Outer Rear susp pivot points, grease zerks? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 31st, 2012, 12:17 PM Thread Starter
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
unless I over looked them, the outer rear pivot on knuckles don't have grease zerks..... anyone drill/tap hole and put grease zerks out there on the outer upper & lower rear pivots?
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #2 of 9 Old May 31st, 2012, 12:21 PM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Feedback Score: 5 reviews
Yes, there are several write up on people putting zerts in them.
chipper is offline
post #3 of 9 Old May 31st, 2012, 12:23 PM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
Re: Outer Rear susp pivot points, grease zerks?
Correct, you did not overlook them. Yes, zerks have been put in by various members. The necessity of zerks there have not been proven to me yet.
rardoin is offline
post #4 of 9 Old May 31st, 2012, 12:25 PM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
........anyone drill/tap hole and put grease zerks out there on the outer upper & lower rear pivots?
Yes, I and several others have. They are the only bushings on the RZR (aside from the shocks) that don't come from the factory with zerks.
Cheers
BarRZR is offline
post #5 of 9 Old May 31st, 2012, 12:30 PM Thread Starter
RacerSam's Avatar
Member #7858
thanks, thought while this engine ordeal is going on, might pull those pivots apart ,put some marine grease in/on them and drill/tap install grease zerk in the alum knuckle.
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #6 of 9 Old May 31st, 2012, 01:01 PM
srt20's Avatar
My RZR: 2015 RZR 4 900 Red
Member #23480
View srt20's Photo Gallery(0)
I put zerts in mine when I replaced my wore out bushings on my 2011 at 1000 miles.
2015 900 4 SSV Works door pods and glovebox sub, UTV headquarters roof, 30" curved led bar, Mudbusters flares Maxxis Liberty 29x9.5x15 tires, KMC Machete 15" wheels 5x2
Sold
2011 Boardwalk Blue and White LE 26" Bighorns on 14" SIXr wheels, 1.5" spacers, 58" wide, Racertech lift, front and rear bumpers,tunes by SSV Works, LTR 450 shocks
srt20 is offline
post #7 of 9 Old May 31st, 2012, 01:54 PM
texanfordracer's Avatar
Member #38966
View texanfordracer's Photo Gallery(0)
Be careful.... might void that warranty.
texanfordracer is offline
post #8 of 9 Old May 31st, 2012, 02:09 PM
Pirate's Avatar
First Name: Stuart
Member #3677
pppfffttt on warranty, won't cover the bearing carrier anyway.
Look for the thread "grease zircs the RZR should have come with". It gives good thought on where to drill and tap and what angle zirc fittings to use.
After drilling and tapping the bearing carrier, you will have to push the bushings in, use some sort of marker to mark the bushings, then use a burr to cut out the hole, half from each ends' bushing. Otherwise the grease won't get to the rod that rides in the bushing...which is what it is all about.
Yes it is a good idea. The Polaris bushings wear pretty quickly and I haven't gotten around to getting Delrin bushings from ????
Pirate
Pirate is offline
post #9 of 9 Old May 31st, 2012, 05:07 PM
flyer05's Avatar
My RZR: 2012 std 50" camo
Member #31679
View flyer05's Photo Gallery(0)
I am going to do this on my 12 800.
flyer05 is offline
Grease zerks. PETE O. General RZR Discussion 34 April 8th, 2012 08:11 AM
Grease your zerks! advrider RZR XP 900 53 August 15th, 2011 11:07 AM
Grease zerks in rear spindles. Sr10 RZR-S Specific Discussion 1 July 11th, 2011 10:15 PM
Pivot points for steering column loose? Dave I. General RZR Discussion 4 February 21st, 2010 08:08 PM
Grease Zerks Sid Community Help 15 January 3rd, 2010 08:46 AM
