What is plugging up my gas tank????? - Page 3 - Polaris RZR Forum - RZR Forums.net
post #31 of 36 Old May 28th, 2010, 12:25 PM
kyost's Avatar
My RZR: 2011 RZR 800 S
Member #10906
View kyost's Photo Gallery(0)
Re: What is plugging up my gas tank?????
Could it be a plugged vent not letting air in, causing the tank to suck together as it uses the gas???
kyost is offline
post #32 of 36 Old May 28th, 2010, 02:21 PM
speedy188's Avatar
First Name: Wyatt
My RZR: 2008 LE Red S-Wheels, Vent Racing Rear seat and Cage, DFR Harnesses
Member #9533
View speedy188's Photo Gallery(0)
Looks to me like the tank was molded improperly. Some left over plastic in the hole blocking the inlet.
2008 LE Red HID lights
Vent Racing Rear cage, Seat and Soft top
DFR Harnesses up front DJ Harnesses in the Rear
+5 Long Travel kit and S-Shocks and S-Flares
Viper 3000# Winch
TMW Offroad Bumper 12" LED Bar Xmitter
UTV Crap Gas Tank Shield
SSV Works Stereo
speedy188 is offline
post #33 of 36 Old May 28th, 2010, 03:39 PM
2010 RZR-S 130 hp Weber
sjm01's Avatar
First Name: Shawn
My RZR: 2010 RZR S
Member #10432
View sjm01's Photo Gallery(4)
Thats too funny!!! Nice one Bagman..
sjm01 is offline
post #34 of 36 Old June 1st, 2010, 04:49 AM
Brush buster's Avatar
My RZR: 2009 RZRS
Member #11803
View Brush buster's Photo Gallery(0)
Ok guys here is an update on my crushed tank.
KYOST was correct in his assumption.
I was wrong about the tank being pushed in from backing over a chunk of wood.
It turns out the gas vent was crushed beneath the battery box compleatly closing it off!
Yesterday I siphoned the gas out of the tank then I put the rzr in the sun with the seat out to warm up the gas tank.
Then I hit the vent with compressed air and the tank popped out some.
So I took a hairdryer and CAREFULLY WARMED the bottom of the tank and gave it some more air, and tada!
Yes it was rather spooky to preasurize the tank and I'm not saying anyone should try it, (official disclaimer) but now the float is no longer jammed up against the filler tube and the guage works again!
To finish it off I ran a new vent line to the tank.
Jackalope I'm sure you have fixed your problem, but If you haven't, check your gas tank vent hose, I bet you have a plugged vent line and your fuel pump pulled a vaccumm and crushed the tank.
Gary
2009 RZRS
1996 HD FLSTC
2006 cannedham outlander 400 XT
Brush buster is offline
post #35 of 36 Old September 22nd, 2010, 08:20 AM
My RZR: 2009 RZRS
Member #11803
Just a quick follup on my gas tank.
After poping the tank out and replacing the vent tubing I have had no more problems.
Anyone with a float stuck up against the filler tube needs to check the vent hose.
Gary
2009 RZRS
1996 HD FLSTC
post #36 of 36 Old September 22nd, 2010, 09:49 AM
Tedram's Avatar
First Name: Ted
My RZR: 2011 900XP
Member #15163
View Tedram's Photo Gallery(9)
That is why this Forum is so valuable-- great story. I'm checking my vent line tonight..
2011 RZR 900XP with a bunch of bolt on stuff and the POPO HO kit...
Tedram is offline
Tags
float , fuel tank , gas tank
Leaking Gas Tank!! grandscapesllc General RZR Discussion 19 June 17th, 2013 04:11 PM
How far can you go on a tank of fuel ? LvDirtJunky Engine and Drivetrain 40 May 8th, 2009 01:20 PM
Anyone had a gas tank split yet? Realbadlarry General RZR Discussion 0 October 30th, 2008 06:13 PM
gas tank relocation? biohazard58 General RZR Discussion 1 September 9th, 2008 06:17 PM
Anyone Have A Fuel Tank They Will Sell Me?? Bigbadfords General RZR Discussion 4 August 17th, 2008 05:27 PM
