quick question on dead Battery - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 24 Old June 1st, 2012, 12:07 PM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Re: quick question on dead Battery
Shorai batteries are awesome. Not only do you save a ton of weight, but you also get the benefits of a 2 year shelf life!!!
Nate
Alba Racing
[email protected]
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #17 of 24 Old June 1st, 2012, 02:52 PM
Pirate's Avatar
First Name: Stuart
Member #3677
Sigh...well OK, where do I sign up to get a free one to try????LOLOL
Pirate
Pirate is offline
post #18 of 24 Old June 2nd, 2012, 04:54 PM
rl06's Avatar
First Name: Anthony
My RZR: 2009 rzr 50"
Member #11944
View rl06's Photo Gallery(0)
so here is a probuly stupid question but will the rzrs stay running if u remove the battery while it is running?
rl06 is offline
post #19 of 24 Old June 2nd, 2012, 08:50 PM
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
If you have a 2011 its possible that the circuit breaker that controls the fan that is located between the seat pan and the skid plate in the wiring harness right below the battery is sticking open causing a drain to the battery. Drop the skid and check the circuit breaker. Alot of people are having problems with them . needs to be relocated up higher to keep it dry. I never thought about it creating a battery drain but it has been brought to my attention my a couple of members who had been having the same issue as you and after replacing it and moving it higher havent had another issue. Chaeap and easy to do. Even if its not your problem it still needs to be done to head off a furture fan problem. may eleminate two problems at once.
Magicmantx is offline
post #20 of 24 Old June 2nd, 2012, 08:57 PM
Magicmantx's Avatar
First Name: Bruce
Member #20584
One way to check battery is to take it out and charge it. Check voltage with a volt meter . Check it again and see if it is staying charged. Also an easy way to check if there is a drain on the battery is to turn off the key. Disconnect the ground wire and touch the ground to the battery and see if you get a spark. With the key off there should ne no spark. If you get one something is drawing power and running the battery down. If the battery loses volts disconnected then its just a bad battery.
post #21 of 24 Old June 3rd, 2012, 07:28 AM Thread Starter
Darkstone's Avatar
My RZR: RZR S
Member #36212
View Darkstone's Photo Gallery(0)
Checked the battery yesterday with a meter. 11.9 volts just sitting. 8.6 when the key is turned. (did not start). 14.6 volts when running after a jump start. Used it to pull trees for about an hour then shu off. Tried to start right away. No start. Cleaned all the leads including the ground. Repeated process and same result. Guess I'm buying a battery.
John
Darkstone is offline
post #22 of 24 Old June 3rd, 2012, 08:19 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Yup, yer battery is gone!!
I use the TruGel, others have recommended the Shorai
But get a gel battery....hassle free, and last forever!!
Pirate
Pirate is offline
post #23 of 24 Old June 3rd, 2012, 09:15 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Pirate
Also, consider going to your local auto-parts store (or Amazon) and buying a Battery Tender Junior. Keep your RZR plugged-in when you're not using it. I use BTJ's on all my toys; my GoldWing's battery is seven years old and still going strong. Just FWIW...........
Cheers
BarRZR is offline
post #24 of 24 Old June 3rd, 2012, 02:22 PM
Pirate's Avatar
First Name: Stuart
Member #3677
RarRZR,
I've found with my Harleys, my Miller Trailblazer welder, my Bobcat loader and excavator that if I leave the Battery Tender connected all winter, it does seem to "boil" off some of the liquid in the battery and the battery goes bad.
Talked to a Battery Tender rep in Sturgis a few years ago and he recommended hooking it up one week a month...that does the trick. Everything starts right off and the batteries don't get low.
Pirate is offline
battery going dead ryan85 General RZR Discussion 5 January 22nd, 2012 05:41 PM
Stock battery dead - battery tender the answer? dxoperator RZR 4 Specific Discussion 8 July 4th, 2011 07:38 PM
New Battery Went Dead wolfpack91 Lighting, Stereo and Electrical 2 May 23rd, 2011 07:11 AM
Dead Battery luckylarry General RZR Discussion 9 December 18th, 2009 12:58 PM
Dead Battery jdhoggg Lighting, Stereo and Electrical 1 June 15th, 2008 10:41 PM
