Shock Problem - Warranty ? - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old May 30th, 2012, 06:42 AM Thread Starter
hokie95's Avatar
My RZR: 2012 RZR S
Member #19778
View hokie95's Photo Gallery(1)
Before taking to the dealer, I figured I ask if anyone else has had this issue.
Sachs shocks were adjusted to highest setting (raising it up and pulling tires in to get into the bed of the truck). Rode it for a quick lap after unloading, non-aggressive ride and definitely no jumps or anything close). Noticed the adjuster had collapsed over the bottom part (see pic). Went to adjust the other one in the rear and it immediately collapsed over the lower as soon as I started to turn it. Both in the rear, no issue in the front. Only one rider in it and no cargo.
If this is happened, how did you fix it ? I tried lifting it up and compressing the spring, but with the adjuster wrench, it wouldn' move. The spring wasn't even touching the adjuster, but that wrench just slides off too easily. Maybe use a hammer and a rod and just beat it?
If the dealer fixes this, is it warranty work? I don't really care to spend any money on these shocks.
Thanks for any input!
Name:	shock issue.jpg
hokie95 is offline
post #2 of 2 Old May 30th, 2012, 06:46 AM
bradlineberry's Avatar
First Name: brad
Member #28901
View bradlineberry's Photo Gallery(0)
Warranty is only as good as your dealer.
With that said.
Looks like its an issue to be taken care of under warranty.
Sent from my Motorola Electrify using Tapatalk 2
bradlineberry is offline
Fox Shock problem Luck8206 RZR-S Specific Discussion 5 February 12th, 2012 04:32 PM
Leaking Shock and Warranty JThomas83 RZR XP 900 4 January 16th, 2012 11:50 AM
Super atv rhino axle problem and shock help wakethis2006 Super ATV 6 May 2nd, 2011 09:02 AM
Problem with Polaris dust warranty skigill General RZR Discussion 6 March 14th, 2009 03:46 PM
will warranty cover intake problem razorback General RZR Discussion 1 July 24th, 2008 10:47 AM
