 of 45 Old June 3rd, 2017, 03:14 PM
wlst101's Avatar
First Name: Vince
My RZR: 2013 XP900
Member #75489
View wlst101's Photo Gallery(0)
Sub
wlst101 is online now
post #7 of 45 Old July 18th, 2017, 09:52 AM
WFOWS6_IL's Avatar
Member #69651
View WFOWS6_IL's Photo Gallery(0)
Appreciate the info. Curious though what your way is to remove the two rings.
WFOWS6_IL is offline
post #8 of 45 Old July 18th, 2017, 11:05 AM
RZRdavid's Avatar
First Name: David
Member #161625
Great info, thanks !!!
RZRdavid is offline
post #9 of 45 Old July 18th, 2017, 04:30 PM
roadiestar's Avatar
First Name: Tom
My RZR: 2017 xp1000 white lightning
Member #2518
View roadiestar's Photo Gallery(0)
I did it to mine in the car just drilled one hole and filled up with silicone. 600 miles so far so good.
ol38y likes this.
roadiestar is online now
post #10 of 45 Old July 18th, 2017, 04:34 PM Thread Starter
HawkEng's Avatar
First Name: Jason
Member #747
Remove the rings with screwdriver and hammer. We usually have it out anyways to change to a new bearing.
HawkEng is offline
post #11 of 45 Old August 2nd, 2017, 08:43 AM
SNWMBL's Avatar
First Name: Caleb
Member #207521
I may do this to mine since it's new.
2017 RZR XP4 1000
SNWMBL is offline
post #12 of 45 Old August 2nd, 2017, 01:22 PM
roadiestar's Avatar
First Name: Tom
Member #2518
850 miles still good
1800 miles still good
post #13 of 45 Old August 2nd, 2017, 06:13 PM
Asaszn's Avatar
First Name: Josh
My RZR: 2015 RZR S 900
Member #9
View Asaszn's Photo Gallery(0)
I take good care of my 2015 900s and don't beat (too) hard on her but my bearing went on a recent ride. Good fox here!
2015 RZR S 900
Asaszn is offline
post #14 of 45 Old August 2nd, 2017, 06:48 PM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Did mine when new. 1200 miles all good so far.
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #15 of 45 Old August 2nd, 2017, 07:44 PM
Addicted
CFDWheeler's Avatar
First Name: Steve
My RZR: 17' White/Reflex Blue XP1k
Member #6186
Feedback Score: 13 reviews
View CFDWheeler's Photo Gallery(0)
Someone should make a DIY video of how to do it while still in the vehicle.
2017 1000XP. White w/ Reflex Blue
FUTV UHMW Full skid package; SATV radius rods,
Viper Elite 5K Wide on Bad Dawg front bumper, SATV rear bumper
SSV Works Stereo; Axiom Roof, 30" front LED radius bar
RacerTech Heavy Springs, 32" Carnivores on STI HD9's
XXL Front fenders with Mudbuster Max rear.
IAFF LOCAL 38 Covington KY
CFDWheeler is offline
Carrier Bearing Dro727RZR RZR S 900 20 March 10th, 2017 02:30 PM
How to replace Carrier Bearing? XP4 1000 Metatrox Engine and Drivetrain 5 February 20th, 2017 05:10 PM
12 XP4 900 Carrier Bearing Install WV23RZR4 RZR XP 4 900 Specific Discussion 3 October 27th, 2016 05:22 PM
We sell Sandcraft Carrier Bearing $240 Free Shipping and 48 RZR Giveaway entries UTV Family Engine and Drivetrain 0 July 14th, 2016 10:00 AM
