battery light ? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 30th, 2012, 10:39 AM Thread Starter
hyllbylly's Avatar
Member #14356
View hyllbylly's Photo Gallery(0)
battery light ?
while riding sunday the bat.warning light started flashing, lasted about 2-5min then went off. then 4-5hrs later after dark it did it again,i couldnt tell any difference in the brightness of the headlights when the warning light came on & again after 4-5 min it went off,still no differeence in headlight brightness.i do not have any extra lights or such,just a ssv overhead ipod box. both times i was somewhere in the mid rps. any ideas from the experts here?
hyllbylly is offline
post #2 of 9 Old May 30th, 2012, 12:28 PM
Johnpeq's Avatar
Member #1490
View Johnpeq's Photo Gallery(0)
Re: battery light ?
How old is your ride,are you still using your oem battery? Have you serviced (checked the fluids)?
When my battery light started coming on in 08, I replaced the battery with an Odyssey PC925L and haven't had a problem since,
John
Johnpeq is offline
post #3 of 9 Old May 30th, 2012, 12:38 PM Thread Starter
hyllbylly's Avatar
Member #14356
Re: battery light ?
its a 08, the batt.is around a yr old.
post #4 of 9 Old May 30th, 2012, 07:02 PM
Johnpeq's Avatar
Member #1490
Re: battery light ?
Was the old battery giving the same battery light? I would remove it and take it to an auto store that checks the conditions, in my area a Carquest store checks them. The 08 owners manual states that the light comes on when there is a low or high voltage condition,
John
Johnpeq is offline
post #5 of 9 Old May 31st, 2012, 09:58 AM
rpfeiff's Avatar
My RZR: Plain and beautiful
Member #16853
View rpfeiff's Photo Gallery(0)
Re: battery light ?
It's the voltage regulator. Under the seat it gets too hot and malfunctions. Needs to be relocated to where it gets more air.
Super ATV +5, Phantom Shocks, Viper Max 4500lb, HID's, Odyssey 925, Big Horns, Artic Thunder Snorkel, UTV Inc Rear Cage & Spare Tire Mount, Alba Racing Big Bore.
rpfeiff is offline
post #6 of 9 Old May 31st, 2012, 11:48 AM
Rzr spy
grant22's Avatar
First Name: Grant
My RZR: Currently Rzr Free
Member #1714
View grant22's Photo Gallery(0)
Re: battery light ?
^^^What he said, and you might have been putting around which doesn't charge the battery much.
Also, consider a Deltran Battery Tender......$34. Keeps your battery at peak power during non-use in the garage.
But YES, consider buying Guy's voltage regulator relocation harness.....I did for my 2008 and it solved it (My 2008 with 228 hrs has the original battery).
-G
grant22 is offline
post #7 of 9 Old May 31st, 2012, 01:08 PM Thread Starter
hyllbylly's Avatar
Member #14356
Re: battery light ?
not tring to put you down, but sunday was the first time this has happened since the rzr was new, & the origonal bat just got to where it wouldnt hold a charge.ive had no issues in the yr since i replaced it ,til sunday.seems if it was the regulator it would have happened before. or maby the reg is starting to go.we got in late &i havnt had time to get to look at any thing yet.
post #8 of 9 Old May 31st, 2012, 01:26 PM
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Re: battery light ?
My VR gave me no problems for the first 2 years, then it started to. I moved it forward and all problems went away.
FYI, mines been on a battery tender since day one.
grant22 is offline
post #9 of 9 Old May 31st, 2012, 01:52 PM
N0OSV's Avatar
First Name: Jim
My RZR: 2010 RZR
Member #29795
View N0OSV's Photo Gallery(0)
Rzr Icon Re: battery light ?
Check your battery connections and the grounding points all over the machine. There is a computer processor involved and I might be getting a noisy signal. It not just about the DC voltage. The battery also works as capacitor to clean up the electrical system. Poor grounds can make strange things happen.
N0OSV is offline
battery light flashing-- New battery and light still flashes shanksyamaha General RZR Discussion 15 December 13th, 2018 07:18 PM
Battery light comes & goes ??? rzrman54 Engine and Drivetrain 10 December 30th, 2011 10:45 PM
Battery light on!!! Dankfx450r Lighting, Stereo and Electrical 9 August 13th, 2011 09:05 AM
Battery Light ??? spovelko Lighting, Stereo and Electrical 8 January 23rd, 2011 05:04 PM
Battery Light jayman69 General RZR Discussion 7 July 24th, 2008 08:06 PM
