no videos on youtube of an oil change? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old June 1st, 2012, 11:28 AM Thread Starter
C.J.'s Avatar
Member #35813
View C.J.'s Photo Gallery(0)
cant believe there are no videos of a diff oil or regular oil change on youtube. anyone have any?
2009 RZR 800
28 outlaws
3" Catvos
Front/Rear Bumpers
HID Lights
Snorkel
C.J. is offline
post #2 of 9 Old June 1st, 2012, 11:32 AM
bradlineberry's Avatar
First Name: brad
Member #28901
View bradlineberry's Photo Gallery(0)
Remove the oil drain plug.
Drain the oil.
Replace the plug.
Change your oil filter.
Add 2 quarts oil.
Crank it up let it idle turn it off check it again.
Or better yet read your manual
Sent from my Motorola Electrify using Tapatalk 2
bradlineberry is offline
post #3 of 9 Old June 1st, 2012, 11:33 AM
Mattshs2005's Avatar
My RZR: 2009 RZR 800 EFI
Member #27004
Feedback Score: 4 reviews
View Mattshs2005's Photo Gallery(0)
Re: no videos on youtube of an oil change?
I used the service manual that I downloaded for free. Pretty easy with lots of pics. I changed every fluid minus the coolant.
Mattshs2005 is offline
post #4 of 9 Old June 1st, 2012, 04:11 PM
dunerider814's Avatar
My RZR: greeeen
Member #3816
View dunerider814's Photo Gallery(0)
my friend saw a video where they took a vacuum pump and sucked the oil out of the engine case threw the dip stick tube. we bought a manual vacuum pump from Lowes, stuck the hose down the dip stick tube, pumped up the vacuum, unbelieveable it worked great. no messing with drain bolts or oil all over the skid plate dripping on the floor in your garage. pump was about $30 and worth every penny. I use the same pump to drain my powerstroke fuel injector oil pump. I can change my oil in 5 min. more time to
It's Miller Time
dunerider814 is offline
post #5 of 9 Old June 1st, 2012, 11:32 PM
JonnyPilot's Avatar
My RZR: 2011 Red and Black Robby Gordon Edition RZR4
Member #32389
View JonnyPilot's Photo Gallery(0)
Did the same to mine today. Sucked it dry with the Liquivac from Lowes. Getting at the oil filter wasn't so much fun, but once I got the oil filter wrench from Autozone for $6 it became much more possible. Could also go with the K&N filter (it has a removal nut on the end of it).
JonnyPilot is offline
post #6 of 9 Old June 1st, 2012, 11:37 PM
mxking03's Avatar
Member #38283
View mxking03's Photo Gallery(0)
i also tried to look for videos on youtube, but i need to know how to change the other fluids, and no i dont have a manuel, maybe i need to buy one
mxking03 is offline
post #7 of 9 Old June 2nd, 2012, 12:00 AM
JonnyPilot's Avatar
Member #32389
Look up TeamHog on here:
Polaris RZR Forum - RZR Forums.net - View Profile: teamhog
He's got links to some manuals in the About Me section. Hope that helps.
post #8 of 9 Old June 2nd, 2012, 01:23 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Yup, getting the service manual for your RZR is one of the things you should do the day you buy the machine.
Read through the maintenance sections, make notes in the margins...like you need a 6mm allen head socket to remove the drain plug.
Go by the dealer and buy a few spare drain plug washers.
After you drain the oil from the pan, raise the front of the RZR about 6" and let the oil filter drain. While the front is up, remove and replace the filter. Yeah, getting to the filter can be a pain, so get a pair of Channel Lok filter pliers...then its easy.
Pirate
Pirate is offline
post #9 of 9 Old June 3rd, 2012, 07:49 PM
switzomatic's Avatar
Member #38370
View switzomatic's Photo Gallery(0)
Try partshark.com for a service manual. I downloaded a manual free off there. Your owner's manual will show all the locations of the fill/drain plugs. I think they are available free online from polaris or a good dealer will give you one. I have found the best/cleanest way to change out the fluids is to remove the factory skid pan. Also, for filling I picked up these cool filler tubes from walmart and some one quart spray bottles. The filler tubes screw on to the bottles and they have a twist/lock so you don't waste any fluid and they work great! Got one each for the front diff, rear diff, and tranny/transfer case.
18 RS1-many mods to come
16 HL Sportsman 1000-way too much done
16 RZR 570-snorkelled & some accessories
18 Anniversary Edition Sidewinder Turbo
16 3/4 Ton Silverado to haul them all
switzomatic is offline
YouTube Help! rzr-madness RZR and UTV Video's 4 January 13th, 2011 11:27 AM
How do I post YouTube videos? CRAWLR Community Help 5 March 11th, 2010 04:46 PM
YouTube Videos guy48065 RZR and UTV Video's 31 January 25th, 2010 03:10 PM
Sweet Youtube Videos rzrgrl General RZR Discussion 5 May 15th, 2008 08:18 PM
